Copiers
Problem for Copiers
Generic problem for all Copiers
What is the IP address for adding names to ...
By huffines_son on Dec 04, 2008
I keep trying the IP address that I have always used for adding names to the scanner. Has it changed because I can't pull it up now?
I am putting in 170.27.80.60
Comments:
Dec 05, 2008
- The problem has been fixed. I was waiting until I found out more before I emailed you back. It was a network problem. Thanks!
Clarification Request
Posted by Bubbabear64 on Dec 05, 2008
Whats the make and model of the unit?
Posted by moe0303 on Dec 05, 2008
Note: By "machine", I mean the scanner itself. Are you able to scan to names that were already added to the scanner?
Posted by Cogz on Dec 05, 2008
Are you using the same IP adress for more the one device? Each device needs it own sepperate adress to work correctly..
Posted by moe0303 on Dec 04, 2008
This is something set up on your individual machine. You will have to go thru the menus to find it. If you let me know what kind of machine it is and the model number, I can help you more.
Solution #1
posted on Dec 05, 2008
Not Rated)
moe0303
Rank: Guru
Rating: 87%, 37 votes
Thanks for the reply. I'm glad you got it working again. Please mark this as solved so that it is taken out of que. Thanks again for using Fixya.
Was this helpful?
Yes
No
Popular Solutions for Copiers
Questions and Unsolved Problems for Copiers
Answer
conica minolta bizhub 35o vs kyocera in same price range
Answer
I am told there is a paper jam, I have taken the paper out, went through the diagram and still says... (More)
Answer
I have a EX-3535 fuser error code 004-361 coming up on a new fuser on a machine. I changed the fuser... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Copiers:
Top Copier Experts
Rank: Guru Guru
Solutions: 782
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
