Question about Frigidaire 20.6 cu. ft. / 583 liter Upright Freezer FFU2124D
Frigidaire FFU20F9G (model FFU20F9GW3) temperature light is on
I have had this freezer for 10 years. It worked fine until yesterday. I noticed the temperature alarm light came on (the audible alarm is off but if you turn it to on you hear it very loudly) and that the ice cream in the freezer melted. I turned the temperature up to a setting of 6 (factory set is 4) and put some ice cubes in and they are not melting and all the other food in the freezer still appears frozen. The temperature alarm light is still on and the audible alarm is still going off if I turn it on and that is my question in terms of why is the temperature alarm light still on and do I still have a problem?
The ONE difference that I did see (actually hear) is that when I closed the freezer door in the past I would hear a sucking sound (like a vacuum sealing something). This sound has disappeared. The door is still closing and as far as I can tell the gasket is sealing but I am wondering if this may have something to do with it.
Thanks.
  • ybey Dec 05, 2008
    Hello Pranaclimbin,
    Thanks for your suggestion. I will try this. I also measured the inside temperature of the freezer and it is 27 degrees Fahrenheit which is way hotter than the specification (2 to 8 degrees F) for this freezer. Maybe I do have a leaky gasket. Does this sound like a symptom of a leaky gasket?
    Thanks.
  • bpriddy2 Jan 04, 2009
    The temperature alarm light is on and the items on the top shelves such as ice cream is melting. I have turned the temperature up with no change.
  • 67 Answers
If the gasket is still sealing allaround the door then u shouldnt be losing any cold. try defrosting the freezer cleaning it out and firing it back up.
Posted on Jan 07, 2009
  • 50 Answers
Posted on Dec 05, 2008
Upright frigidaire freezer light flashing 6 degrees pressed super freeze will it reset??? How do I know if super freeze button working??
Check along the back and sides of the freezer for any vent-like openings that are covered or blocked by packages. There may be a sensor that's not getting air flow as it should. Although most upright freezers are now frost free, there still can be ice buildup in critical areas such as the thermal sensor or the fan. Can you tell if the fan is running?
Even if the compressor has failed, your frozen items will keep the temp down for several days. I suggest you move the frozen goods to a neighbor immediately. Meat or fish in particular quickly becomes unsafe to eat without at least refrigeration.
Sep 03, 2016 | Frigidaire Freezers
Pannel off freezer not turn on ?
Thank you for your question, Friend.
It sounds like the temperature control of your Frigidaire freezer (FKFH21F7HW) is possibly in the off position. When this occurs the temperature control turns off the compressor, but does not disconnect the power to the light bulb or other electronics. Let's try reactivating your freezer by pressing the UP arrow until display shows "4" or desired setting. Please allow 24 hours for temperature to stabilize. For future reference you can lock the control to keep from accidently changing the temperature setting.
If this is not the case and your freezer has no power, can you please elaborate prior to your problem any other symptoms? For instance, did notice any error codes, or other strange functions? Also, may I have your model number please? The serial tag, which lists your model number, is normally located inside the cabinet on the left/right side wall. Thank you and I look forward to hearing from you. - Z
Sep 03, 2014 | Frigidaire Freezers
Ffu20f9gw3
If your unit has a defrost timer, and you don't see it at one of the back corners, then it will be hidden behind the front kick plate either on the left or right corners.
Sep 19, 2013 | Frigidaire 20.6 cu. ft. / 583 liter...
I have a Frigidaire upright freezer model# ffu20f9gw3. The temperature alarm light is on. Cold air is blowing but the ice cream melted, and the hot dogs are still frozen and loaves of bread that i...
I have had the same problem with my frigidaire/electrolux upright freezer... I am researching to see if there is a pattern. Once or twice a year for the past few years, the freezer defrosted itself. I found the outside of the unit to be VERY hot to the touch around the time that this occurred.
We typically unplug it for a chunk of time when this happens and then replug it. It has always begun working again.
Sadly, we have lost many groceries and have had to clean many bloody meat messes as a result of this. ANYONE buying this freezer should save their receipt... That way, they can return it or have it repaired when it fails. I hate to think of sending all of these failing monstrosities to the landfill... =(
Aug 13, 2010 | Frigidaire Freezer 20.3 Cu. Ft. Frost Free...
Model Number - LFFU2065DWO. Been working fine until yesterday when we noticed some food thawing. I adjusted the thermostat but it keeps warming up. The fan is operating and the unit still pulls a vaccuum...
yuour compressor is busted the couse the compressor overlooad did trip... couse to shut down your compressor thats why its allways on heater mode..... call an refrigeration tech and replace your compressor and check your power meybe your have encountered an low voltage power breakdown to buned your compressor.
Aug 02, 2010 | Frigidaire Freezers
Not freezing
Check your circulatation fan. It may be stuck. Keep me informed The Raz Shack
Apr 20, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
I have a frigidaire freezer upright model#ffu20f9gw3
Without any additional info, there are a lot of possibilities:
1. Condenser coil (underneath unit) is dirty and clogged.
2. Compressor is failing. (need A/C tech)
3. Metering device is clogged. (need A/C tech)
4. Refrigerant charge is low. (need A/C tech)
5. Door seal is broken (frost will form around door).
6. Defrost heaters are stuck on (replace defrost timer located underneath unit at front).
7. Condenser fan has failed (underneath freezer on back).
8. Evaporator fan (inside fan) has failed (ice will form on cooling coil).
This should get you started...
If this helps you, please select YES to the first two ratings questions. Thank you, and Good Luck.
Oct 13, 2009 | Frigidaire Freezer 20.3 Cu. Ft. Frost Free...
Freezer not working
I have a Kenmore Freezer model # 253.9251310 serial # s510347256
10\95 Makes all kinds of noises and now is defrosting. Sounds like fan is working but no noises besides fan. any ideas
Dec 12, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Several things could cause this. To check most things you will need to remove the back wall of the freezer to see the evaporator. It is possible the freezer is low on gas. If it is the coils will usually appear to be only half frosted or less. It is possible the defrost is bad ( I assume this is a frost free) In this case the coils will be totally clogged with ice and no air can circulate. If so you'll most likely have to replace the bi-metal... a circular looking part about the diameter of a quarter clipped onto the coil with 2 wires leading from it. This may also cause the fan to stop running from ice accumulation...or the fan itself could be bad which would also cause a partial meltdown. Unless the machine needs gas an appliance repair person will probably charge you around 100 bucks for most of these repairs..gassing it of course will be more and there is no guarantee how long the gas will stay in it as most leaks are difficult, if not impossible to locate. Hope that helps !
Dec 06, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Freezer Problem
If it started to cool again the compressor was running. Check the condenser and make sure it is clean. Provide as much air movement through the garage as possible . 100 degrees is a high temperature to be operating a refrigerator in.
Jun 10, 2008 | Frigidaire Freezer 16.7 cu. ft. Upright...
Frigidaire 20.6 cu. ft. / 583 liter Upright Freezer FFU2124D Logo
1,029 people viewed this question
Top Frigidaire Freezers Experts
Electrolux
Electrolux
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
