Question about HP Pavilion Media Center a1330n - AMD Athlon 64 2.4GHz Desktop Computer (Open Box Product, Limited Avai... (EL466AAABAOB)
Using the digital out on my HP Pavilion m9360f Elite Desktop PC
What audio output should I use to connect to my line in on my stereo? The stereo has a 3.5 mm input jack. The digital out has a rca jack and that is not a problem if this is the output I should use
    Problem Solver:
  • 11 Answers
That's not an RCA jack that is for digital cable to connect to a surround sound system. What you want to do is connect an rca jack to the lime green out jack for a 2 speaker stereo system.
Posted on Jan 11, 2009
Audio card; which kind is in optiplex 755
Du?an Macejko,
ADI1984 Integrated Audio The OptiPlex 755 HDA audio implementation uses the HDA 1.0-compliant digital bus from the ICH8 and the Analog Devices ADI1984 HDA codec.
The Analog Devices codec provides the following:
  • Analog inputs for line-in and mic
  • A single amplified stereo output connected to front headphones
  • A line level output connected to back line-out
  • A mono output for optional internal speaker
    Thank You,
    Dell-Jesse L
    Dell Social Media and Community
Feb 07, 2013 | Dell Optiplex 755 Desktop Desktop Computer...
Power pulsing
Did you put a compatible video card in? What do you mean by pulse on and off? Is it trying to boot up, then shuts off before it boots?
Remove the power cord and press and hold the power button for 30 seconds, then put it back in and try to boot.
Apr 02, 2012 | HP KQ499AA Pavilion Elite M9360F Desktop...
Connected laptop to tv, but sound only come from laptop. How can I make the sound come out from tv?
If your laptop has a HDMI output, and your TV has a HDMI input, then use a HDMI-to-HDMI cable, which carries both "audio" and "video" signals.
Otherwise, you need a cable from the "headphone" output from your PC into the "RCA" stereo-audio inputs into your TV.
Dec 20, 2010 | HP Pavilion dv6-1030us Notebook
How do you install an audio output device?
this depends on what kinda audio output you want to install ..but the general idea is to get the audio signal from the computer from the green out in the back on the sound card (it is a 3.5 jack ) ..and there is the stereo out-put for the computer's sound..It can be amplified in any device that has a stereo input on 3.5 jack ..
if you want something more complicated..the map of the out-put (the scheme) will be shown in the sound manager (of teh driver ) ..when you make the output changes..This is on a color code..and can be 2+1...3+1..4+1..and the surround 5+1..when you choose surround 5+1 from the sound manager ..it is shown all 3 outputs and the role they play ..bass+center ...Front ...and rear ..they are 2by 2 stereo paired on left and right ..
Sep 02, 2010 | HP PAVILION A6230N DESKTOP PC
I need to knowwhat phono leads I need to connect pc to tv -sound to come out of tv-Ive a medion pc? WHERE do I connect the leads on the pc?
Normally 3 standard sockets for audio, line in, line out and mic in, that are coloured blue green and pink respectively, for audio out connect to green socket (3.5mm jack plug)
May 11, 2010 | Medion MD-1704 PC Desktop
Speakers don't Work on HP Pavilion f1903 desktop
Just match the color of the male and female on each end. Plug the audio cable (mini stereo phone plugs) to the PC audio line out (green miniphone jack) to the Powered speaker mini stereo phone audio line input jack (green color jack). You will have to set the volume controls of the speaker control knob and at the PC on screen volume control panel.
Mar 29, 2010 | HP Pavilion F1903 19" LCD Monitor
Computer frequently shuts down unexpectedly/ fans very noisy
You might have a cooling problem due to a fan malfunction. It is not clear whether it's the power supply fan or the CPU fan; in the latter case you might also have a thermal coupling problem. The symptoms you describe certainly seem to point to such.
My advice would be to replace the fan (or the whole power supply; you might also want to purchase a "Silent Power" unit for quieter computing). If it's the CPU fan and you are comfortable with, or know anyone comfortable with a bit of PC servicing, you might want to also unmount the heat sink from the CPU and replace the thermal paste between CPU and heatsink. Clean the heat dissipator (the black metal grille over the heatsink) with hot water and a bit of soap and dry thoroughly, or wipe it energically with a dust brush, before mounting the new fan on it.
Feb 28, 2010 | HP KQ499AA Pavilion Elite M9360F Desktop...
Should i need sound card,audio driver or what my mic is not detected on messengers and even i change set up on messenger tools set up.
Yes sound card plus audio driver is needed for microphone to work.
Here is the audio driver link
ftp://ftp.hp.com/pub/softpaq/sp28001-28500/sp28481.exe
Download it and have it install.
here is the details of what to plug in your sound card
line output (usually with a 1/8" stereo minijack). You can feed this into a cassette deck or an amplifier (ideally connected to a good pair of near-field monitor speakers) for playback and mixing purposes. If you have a really cheap soundcard, it won't even have this and you'll have to get your output from the...
headphone jack (with a 1/8" stereo minijack). You can use this for monitoring while recording, but don't use headphones for mixing.
line input (usually with a 1/8" stereo minijack). This is the only thing you should plug any of your musical recording stuff into.
Dec 09, 2009 | HP Pavilion dv1000 Notebook
Looking for line level input or a card I can use with line level input.
There is high performance stereo input PCMCIA cards, not cheap, also a cheaper alternative stereo input USB devices.
Check them out on the Internet, use Google search.
May 05, 2009 | HP Pavilion dv9000z Notebook
PC Grounding Problem
This ground loop isolator from Radio Shack was suggested when I did a search:
http://www.radioshack.com/product/index.jsp?productId=2062214
It says it has the 1/8 jack adapter, so it should plug right in!
I'd be curious to hear about the results if you try it.
Good Luck!
Feb 04, 2009 | HP Pavilion Media Center a1330n - AMD...
Computers & Internet Logo
107 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
