Question about Garmin Quest GPS Receiver
GPS I have a garmin Quest GPS it keeps dopping out of satellite reception even when there is only lite tree cover.does anyone out there have any ideas that can help me? (GPS has no external antenna and is mounted in side a car)your sincerely April
  • 24 Answers
Http://www.fixya.com/support/t3119011-quest_2_antenna_contacts_cleaning
The antenna is on a spring loaded hinge and over time can get dirty where it connects to the gps. I have seen instances where cleaning the contacts helped the performance. Just be careful when removing the plastic endcap on the back of the GPS. There is a small spring that can fly out of there and is lost easily.
Posted on Jan 23, 2010
My garmin wont keep up in the woods
Correct. Like all satnavs it needs a fairly clear and unimpeded view of the sky in order to connect with the satellites. The signals from the satellites are incredibly weak and so it doesn't take much to block them out.
Tree cover, tall buildings, deep gulleys and similar will reduce accuracy and location refresh rates or even prevent them altogether.
Jul 26, 2011 | Garmin eTrex Legend GPS Receiver
GPS Garmin 1450 poor satelittle signal- can't find satelittloes
If the Garmin nuvi 1450 could find satellites at the same location and time before there's something wrong with the built-in receiver / antenna. Because it's not accessible from the outside it needs to be opened to check the antenna connections. Best is to check battery at the same time and replace it - once the problem is fixed.
At some locations there can be poor GPS sat reception - due to line of sight obstructions, such as trees, buildings. For a 2D fix it needs to "see" at least 3 satellites signals.
Jul 05, 2011 | Garmin nuvi 1450 GPS Receiver
Rino 530 keeps loosing signal was hunting in Canada using rino while walking . keeps saying no satalite
The GPS needs a clear view of the sky and at least 3 or more satellites to get a fix on your position. If you are under a heavy canopy of tree cover / brush, it can affect accuracy and even the GPS's ability to get a fix at all. Also, if you are in a mountainous region, the geometry of your location and the location of the satellites over the equator could be obstructed, resulting in the lost satellite messages. You must have an unobstructed view of the southern sky to get a fix.
If you are able to get a fix in an open area, the GPS is able to do its job, but the location you're trying to use it in is offers too much interference to capture satellite signals.
Making sure you've got the latest firmware from Garmin can solve a lot of troubles, too. If you still believe that your GPS isn't working the way it should, contact Garmin Support.
I hope this helps - and good luck. Please rate my reply - thank you.
Feb 23, 2011 | Garmin Rino 530 GPS Receiver
My Garmin Quest displays...detail maps don't support routing.The position of my vehicle is shown slightly to the left of the roads I am driving on.
May be zoomed in to close, could be that the antenna is not receiving good satellite signals, some windshields have metal to lower sun energy and this can affect reception. Try external antenna.....
Feb 13, 2010 | Garmin Quest GPS Receiver
GPS won't pick up satellite reception.
Let's assume the unit is in good conditions. When you travel for more than 500 Kms the unit need more time to acquire the satellites, so the solution is to keep the unit on in a uncovered area for about 15 minutes.
Regards
Osiris
Aug 11, 2009 | Garmin eTrex Legend GPS Receiver
The gps looses satellite reception. Repositioning
DIY is risky in this situation, besides there is 3 months warranty by Garmin on their interventions I would suggest you get it done by the professionals
Jul 18, 2009 | Garmin Quest GPS Receiver
Won't acquire satellites
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} make sure you are in view of clear sky, large buildings, trees and even clouds will make it harder to track satellites.
May 19, 2009 | Garmin eTrex Venture Cx GPS Receiver
Satellite loss
How long has it been since you updated the firmware on your unit? Try updating and see if this helps. Also, keep in mind the receiver on the C330 is not as sharp as on other units like the C550 and some of the Nuvis. You may have problems while under overpasses, between large trees or buildings, etc. This is just a design limitation of the unit.
Feb 08, 2008 | Garmin StreetPilot C330 GPS Receiver
Losing Satellite signal
Latest software is 5.20, GPS sw 3.0
Go to the following link for more info on WAAS
http://www8.garmin.com/aboutGPS/waas.html
WAAS doesn't have anything to do with satellite reception.
Dec 26, 2007 | Garmin nuvi 350 GPS Receiver
Garmin Quest GPS Receiver Logo
107 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
