I am in need of a HP CLJ 3600n Service Manual.
    President:
  • 8,637 Answers
Not totally sure this is the right site but worth a try for the manual. Bud
http://www.generalmanual.com/Printers/HP-Color-LaserJet-3600dn-Printer.htm
Posted on Jan 07, 2009
HP CLJ 5500
If you mean toner, you can probably do it, but most new printers have a memory chip on the cartridge which keeps track of toner. Adding toner will not change the count and the printer will ignore the new toner
Jan 04, 2014 | HP LaserJet 9500mfp Printer
Cartrage not engaged
Try to follow the instructions in a user's manual:
http://www.retrevo.com/support/HP-3600n-Printers-manual/id/313ag619/t/2/
www.hp.com/support/cij3600
Jan 24, 2013 | HP LaserJet 3600n Printer
Where can I find a service manual for HP CP1215
http://www.feedroller.com/store/Service%20Manual/CLJ-CP1210-CP1510-Manual.pdf
Sep 06, 2012 | HEWLETT-PACKARD HP Color LJ CM1312 MFP...
Hp clj 3600 error code 51.23 find the solution
51.XY ERROR
alternates with To continue turn off then on
A printer error has occurred.
X Description:
2 laser
Y Description:
0 Black
1 Cyan
2 Yellow
3 Magenta
Your error then comes from the magenta laser.
The recommendations from the service manual are:
  1. If the message persists, turn the printer off and then on.
  2. Reseat DC controller connectors J1022, J1026, and J1027.
  3. Reseat laser/scanner unit connectors J101A, J101B, J5001A, J5001B, and J5020.
  4. Replace the laser/scanner unit as necessary.
  5. Replace the DC controller PCB as necessary.
Mar 08, 2011 | HP LaserJet 3600n Printer
I have an HP Color Laserjet 3600n with error 10.10.03
Thank you for contacting FixYa with your printer issue.
www.hp.com Support Document (110993)
10.XX.YY SUPPLY MEMORY ERROR Description The printer cannot read or write to at least one print cartridge memory tag, or at least one memory tag is missing. Action
  1. Open and close the front door.
  2. Remove the print cartridges, and then reinstall them.
  3. Close the front door.
  4. Turn the printer off and then on.
  5. If the error persists, contact HP Support.
Helpful CLJ 3600 Error Message Tables:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c00047478&prodTypeId=18972&prodSeriesId=501044
Hope this helps helps. Please keep us updated and remember to rate this answer.
Jan 22, 2011 | HP LaserJet 3600n Printer
I have a HP CLJ 4700dn printer which keeps on giving 49.2FCC
That error is a firmware error, you might try again to download and install the update, or try a new memory stick if you have additional memory installed.
Jun 22, 2009 | HP LaserJet 5550DN Printer
51.23 from the printer clj cp3505
51.xy error in color laserjet usually point to the laser scanner. I cannot confirm this for the cp3505 at this time but HP codes are fairly consistent.
In your case the scanners all come in one unit pretty expensive. RM1-6338-000CN
You can try checking cables to the assm. if you want to get that involved and swapping toner. Bad toner can cause strange problems.
Hope this helps
Mar 23, 2009 | HP LaserJet 3600n Printer
HP 3600n Cartridge Memory Tag
Check the latch on the right side of the black cartridge. They have a problem with them breaking. There is a new style available.
Oct 18, 2008 | HP LaserJet 3600n Printer
HP Color Laserjet 2840
Need to order a replacement FUSER it's located in the rear of the printer. If you live in the USA you need 110V if you're in Euro 220V see below for the part number you need to order.
RG5-7602-000
RG5-7603-000
Fuser ***'y, 110V, CLJ 2820/2840
Fuser ***'y, 220V, CLJ 2820/2840
CLJ 2820/2840
Aug 06, 2008 | HP LaserJet 2820 Printer
302 people viewed this question
jasbo
jasbo
