Question about Maytag Neptune MCE8000AY Electric Dryer
Need to clean out lint trap
Model number MCE8000AYQ. Does lint basket remove from the drum for easy cleaning. I have removed the two external screws from the bottom drum and have removed the screws from the sensor but that does not release the basket. Anything else I can do?
    Problem Solver:
  • 8 Answers
No, the lint basket/grid does not remove from front panel. This is what drives me nuts about this dryer......the worst lint catch design on any dryer I've used. I have purchased several vac attachments to get down in there, but every so often I take it apart.
You have to remove the bottom lower front panel of the dryer. It's not extremely difficult, just time consuming. I copied and pasted how to do so below thanks to a poster from another site, as I'm not so good at explaining these things in writing.
" Unplug the dryer. Remove the two screws that connect the front panel to the lint trap housing.
- Open the upper cabinet dryer and unscrew the four screws that span across the rear of the control panel.
- Move the control panel up and be aware that you will have to detach at least one electrical connector to get the panel out of the way (This will allow you to swing the control panel to the left).
- Remove the five srews located across the top of the bottom panel (Previously hidden by the control panel).
- Swing the top of the panel out and gently pull up to remove the bottom of the panel from the brackets.
- Unhook the yellow moisture sensor harness 2 wire electrical connector on the lower right side which will allow you to swing the panel to the left. "
You can download the Service manual online. It has the photo's to show you how. Not sure if this site has it but some other sites do. If you type in the model # + service manual in a search  it should bring up several sites to get it. You may have to pay for it. I ordered one soon after buying the dryer.....you never know when you may need it and being able to order the parts and fix it yourself saves a bundle, especially when it's one small little $5.00 part that could cost $100 or more on a service call. The electrical connections inside the front panel and on the digital console are not difficult to remove at all. I wrote on the inside panels w/ a marker as I removed them the first time I opened it as to how they hook back up. You can also take pics as you go w/ a digital camera if you have one. The 3 plug in connectors on the logic board are 3 different sizes, so they only can go back in one way.
I just got finished putting mine all back together last night.......I had a chewed sensor harness thanks to a chilly tree rat thinking my dryer vent on the roof looked like a toasty place to keep warm.....not realizing he'd fall 20ft straight down w/ nowhere to go but into dryer doing some damage trying to get out.
Anyway, sorry if I wasn't very clear on things, as I said I'm not to good explaining these things in writing, but the service manual is a must.
Good luck and take care, Teresa ; )
Posted on Dec 07, 2008
Is there a lint trap or lint filter on this washer? It is a kenmore washer model# 11022622100. I seem to remember my old washer having one inside the lip of the tub but I can not find one anywhere.
On most 110 mods there was what they called a lint trap at the bottom of the wash basket.You can;t see it without taking the basket out (ya I know dum) you will need special tool to remove basket.that filter has now been replaced by whirlpool with 4 little plugs and the so called filter is removed.You can clean the old one and unit will be fine..for that job I would say to get a pro as it takes me about 2 mins to open and will save you as a home owner a whole lot of headaches..Hope I helped and Thanks for voting
Just a note that whirlpool made that machine.
Mar 17, 2011 | Washing Machines
A lot of lint left on the clothers after load finished. Rinsing twice more only helped a little. My machine is about 12 years old. Don't know model but it's a top-loading with mini-basket.
Have you ever cleaned the lint trap? many people do not realize that washing machines have lint traps too. It is usually located under the fabric softener cup in the agitator -- not sure on yours without model number. It has a lot of tiny holes in it that clog fairly easily. One trick to clean it is to put it down in the drum where the wash goes and run a wash cycle, but you may have to do a bit by hand as well. Hope this helps.
Feb 15, 2011 | GE Washing Machines
I need to figure out how to get the front panel ff of my daughter's kenmore dryer Mod #96093800 to clean the lint from inside. Also the dyer heats up but doesn't get hot. any suggestions
First you have to remove the back and then top of the dryer, then you will have to remove the drum. After the drum is removed you may see screws along both sides on the inner corners of the front. (You may not have to remove the front once drum is out.) Remove these and the front should come off. There is usually lint jammed in the front tube if this dryer has a lint trap under the door, thus causing the heat not to circulate through the dryer.
