Question about Hitachi 42HDM12 42 in. Plasma Television
Horizontal line or seam going from bottom to top of screen
There is a horizontal line or seam going from the bottom of the screen to the top about every 10 inches or so and when it hits the top it starts over. Hope you can help. Thanks
  • 38 Answers
The problem of your tv set is in the horizontal section! lost of horizontal voltage.. try to isolate capacitors around it then check it with ohmeter.
Posted on Mar 03, 2007
    President:
  • 1,284 Answers
Sounds like you have AC leakage somewhere. If you have cable TV, disconnect it from the TV and see if the line dissapears. If it does then most likely it is a faulty cable box or a bad ground on the cable system.
Posted on Feb 22, 2007
Screen has horizontal lines and fading
bad screen u have to get new screen take it apart from top side pop off top panel 2 screw on back use flat head unscrew screen get new one one ebay ect ok cheak cables in ther also thx nick
Feb 09, 2008 | Computers & Internet
Two horizontal lines appeared near bottom of screen
You can spend $300 to $500 fixing this or just do the best thing most cost effective thing and replace the TV.
Aug 23, 2016 | Sharp Aquos Televison & Video
My 42 in phillips LCD flat seen has a black horizontal line toward the bottom how can I fix this.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI'm experiencing thin black lines from the top of the screen to the bottom. ... by babes808gpa / January 15, 2010 1:42 AM PST ... lines are about 1/4 inch apart from top to bottom of screen. starts on the right and about a 1/3 of the way toward the ...have the exact same problem, my lcd tv has multiple lines are horizontal it ...
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the ...
? 3:05
https://www.youtube.com/watch?v=KiqJuMiEiak
Jun 8, 2013 - Uploaded by Sameh Moustafa
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the picture SOLVED .... I just have one black line ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Dec 20, 2015 | Televison & Video
2 days ago, a narrow black horizontal line appeared in the middle of the screen.
CNETJun 11, 2015 - I'm experiencing thin black lines from the top of the screen to the bottom. ... my lcd tv has multiple lines are horizontal it starts from the right and fades too the left, ... Samsung LN55a950 - Horizontal lines on right side - Forums - CNET
Jun 11, 2015
Samsung 52" LCD TV black lines - Forums - CNET - CNET.com
Jun 10, 2015
More results from www.cnet.com
Plasma TV Repair Horizontal Lines - How to Diagnose ...
? 2:49
https://www.youtube.com/watch?v=h4XWCxUsSVU
Sep 2, 2014 - Uploaded by ShopJimmy.com
I have thin horizontal black lines on the top and bottom areas of my TV. .... Hi, I have a 2011 64-inch 3D Samsung PN64D8000 Plasma TV.
how to fix horizontal or vertical lines on lcd tv - YouTube
? 4:52
https://www.youtube.com/watch?v=k2QpYJp6MU8
Apr 12, 2014 - Uploaded by cr4zyw3ld3r
Hi my LG 47ln5700 tv set has thin greyish black horizontal lineson one side of the .... I hope this works good with Samsung LCD as well....
Dec 19, 2015 | Samsung HP-R5072 50 in. Plasma HDTV
Why half screen is ok, other half I.e. bottom part horizontal lines are seen.
Your LCD or Control Board is damaged. You can replace the LCD or the Board or have someone do it for you.
Aug 03, 2015 | Sony KLV-32BX300 SERIES BRAVIA LCD...
Wavy horizontal lines across the screen
It sounds that the main power supply section to your TV has the fault. The horizontal thik lines that appears crawling down across the screen should be of video 'HUM'. Have you replaced the main filter capacitor at the power supply section? If not, replace it along with the main rectifier. The AC power is rectifed by a bridge and applied ot this main filter capcitor. It will have a capacitance value between 120 to 350MFD 450VDC. Check this section. Measure the rectifed DC voltage acorss this main filter capacitor. It should be around 350VDC, if your home power supply line is 220VAC. If it is 110AC, this DC voltage will be around 165VDC; and it should be. If rectified DC voltage found lower than the input AC voltage, replace the rectifier bridge. In some sets, this bridge section have four diodes. Some other circuits, a bridge rectifier stalk may be used.
May 20, 2012 | JVC AV-27050 TV
I cannot find the manual for my DPSB3620 GE Profile Dryer. It turns on but nothing moves and I can't seem to be able to open the back
the only panel in the back that can be removed is at the bottom where the vent hose hooks up....the way to get to the belt is. remove the screws where the lint screen pulls out ...pop the top section of the dryer...their are 2 clips in the seam at the top of the dryer ....about 2 inches from the edge use a flash light to see them ...use a screw driver ....go between the horizontal seam at the top to pop ..then their are 4 screws holding the front of the dryer.2 at the top .2 at the bottom ..only loosen bottom screws do not remove them ..then the front of the dryer with the door can be removed ..now you can install the new belt ...remove the lower panel in the back to see motor ...the drum pully //tensioner this is where you put the belt on the pully ..let me know ..if you need more help....good luck../joe
Aug 29, 2010 | GE Dryers
White horizontal, zig-zagging lines
Sounds like the flyback transformer is bad. couple of 100 dollars if it is that
Dec 03, 2007 | Televison & Video
Open Questions:
Hitachi 42HDM12 42 in. Plasma Television Logo
625 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
