Question about Xerox Phaser 7300DN Laser Printer
Technical Black Imaging Unit Replaced,Error message still shows
Phaser 7400 Printer.
Told us to replace Black Imaging Unit. We replaced with brand new unit. Error message still shows. Have rebooted printer. Taken and put back in imaging unit. Clean unit and area placed in and still shows message. Thank you in advance for ANY help.
  • 37 Answers
These units are automatically reset with a fuse. When you put the imaging unit in it will completes a connection which resets the count then simultaniously blows the fuse. Sometimes the fuse blows before the reset, which is what it sounds like happened here. The machine should print normally but the error will persist until the unit is replaced with a new one. Is the the imaging unit an OEM unit or remanufactured? Whoever you got the unit from should replace it as defective free of charge. If it is OEM you might have to go through Xerox to get it replaced. I don't know if the Big Box stores will.
Posted on Dec 04, 2008
  • 97 Answers
Check out the details about this issue on my web site :
http://michelsplace
Posted on Mar 03, 2011
I have tried using a new fuse to cause an imaging unit to reset on a Phaser 7400 but the fuse will not blow.
If the unit is remanufactured or if you know how, you will have to disassembly the imaging unit and replace the fuser that blowns or simply just solder it. http://www.uninetimaging.com/downloads/technical/xerox/english/Xerox_Phaser_7400_Reman_Eng.pdf
Graphic 27.
Mar 30, 2014 | Xerox Phaser 7400/DXF Laser Printer
Xerox Phaser 7400 U28 error message
The Service manual says:
The Drum Phase Sensor for the named Imaging Unit indicates that the drum is out of position.
Initial Actions:
Reseat the indicated Imaging Unit.
Cycle the printer's power.
after these steps it gets a lot more detailed and you would need to be an experienced tech to understand everything and follow the steps within a timely manner, if reseating the cyan imaging unit doesn't fix the problem, then you will have to call for service.
Hope that helps
Christopher
May 20, 2012 | Xerox Phaser 7400/N Printer
Xerox Phaser Printer has an error message cyan imaging defected, the unit was replaced with a new one, still getting message
There is a list of different parts that can be causing this error.
The first one is if its not seated properly. You can take it out and put it back in to make sure it is seated. Having bought a new one means that this is the only simple solution to this problem.
Here are the different parts that may need to be replaced as per the service manual states:
the imaging unit sensor board
the CTG0 harness
the engine control board
imaging unit motor
the lift uplink
the motor driver board
the low voltage power supply
!! that't a lot of possibilities and there are a series of electrical and mechanical tests that must be performed. You will have to call for service. Unless its seated incorrectly.
Xerox phaser 7400 giving error - replace imaging unit- what solution now?
Did it specify a color you should replace? The machine has 4 image units (CMYK) each with a different part#. Replacing them is easy, no tools required. Open the top door, lift out the entire image unit, move the toner over to the new unit, and lower the image unit. Here are the part #'s for the 7400 for each color. Iteminc.com has these online.
C - 108R00647
M - 108R00648
Y - 108R00649
K - 108R00650
Good luck, hope this helps. Thanks for using FixYa!
Aug 05, 2011 | Xerox Phaser 6350/YDT Laser Printer
Phaser 7760 Error message: "Imaging
The black image unit of your machine should be replaced soon. It is a maintenance item and is very easy to change. They cost about $350 new, but you can buy one much cheaper rebuilt. Here is a video I made to help explain what it is you need to change and how to do it. Good luck
Nov 16, 2010 | Xerox Phaser 7760/YDX Laser Printer
What is error code 941 on a Xerox Phaser 7400?
www.support.xerox.com -phaser 7400- support -fault code-941 says cyan or magenta toner failure, but the solution says to
1. remove & reinsert the cyan or magenta imaging units.
2. replace imaging units .
check out the site to see if helpful
Jul 01, 2010 | Xerox Phaser 7400DN Laser Printer
Xerox phaser 7400 replaced yellow toner, but still getting replace toner error. I've reseated it twice, reseated the imagining unit and tried turning it off.
You can try do a NVRAM reset. If after that you still have the error message then I would tell you to contact the Xerox team as you might have a wrong consumable (defected/wrong CRUM) information.
NVRAM reset: http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=36,E=0000000002092637520,K=9394,Sxi=5,Case=obj(3085)
May 16, 2010 | Xerox Phaser 7400/N Printer
We have a Phaser 7400. It continues to give us
If you've already changed out the toner cartridge and the problem persists, then it could be several other parts that are either defective, dirty or blocked.
You may want to contact a certified Xerox technician and have them look at the Imaging Unit Agitator Bar and the Low Toner Sensors for Cyan/Magenta. There could also be a faulty toner supply motor.
Sep 10, 2009 | Xerox Phaser 7400/DT Laser Printer
Black Imaging Unit
If the machine calls for a new unit, a new not used cartridge must be installed to clear the message
Mar 27, 2007 | Xerox Phaser 7400DN Laser Printer
Xerox Phaser 7300DN Laser Printer Logo
1,070 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
