Question about Pentax *ist DS Digital Camera
Picture mode Only half of the picture modes are available. Neither tv or av are avilable only p and m On the other side of the dial only macro sport flash off and auto are availabl So when I put the dial on tv it will say program exposure. Is this a software problem or a problem with the dial
    Problem Solver:
  • 14 Answers
You also need to make sure the lens apature ring is in the right position, turned all the way to the right and set on the A locked position. also go thru all the menus and make sure all the custom settings are set back to factory and start over with the settings
Posted on Oct 07, 2009
    Novelist:
  • 107 Answers
This is most likely a problem with the dial itself. Generally speaking the software within the camera does not fail unless something breaks within the camera. To make absolutely sure - contact the manufacturer and find out if there is an active recall for this product. If it is a manufacturing or software fault they will recall it. Otherwise it will have to be professionally repaired. David Millier Advance Camera Repair
Posted on Feb 24, 2007
My camera works fine in all ways except whenever i turn the 'flash' on and try to take picture the green light just flashes repeatedly and it won't take a picture at all, but if i turn the...
Referring user guide:
Are you press ligthly? if press half and ligthly, it will not take the picture.
When you have using macro mode, you need to disable Flash mode.macro mode will show picture(flower) and avoid hand shake during this mode.
When you take in 10cm range in macro mode, it will take more longer time to autofoucus, you need to be freeze a while until it take the picture. The best it, try to take picture in without you inhale. it will avoid you from shage
Try using in different DIS mode when you using the flash.
In some mode, it will have twice flash. First flash it will check the condition and wait until second flash and dont move your camera.
Some condition, you will get the picture is white, it because from dust atmhospheric that we cant see. it reflective to ur flash.for the best picture, you need to try in different mode and different condition. that will make you as proffesional. this camera have many mode that you need to understand. training urself to be perfect. download manual and test your camera
May 12, 2011 | Samsung S860 Digital Camera
Whenever I try to put on the flash, it says no flash in the macro mode. What does thaat mean and what do i do!!! Its really frustrating because it already doesn't take good pictures and i need the flash.
Macro mode is used for taking close-up pictures. In this mode, as the camera says, you cannot use the flash. There's a slide switch on the left side of the camera, near the USB jack. To take the camera out of macro mode, slide it away from the flower and toward the mountain.
Feb 22, 2011 | Vivitar ViviCam 8025 Digital Camera
Why does my camera say macro mode when i try pitting the flash
There's a slide switch on the left side of the camera, near the USB port. Slide the switch away from the flower icon toward the mountain icon to switch it out of macro mode. The macro mode is for taking pictures of subjects very close to the camera, and the camera won't fire the flash when in macro mode.
Dec 23, 2010 | Vivitar ViviCam 8025 Digital Camera
When i try to turn my flash on it says Macro Mode
You're in macro mode and the flash won't function. Check your manual to find out how to get out of macro mode. Most cameras have a button or a dial with a picture of a flower representing macro mode. Find that and change it.
Dec 26, 2009 | Vivitar ViviCam 8025 Digital Camera
How do I see my pictures in macro mode? If shows
click on the " flower" icon on the dial wheel to select the macro mode and then shoot normally. also, do remember to return to normal mode by pressing the flower icon again... or else you might end up getting blurry images.
Feb 18, 2009 | Canon PowerShot SX10 IS Digital Camera
Pentax istDS Digital Camera, How to set Custom White Balance in Auto Modes
Custom white balance can only be set in P, Tv, Av, or M modes. The auto modes are, well, automatic. They are all preconfigured and intended for ease of use not configurability.
Nov 08, 2008 | Pentax *ist DS Digital Camera
Please help!
Try going into the M(anual) mode on the selector dial and then turn off the flash (press the right side of the controller button until you see the lightning bolt with a bar through it). The macro shooting option should still be available in the manual mode.
Apr 17, 2008 | Canon PowerShot A460 Digital Camera
CANNON S50IS
Guest is quite right - use the macro button on left hand side of lens (holding camera pointing at subject) Press once for "macro" which focuses from 10cm away. If you hold this button in for about 2 seconds, it puts your camera into "supermacro" mode, which gives focus from right up against the lens! (need backlighting for this close!) Supermacro will not work in Auto and Sport mode. Best is to use "AV" or "TV"
As far as viewing your pics goes - rotate the mode lever (You turn this anti-clockwise to turn ON) clockwise and you will see the most recent pic on your LCD screen. Use the left and right direction on the omni selector to naviagate through your pics.
Its a good idea to download the advanced manual onto your pc from the dic supplied. Its an adobe document and very user-friendly.
I hope this helps you.... :)
Mar 21, 2008 | Canon PowerShot S5 IS Digital Camera
Canon 20D strong blue cast to pictures
You probably have the White Balance set to a setting other a
than "Auto White Balance" (AWB). On the top of the camera, above the exterior LCD panel, there is the "AF-WB" button. Turn the camera on--past "on" to the bent line. Press the AF-WB button once. On the left side of the exterior LCD panel there is a vertical, reticular box with the symbol of the selected setting for WB. Normally, the setting should be set to AWB. If it is not, turn the command dial at the back of the camera until "AWB" is showing. Try shooting again-the color should be better.
In the "auto" modes (green box, portrait, landscape, etc) the AWB is automatically set. In the "advanced" modes (P,Tv, etc) the WB is manually set for whatever light source you are using. The command dial may have been accidently turned to different setting. Hope this helps.
Jan 23, 2008 | Canon EOS-20D Body only Digital Camera
Focus
Your camera has the ability to shoot Macro and Super Macro, although in some Dial Modes, you can't use Macro.
To engage the Macro mode, press once the button on the left side of the lens/camera that looks like a Flower. To engage the Super Macro mode, press and hold the same button for more than one second.
Macro mode range 3.9 in. - 1.6 ft
Super Macro mode range is 0 in. - 3.9 in.
To cancel Macro mode, press the Flower icon button once.
Zoom levels are limited, and you will know that when the zoom bar turns yellow. This means the zoom is not available at that zoom level.
Hope this helps.
Nov 24, 2007 | Canon PowerShot S3 IS Digital Camera
Pentax *ist DS Digital Camera Logo
51 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
