Question about Desa International ReddyHeater® R115DT Utility
Hello. I have a Ready Heater, Model R150B, Kerosene burner. It needs a new fuel tank assembly. Can I order one from you? If so how much will it cost? Need cap also. Thanks Gary.
  • 188 Answers
Here is a link to your owner's manual... http://12.153.20.74/manuals/099176-01J.pdf. I suggest you go online to www.masterparts.net or call them toll free at 800-446-1446. They should be able to assit you in getting your parts. I hope this helps!
Posted on May 21, 2009
R150B kerosene reddy heater, every 2 to 3 seconds It has spurts of flame, why?
generally water or air in the line will interrupt the flame momentarily.
Nov 25, 2014 | Reddy Heating & Cooling
My kerosene monitor heater with the model number M441 isnt workin correctly , ive changed the filter outside that goes into the tank and replaced the burner and still it isnt working , the burner status...
First thing to do is clean the flame rod. Take the black grill off of the front of the heater (6 ro 7 screws). Now locate the flame rod. It is beside the window where you can look into the burner. It has one wire going to it. Be careful so you don't damage the gasket. The rod goes in then straight down, so you will have to turn it to get it out. You can clean it with some steelwool or emory cloth. Reinstall it and try the heater.
Listen to the heater. If it cuts off, does the fuel pump start making a thumping before the heater cuts off? If it does, the heater is running out of fuel for some reason. I know you checked the filter, but did you check the strainer in the fuel sump. You can find it on the right side of the heater at the bottom. Make sure you turn off the fuel at the barrel before you remove it and have some rags ready to soak up the kerosene that will come out. Clean the filter with some kerosene if it needs it.
Let me know what you find and don't forget to rate my answer. Thanks.
Jan 06, 2011 | Heating & Cooling
Kerosene will not ignite, new igniter, fuel comes out of injecter but fuel does not ignite. Does kerosene go bad?
Yes it loses volitility, but i think you have water that you are trying to burn. Completely empty the tank and go get new kerosene. The can you have could have water in it as well. Water gathers in any tank or can, from condensing water over the spring, summer and fall months the heater is not used. With a fuel change you should be as good as the first day you used your heater.
Hope all goes well, and stay warm.
Matt
Dec 31, 2010 | Garden
Ignites /starts will cut out after a few minutes
There are several reasons as to why this happens, and with that being said there are several things to correct this problem. I do this as preventative maintenance, remove the top section of the burner tube, this exposes the entire burner tray and internal parts. Locate the nozzle and remove it, they say you can not clean these, I say with a Q-tip, tooth pick and carb cleaner you can with out damaging it. Now behind the nozzle is a screen assembly these corrode at times so make sure to clean it as well.After cleaning up assemblies put the nozzle and filter screen back together.Next is the flame sensor, it is located below the nozzle assembly, round in shape and has a lens of sorts at the front. These collect carbon deposits, dirt, and the occasional homeless insect. It can be cleaned with a soft terry cloth rag and windex, now inspect the fuel lines for cracks, holes, or dry rot, replace if necessary. Locate the fuel pump next, on the back of it there is a foam air filter, this I clean with dawn dish soap rinse and dry really good, then put it back. Trace the fuel lines back to where they come thru the burner tube, now remove the side cover, you should see the fuel line and it goes to an in line filter. Remove the filter and I use a compressor and blow gun to clean it by blowing air backwards thru the filter, instantly clean. Inspect your lines again, replace if necessary. Replace side cover and open the fuel tank, lean the heater so the fuel runs towards the fuel filler opening. You are looking to see if water is in the tank, this happens from condensation when in storage. If there is I drain the fuel in to a clean five gallon bucket, now the fuel will float on top of the water and you should be able to see it.If there is water try to dry out the tank with a rag and remove as much water as you can. You can siphon off the fuel from the water and reuse it if you like just be careful not to siphon to far and get the water. Fill your heater with fuel, put cover back on the heater and plug it in, it should now fire up like new. Good luck
Dec 29, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
I have a all pro R60A that turns on but shuts right off and blows tons of smoke out after shutting off.
