Question about Memorex Karaoke System MKS5620RFB
Karaoke-Press on, screen lights up, cd nor cassette will play
I have a Memorex Karaoke. I press the on button, the lyrics screen lights up, but it will not play a CD disc nor will it play a cassette tape. The on button has a small red light beside it and it does not come on.
The machine just stopped working. What can I do?
  • djbarnes522 May 11, 2010
    You advertise you'd solve my problem for FREE. No, I haven't solved it. I don't see what's wrong. I don't want the plan, just a simple answer as to what could be wrong and if it would possibly cost more to have it repaired than to purchase a new one. Thank you
2 Suggested Answers
SOURCE: I have a Memorex Karaoke machine, Press power
Had same problem opened up back found blown fuse replaced and still blows.
Unhooked power source from were fuse was blown and fuse dose not blow seems to be something in that big board above it.I'm realy not into repairing of electronic boards. There is a lot or stuff going on inside there.
Just thought I would share my experience.
Good luck
Posted on Nov 24, 2009
Getting my aiwa to play cds or cassettes. Bought second hand no instructions .lights up won't play can I get instructions on how to get sound?
You don't state the model, so we are running blind here. It should be fairly obvious. For the CD press the CD button. Then press the door button and put the CD on the tray. Then press play or the door button again. If the CD player works it should play the music. Same with the cassette. Drop the cassette into the holder, push it back in place then press play.
Oct 07, 2017 | Aiwa Audio Players & Recorders
How do I get the lyrics to play on the screen using the karaoke anywhere app? I hear the music but there's no lyrics
The Karaoke Anywhere app will play standard MP3+G zip files. These contain two files. One must be an mp3 file and the other must be the accompanying cdg file. The zip file cannot contain any other files or folders.
It seems from what you describe, the file you are attempting to play through Karaoke Anywhere is an MP3 file but that it either does not have a proper CDG file, or the MP3+G zip file is not in the proper format.
Sep 01, 2014 | Sakar The Voice I Want You CD G Karaoke...
Record button will not push down with play button, to record.
Are you using a new cassette???? Check to see if the tab is missing on top of the tape.....If it is put tape over it
Mar 14, 2012 | Memorex MKS5009 Karaoke System w/CD/CD+G...
I have memorex radio/cd/cassette player model MP3226. The PLAY button on the cassette tape does not stay in the down position when pressed when a tape is in the housing. If I remove the tape, and press...
I can imagine 2 cases for your problem:
Either there is a mechanical problem and something is not allowing the "play mechanism" to go all the way up to the clip position when the cassette is in the housing,
Or the tape isn't rolling up properly. Some of these deck's have some kind of protection and when the tape isn't rolling properly a system stops the play procedure. Check if both of the rollers for the tape are spinning around properly. In case of not spinning, run the cassette fast speed forward and backward in order to come to the proper state. Also check without any cassette is any roller spinning around or not?
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
direct fixya link:
May 15, 2011 | Memorex MP3126 Cassette/CD Boombox
I assume you know that you MUST use special Karaoke disks to have lyrics displayed... Ordinary music CD's do not have that data on them.
Jan 25, 2011 | American Audio Cdg-350 Professional Dual...
When i put a cd in to play, we cant get the words to show on digital screen??
You MUST use a special Karaoke CD disk to show lyrics on the screen. Plain music CD's will play music but NOT display the lyrics. Karaoke disks can be expensive... so shop online for Karaoke CD's. Some music stores, including Costco and other warehouses sell some Karaoke disks, but they are usually in a very small section of the displays.
Dec 27, 2010 | GPX Karaoke Party Machine
I have a Memorex Karaoke machine, Press power button, screen comes on but it will not play a disc nor cassette. There is a small light beside the power button but it does not come on either. What could be...
Good luck
Oct 20, 2009 | Memorex Karaoke System MKS5620RFB
It wont play CDs
the cds you put in there are not compatible to the player.if it had been playing the same cds then it is time to take your set to a tech for repair it can be your memory chip or your lens.good luck.
Apr 18, 2009 | Memorex MKS5009 Karaoke System w/CD/CD+G...
When I press the power button, it will not work at all. It won't play a disc and the screen won't show that it is on either.
Aug 26, 2008 | Memorex Karaoke System MKS5620RFB
Professional new karaoke system skipping and lyric problems
your disc is scrath or maybe the lens of your player is already weak,or have dust,if you can do the job,clean it with a soft cotton..wipe carefully with only one direction..try also the lens cleaner.
Feb 23, 2008 | Memorex MKS5009 Karaoke System w/CD/CD+G...
48 people viewed this question
Top Memorex Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you a Memorex Audio Player and Recorder Expert? Answer questions, earn points and help others
