Question about Kenmore Elite HE4 Electric Dryer
He3 washer letter f shows on dial and then flages the letter g,what does it mean
  • davisjoe Dec 10, 2008
    thank you for trying.
Our mother board had to be replaced. It was replaced twice then we made them take it back.
Posted on Dec 07, 2008
Kenmore elite h3 front load washer is not working error code f2 flashes
The F2 error code mean that the washer didn't drain the water within the normal time it takes to drain,usually the reson the washer hasn't drained properly is because the filter screen on the drain pump is clogged with debris. this tip i have written will show ya how to clean the filter on the pump.
http://www1.fixya.com/support/r10121384-check_when_duet_washer_door_locked_after
GENE
Oct 08, 2011 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
I have a Kenmore Elite Quiet Pack 2, HE3, model number 110.45872 400 front loading washing machine. When I start a cycle it stops and letters H and F alternately show on the screen. What does this mean?
i just had this problem... i did the following (should only take 30 minutes) take the panel off, that is located below the front door,, there are 3 small srews located at the bottom that hold this... then you will see the water pump, the water pump has a access srew plug, when you unscrew this, its like a filter, you may see stuff, like coins, socks, etc, remove and clean it, then put everything back... this should fix the issue.
Oct 11, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
F6????
The F06 error code on the HE3 elite is a tachometer error. Per the tech sheet, it says to check all connections and continuity between the MCU, CCU and Drive Motor. The tech sheet says normal reading is at 6 ohms.
Apr 18, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Zanussi Washer Drier
We had same problem with same model machine - basically you have to ignore the letters behind the see through plastic window and write new ones around the dial with a permanent marker that you know are correct and correspond to what you want. It's a lot of trial and error - try and go for the simple dryer function first and mark write the corresponding letter against the dial straight away, then work out the distance between each letter on the proper dial and and you should replicate these distances and letters with your pen.
Jun 30, 2009 | Zanussi WJS1397W Front Load Washer / Dryer
My kenmore he3 washer is showing an error code f4 what does this mean
The F4 error code on your washer indicates a problem in the electrical circuits of the washer... and not end-user repairable.
This problem requires a technician to test the wiring circuits to diagnose the problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 18, 2009 | Kenmore Elite 45986 Front Load Washer
Help! Mt Kenmore Elite Quietpak2 HE3 keeps
F/06 Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Mar 10, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore HE3 washer emits steady, constant beeeeeeeeeeeeeep
Depending on how your washer controls the beeper, it could be a stuck relay or a fried transistor.
Jan 17, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Elite HE4 Electric Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