These heaters have several things that happen to them while in storage. I do a yearly check on mine and it goes like this. Open the fuel tank and tilt the heater to see fuel at the filler hole, look at the fuel and tank you are looking for any water in the tank. Condensation is usually the culprit, what I do is drain the tank in to a clean five gallon bucket and the fuel floats on top of the water. If you see water use a rag and try to dry out the tank as best as you can. You can also siphon off the fuel for reuse just be careful not to siphon to much and get the water again. Next remove the top section of the heater tube, this exposes all of the internal burner parts. Locate the burner tray and remove it so you can access the fuel nozzle. Remove the nozzle, they say you cannot clean these but I say different. You need a Q-tip, tooth pick and carb cleaner and clean it up carefully so you do not damage the nozzle. Behind the nozzle is a screen these like to corrode so clean it real good too. Put the nozzle assembly back together, inspect your fuel lines for cracks, dry rot or holes and replace if necessary. At the bottom of the assembly there is a sensor for flame these collect carbon deposits,dirt and the occasional homeless insect. Clean this with windex and a soft terry cloth rag. Put the burner tray back together. Trace the fuel lines back to where they come thru the heater tube and now remove the side cover. You will find the fuel line and an in line filter remove the filter and clean this with a compressor and blow gun by blowing air backwards thru the filter. This instantly cleans the filter, now put it back together after inspecting the fuel lines,and replacing it if necessary. Put the side cover back on and go to the fuel/ air pump on the back of this there should be an air filter usually foam, clean this with dawn dish soap and dry really good before putting it back in.Inspect and clean igniter while you are inside the heater, then put the top section back together. Now you are ready to plug your heater back in and test it. If all went well you should be heating like it did when it was new. Just a tip for you is to look at the fuel coming out the nozzle it should be a fog not droplets, if droplets your nozzle needs changed. Pay attention to spray angle and GPH rating very very important.
I HAVE ALL-PRO 115000 BTU WHEN I TURN ON RUN FIIL MINUTES AND SHUT OFF
There are several things that you can do to this heater and I have made it a yearly practice to pull this preventative maintenance. Here we go, remove the top section of the heater tube this exposes all of the internal workings of the heater. Locate the burner tray, on the front is a brass nozzle which they say you can not clean. I say with carb cleaner a q-tip and tooth pick you can, in behind the nozzle a screen assembly clean this too they like to corrode. Put the nozzle assembly back together and inspect all fuel lines for cracks, holes,and dry rot replace if necessary. At the bottom of the burner tray there is a round item, this is your flame sensor. These are known to collect carbon deposits, dirt, and occasional homeless insect, clean it with windex and a soft terry cloth rag. Now put the burner tray back in the heater. Trace the fuel lines down to where they come thru the case, remove the side panel cover here is where you will find the fuel line and an in line filter. Remove the fuel filter and I use a compressor and blow gun to clean these, simply blow air backwards thru the filter and instantly it's clean. Inspect those lines again if all is good put filter and lines back together and replace the side cover. on the back of the fuel pump is a foam rubber air filter, wash it out I use dawn dish soap, but dry it real good then put it back in. Now replace the top and I want you to open the fuel tank and tilt your heater towards the fuel opening, you are looking to see if there is water from condensation while being stored. If there is empty the tank in to a five gallon bucket, oil is lighter than water so fuel floats to the top. You can either throw it out and dry out your fuel tank or siphon off the fuel and reuse it, just be careful not to get any of the water. Now you are ready to test your heater.Plug it in and you should be up and running like new again.Good luck
Dec 28, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
My monitor 2200 heater is leaking fuel what could be the problem
That depends on where the leak is. If it is leaking out of the fuel sump the needle valve in the sump could be stuck or just leaking by so that the sump is over flowing. You could also make sure the fuel line fittings are tight where it connects to the pump and the burner chamber. If you are using an internal tank you should take the tank out and look down in the heater for kerosene. Check the fuel fittings in the back of the heater. Has the heater been working? If has gone through several attempts to start but hasn't lit kerosene could be built up in the burner and you should check the igniter. Also you would want to dry up any excess kerosene in of the burner. There are also some o-rings in the fuel pump itself but I wouldn't think they would be leaking. Basically there are not a lot of places it could be leaking just follow the fuel line from the back of the heater to the burner. You may need to wipe up the kerosene and then look for a drip. Hope this helps.
Mar 30, 2010 | Heating & Cooling
R150B Kerosene Reddy Heater-
Neither of you state the model of heater that is giving you starting problems. many of the motors have an external starting capacitor (relay). If so, you may just need that part, if your heater is equipped with one. On the other hand, many have an internal capacitor , which is not servicable.
Feb 15, 2009 | Desa International ReddyHeater® R115DT...
Ready Heater 200 BTU Kerosene
Try a part from a similar heater like Mr. Heater Most of the parts are identical they just mount a little different, put the new part on your old mount. Had a similar problem with my dyna glo and with a little rigging it works like new.
Jan 22, 2009 | Desa International Reddy Heater R200BT...
Wick and manual for Montgomery Wards Windsor kerosene heater
Hi, I have a Montgomery Ward Sunheat heater. It's a dual burner enclosed type with a door on the front. The fuel tank is cylindrical and about 1 1/2 - 2 gallons. The cap has a needle valve and when turned upside down releases fuel to the burners by gravity. The whole heater itself is rectangular with louvers on the sides and top. I don't know what wicks go in this or if there are compatible replacements out there.
No 84ALO5800A is the only I.D. or Model No.
Thanks,
Jack
Nov 27, 2008 | Montgomery Ward (223600UP) Heater
Desa International ReddyHeater® R115DT Utility Logo
120 people viewed this question
Top Desa International Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
