Question about Toshiba 1360 Black and White Copier
Black streaks appearing on copies
Cleaned drum and rubber roller but streaks still appear
  • 58 Answers
Well there is not to many things thst would cause that problem,try cleaning the corona wires ,all the mirrors,and check the upper fuser roller.
Posted on Dec 04, 2008
Streak in the middle of the copie/print with drum and blade replaced
Please clean the drum charge roller use the izopropilalcool,clean the charge roller cleaning roller,clean use the vacuum cleaner the waste toner (located under transfer assembly 6 screw),activate the ATDC and AIDC sensor configuration.
Jan 08, 2012 | Ricoh Aficio 1035 Copier
Copies come through with a black streak down the length of the paper.
Remove the image unit,change drum cleaning blade,clean the drum.
Nov 10, 2011 | Minolta EP1030/1030F CS/PRO Copier
I have an HP Laserjet 4, quite old, and it has developed a very prominent streak almost straight down the middle of the page. Staples told me to clean the drum, but my manual doesn't even seem to mention...
Put paper in the manual feed tray. That's the pull down door in the front.
Print something. As the page gets fed 3/4 of the way into the printer, open the top cover. Pull out the toner. Look down at the paper. If you see the prominent streak, you probably have a bad toner cartridge. If the streak is not there, check the fuser. One of the rollers is bad.
While you have the toner in your hand, you should see a flap that is the entire length of the cartridge.
Put you thumb on the flap and pull it down. You will now be looking at the drum.
If you see the prominent streak, that's your problem. See if you can clean it with a soft lint free dry cloth. If the streak comes back, the rubber cleaning blade is probably bad. Replace the toner cartridge.
Feb 07, 2011 | HP LaserJet 4 plus Printer
I have black streaks on my 1600n prints. I have tried cleaning the drum, however the streaks still exist.
Dirty print out is basically due to cartridge related issues. Take out the cartridge and clean its drum/ (green roller) with a dry, soft, lint-free cloth. The drum is usually located under a cover. Checkout for any spilled toner inside the printer and clean it also. Print a few pages so that the parts get further cleaned. I think, this would solve the issue.
Moreover, black streaks (thicker lines) and dots etc indicate faulty PCR Roller which is located behind the green drum inside the cartridge. Cartridge or get the PCR Roller changed by a professional.
Let me know if any further clarification is required.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Feb 06, 2011 | Dell 1600n All-In-One Laser Printer
Kyocera Mita 2050 there are streaks of toner appearing on the pages printed.
If you send a print job or print a report from the copier and there is no streaks then the problem is most likely the thin **** glass to the left of the large glass. It just needs to be claened.
If the streaks are happening when printing and copying then the problem is most likely your drum unit (MK-410) or possibly the fixing unit (FU-410), the fixing unit is the one that gets hot.
As the drum gets old it can cause print/copy issues and the cleaning blade that cleans the drum gets to the point it doesn't clean the drum properly causing streaks.
The heat roller has a teflon coating on it and as the roller gets older the teflon starts to come off and can effect prints/copies.
The drum unit should be replaced every 150,000 pages and the fixing unit every 300,000 pages on the KM-2050.
I hope this is helpful,
Shawn
Nov 15, 2010 | Kyocera Mita KM-2050 Printer
My ricoh 3235c copier had image problem, one inch wide streak down the page, so I chaged the developer unit and now it says no toner just replaced the toner too, what now? please help. thank you.
Try cleaning the blade(by rubbing a piece of paper between the drum and the blade) ,also clean the charge roller(black rubber roller) with a soft clean cloth.If all else fails replace the black drum unit(It's life is 60k)
Feb 12, 2010 | Ricoh Office Equipment & Supplies
THERE ARE LARGE STREAKS OF INK ON ALL COPIES AND
The green roller is the drum which has a cleaning blade to remove excess toner, when the drum gets older it becomes clogged and will dump toner back out onto the drum. Just some info on it. Best fix is replace the drum, you could take it apart and attempt to dump and clean it but it's rarely worth doing that.
Jan 04, 2010 | Brother IntelliFAX 4100 Laser Fax
Vertical streaks when printing pictures
vertical lines on prints usually means either the drum's cleaning blade is not cleaning the drum (or the drum is damaged) or the fuser is scored. scored means that the protective coating on the fuser rollers is damaged. I would check the rollers on the fuser (the hot part of the printer right near the paper exit) for any lines on it, if you look at your prints, you should see them in the same location on the fuser. if you do not see any lines on the fuser rollers, then replace the drum.
May 24, 2009 | Dell Office Equipment & Supplies
Dirty copies.
Does this streaking problem occur when printing (not copying)? If it does then you are probably looking at a consumable issue. Alot of times black streaking is caused by a defective or spent drum. Is your drum new? There is also a blue piece on the drum unit used to clean the corona wire that cleans the drum. Have you tried moving it back and forth several times?
If the problem only happens when copying and the streaks are as bad as you make them out to be then you problem have a bad CIS unit (scans your originals for faxing or copying)
Inkworks
866-381-0541
Nov 21, 2008 | Brother IntelliFAX 4100 Laser Fax
Narrow streak down page
Take a look at the drum on you copier by opening up the right door. Do you see a line on the green drum? If so, your drum should be replaced.
Sep 15, 2008 | Sharp AR-153E Copier
Toshiba 1360 Black and White Copier Logo
188 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
