Question about HP Hewlett Packard LaserJet 3000dn Printer
Unable to delete a command in the spool que?
I was in the process of printing and received an error message. After removing the paper jam and deleting the command the status says deleting but appears to be frozen.
The problem has been resolved. I re-booted my pc and the command finally completed deletion. Thank you for your assistance.
Sharon
Posted on Dec 05, 2008
My printer is telling me there is a job in the que thats preventing it from printing ...When I run the troubleshooter it tells me its fixed ! But i still see the error msg and the printer will not print
You need to delete all jobs in the print queue, see instructions below:
If you've ever had a print job hang, you're probably familiar with the Windows Print Spooler window. You get to this window simply by selecting the relevant printer from the Control Panel's Printers and Faxes applet (simply Printers in Vista). In the somewhat unusual event of a printer queue jam, you can go to the Print Spooler and simply delete the job. Sometimes, though, the system won't let you cut off print jobs that way: It marks the job "Deleting..." but never quite gets there, and you end up rebooting. But there's an easier way.
Open a command prompt (go to Start ' Run, then type cmd) and type the following, pressing enter after each line:
net stop spooler
del c:\windows\system32\spool\printers\*.shd
del c:\windows\system32\spool\printers\*.spl
net start spooler
In Vista you'll need to open an elevated command prompt by right-clicking on cmd.exe and selecting Run as Administrator. For those of you who remember batch files, use Notepad to save the four commands above as a batch file. I've named mine Killqueue.bat.
Jan 08, 2011 | HP Color LaserJet 2600n Printer
Cannot empty the print que print jobs on IMac status is Deleted, except for last line which says "printing", but it is not printing
This is most likely because an error with the printer is making it impossible to delete the final print job. The most common error is no paper or a paper jam. Look for blinking lights on the printer and any error messages. Feed more paper if necessary. Once you fix the problem, reset the printer or press the blinking button.
Feb 21, 2010 | Dymo LabelWriter Thermal Printer
HP Color laser jet 4700n 49.3048 service error
The problem is usually caused by printing a PDF file with fonts/page size/ page formating errors which will cause the printer to display the 49.3048 error. The only way to use the printer is to POR or recycle the power and delete the print job from the server or spooling device and cancel it on the printer before the offending command is issued to the printer again. You can try updating the firmware to the latest version 46.140.5 from the HP website. MIke L.
Oct 12, 2009 | HP Color LaserJet CP4005dn Network Printer
My Lexmark 2500 does not print half the time and the print que won't delete when I go into printers. Any sugestions? I have Vista.
To delete the documents in the print que go to start right click on 'cmd' and select 'run as administrator' and type net stop spooler and minimise the window.
Hold the windows logo key on the keyboard and hit the letter 'R'
Now type 'spool' and push 'ok'
In 'Spool' go to drivers-w32x86-3 and delete all the files you see there
Go back to the command prompt and type net start spooler.
If you donot want to follow these steps, you can simply unplug the printer USB cable from your computer and restart the computer.
Both are 100% fixes.
Apr 18, 2009 | Lexmark X2500 All-In-One Printer
HP photosmart C5280 document stuck in print que
Delete document manually from the path mentioned below:
1) Press windows + R an then type spool
2) Go to PRINTERS folder.
3) Delete the files present in there.
If not able to delete then
1) Open command prompt.
2) type "net stop spooler" and then delete the files
3)Again type "net start spooler"
Your stuck document is now cleaned. You can start printing your document again.
Mar 30, 2009 | HP Office Equipment & Supplies
I was in the process of printing some pictures when it stopped and only printed half of a picture. I checked the stauess of the printer and it said there was an error. I tried to cancel/delete the printing...
If the job is hung in the print que, and it will not delete, turn the printer off, then shut down the system. Turn the printer back on, and re-start the computer. This should clear the data spool that you were not able to delete.
Nov 20, 2008 | HP Office Equipment & Supplies
Printing status frozen and won't delete or print
Have you tried unpluging your printer from the computer as well as unpluging the printer from the electrical? If that doesn't work you should start from scratch... that is remove the printer from the computer memory, delete it, turn off the computer, turn on the computer and go through the installation process as if you just purchased the printer. Barring any mechanical problems as in jams or the such, the printer should return to operational status.
Oct 07, 2008 | HP DeskJet 5150 InkJet Printer
Flashing red lights and letter E on my hp printer
basically for this printer I have found that just restarting your computer will solve almost anything. make sure there is no paper left jammed in the printer and restart. sometimes you have to delete the print job in the printer que. there should be a printer icon down my your clock, right click, open active printers, and delete your file. restart your computer and try again
Sep 18, 2008 | HP DeskJet F380 All-In-One Printer
Unable to delete print job
Switch off or unplug the printer and then delete it. make sure you have administration rights to delete print cue if your under active directory.
Dec 12, 2007 | Office Equipment & Supplies
HP Hewlett Packard LaserJet 3000dn Printer Logo
188 people viewed this question
Seeker5211
Seeker5211