Feb 21, 2010 | Kenmore Dryers
A PEN WENT DOWN THE LINT TRAP AND NOW THE DRYER WONT TURN ON. KENMORE GAS DRYER
can you move the drum by hand?if not the pen is jammed in the blower wheel stopping the motor from turning,if the filter is on top you'll need to remove the filter,take out the 2 screws in front of the filter now make sure the dryer is on a flex line so you can pull it forward to remove the lint filter and then remove the back panel,now you need to remove the 4 screws holding the duct on that the filter slides into and remove the pen and any lint that's in the duct,if the filter is inside remove the bottom panel,remove the filter and take off the duct and clean it out,next time send model number
Feb 15, 2010 | Kenmore 73952 Gas Dryer
Want to remove the lint basket that the filter
your best bet is to remove the front panel of the dryer and pull the front drum/blower duct assembly off the machine. You can then fully access all areas of the duct and also clean all the lint build up inside your dryer.
Nov 27, 2009 | Cars & Trucks
How to put a belt on a estats dryern tedx640jq
open lint trap door and remove two screws. pull lid toward you and lift up at front edge. on either side of the front door panel there is a 5/16" sheet metal screw. when screws are removed, pull top of door panel out to clear drum and lift. should be able to access drum and idler from there but make sure you unplug dryer first, double check belt for twists, rotate drum back and forth. While your in there you should clean out lint and check rollers.
May 20, 2009 | Estate TEDX640JQ Electric Dryer
Lint filter
Hi Bob... You probably have a buildup of crud in the outer tub itself, or perhaps someone washed a rug and the backin has come off and is all in the outer tub and little by litter it is cloggin up the water pump. I would suggest that you pull the inner basket out of the machine and do a good cleaning of the machine. It's rather easy to remove that inner basket- you only need a phillips screw driver!
1. Pop out the two plastic white caps near the front/top (under the washer lid but on the top of the washer) and remove each screw.
2. Remove the agitator by popping the fabric softener cap out and simply reaching down in the center and unscrewing the white plastic "tee" nut that secures it to the agitator shaft and lift the agitator up and out.
3. Lift the machine's top up (it lifts up just like the lid does)
4. Unsnap the "tub collar" from the washer tub, (requires no tools!)
5. Grab ahold of that entire inner basket and lift it right up and out of the machine. (you may want a helper to hold the machine top back for you)
Now with that basket out, you can see what you need to do as far as any kind of build-up. You can wipe clean the inner plastic tub and remove any lint/rug backing/crud you see, and you can take that basket and clean it up in a laundry tub, of it is warmer where you live, take it outside and spray it down with a garden hose. The underside is probably going to filthy. The outer side of the inner tub is almost like a cheese grater, it might have some lint snagged in the holes. Just spray it down and clean everything up. Put it back together and you're good to go again.
It takes me about 10 minutes tops to pull the inner basket. Fisher Paykel's are very easy to work on.
Feb 21, 2009 | Fisher and Paykel GWL11 Top Load Washer
How do I remove the lint trap holder to clean out the lint inside
The font panel must be removed. This may be done by removing the control console (open upper cabinet doors to find screws behind the console). The screws along the top of the lower front panel are easily accessible. Disconnect the two interlock switches, remove the grounding clip attached to the bulkhead & lift the panel off the two lower clips. Inside the panel is a housing that leads to the exhaust blower. It will be packed with lint that may be hardened like papier mache. Just clean out the mess & reverse the process to replace the parts.
the
Jan 21, 2009 | Maytag Neptune MCE8000AY Electric Dryer
Whirlpool Gold Dryer GEQ9800PW1
take a screwdriver and push it in below the door at the top of the bottom panel, near each end of the panel, there is a springclip to pry on that that releases the panel and it will fold out and then lift off. then you can get access by removing a few screws.
BE SURE TO UNPLUG BEFORE WORKING ON IT.
May 17, 2008 | Whirlpool GEQ9800P Electric Dryer
Maytag Neptune MCE8000AY Electric Dryer Logo
273 people viewed this question
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
