Question about iLO 2600 Television
Ilo tv I was wathing tv and it just died so I replaced the fuse it died again I repeated this a couple times with no luck,the tv was only 5 months old.It's a 32" Ilo.
  • 3 Answers
PUT IT ON THE TRUNK OF YOUR CAR AND DRIVE REALLY FAST. PERMANENT FIX!
Posted on Sep 02, 2007
SOURCE:
I have a 2004 Chevy Cavalier. A couple of months ago, just after starting the car one day, the 'check engine' and 'trac off' lights both came on. I immediately shut off the car, waited approximately 5...
Many cars have the cooling fan on a thermostat or time delay, to allow it to run for a short period of time after the engine turns off, to cool the engine off. You may have just never noticed it before. So I wouldn't worry about that.
Your real problem is the blowing fuses, apparently you have a short somewhere in your wiring. Putting in bigger and bigger fuses is a great way to set fire to your wiring harness. It's possible that the wire is pinched or chafed somewhere, and perhaps when you hit a bump just right, it touches and shorts.
You may have to take this to the Chevy dealer or a GOOD independent shop to have them chase it down. Unless someone out there knows exactly what this is, it could be a tough one to find.
Apr 26, 2011 | Chevrolet Cavalier Cars & Trucks
I need to find remoto for am ilo tv
Best advice; save the $10-$20 on getting a new remote and get a new TV. If you look up iLo High Definition TV Problems, you'll get a whole slew of problems, most occurring within a months-years. However, if your iLo Television suddenly does have problems, contact mds@chimicles.com Matthew D. Schelkopf. He will be building a Class-Action lawsuit against whatever company makes the televisions cause according to another source on this website, three companies make it for Wal-Mart. Good luck with the TV either way; ours died tonight, and that's no joke. : (
Aug 29, 2009 | iLO 3200 32 in. LCD Television
Fuse blows repeatedly
The auto speed control is failed. Keep it manual and see how it does...It will run at full throttle even when no load is running. Then fix the throttle control when able.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Aug 09, 2009 | Generac Guardian Ultra Source 15,000 Watt...
Pioneer SD533HD5 repair, blown STK's or bad power assy?
Go back recheck everything 6amp fuse in middle of power supply board that will blow, also solder everything that looks like poor connection pioneer always has a lot of cold solder jionts.CK all pico fuses they are green,yellow look like resistors but are fuses.
Jun 15, 2009 | Pioneer SD-533HD5 53" Rear Projection HDTV
3 times repaired
It could be the buffer board and sometimes it's best to just replace it. If the repairman has to come out again tell him to replace the board. especially if it is under warranty
Mar 01, 2009 | iLO V27DMBX Television
The tv died
My ilo Does This Every time We Have A Power Outage Did You Reset It????? Unplug The Tv And Hold Down The On Off Power Button For 30 Seconds Then Release And Plug It Back In And Check.
Jan 07, 2009 | iLO 3200 32 in. LCD Television
Plasma TV keeps turning off and blinks 5 times
Bad capacitors on the power board. If they look swollen or enlarged then they are most likely not holding enough charge.
May 17, 2017 | Televison & Video
KDS-R60XBR1 Sony Projection SXRD Power Issue?
how many times does it blink pause then blink again?
Dec 01, 2007 | Sony KP-41T65 41" Rear Projection...
ILO universal remote code
I had the same problem trying to program my satellite remote to work with the ILO tv. I found that the emerson codes DO work. Yes local cable remotes will work as long as you have the code and the brand is getting more popular. The code that worked with both cable companys, Charter and DirecTv was 10171 I believe. You can find it under the Emerson codes. Hope this was helpful.
May 23, 2007 | iLO 3200 32 in. LCD Television
Televison & Video Logo
42 people viewed this question
Top iLO Televison & Video Experts
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
