Question about Samsung SGH-D900 Cellular Phone
Charger port seems faulty and wont take a charge SGH a 437
What does it mean if the white card small box above the battery position is not solid white but appears a pink sea shell design??
    President:
  • 625 Answers
Umm, that means it was exposed to moisture or is water damaged.
The water dmage may have caused the charg port on you D900 to short out.
If it is the charger port, You have 3 options.
1. get it repaired, warrant if possible
2. Get a new one
3.Get an external battery charger and charge battery separate from phone.Another battery and charger will set you back about 10 dollars on ebay
For more information and links to the parts check the following link below.
Samsung SGH-D900 charging problem repair
Posted on Aug 18, 2009
1100 nokia model charging problem when i put charger into the charging ject charger lite off and batry not charging
First you need to understand that this might have been caused by either the phone or the charger.
To test if it is the charger, test it with another phone to see if it will work, if it does not, then it means the charger is faulty and needs to be replaced.
But if the charger works, then it means the chasrging port of your phone is faulty. To replace it is quite simple, remove the battery cover, the battery and the sim card.
Unkey the hook that are by the two lower end of the phone, they are black and connecting the front cover to the back, then you run a flat object like a credit card or knife around the edge and pull it up from the bottom, the front cover will be easy to pull out now, then you should have some 6 screws around the phone, 2 on top, 2 in the middle and 2 by the lower end, once you remove the screws, you will be able to remove the screen, it is attached to the metal try that protects the keypad. From there, you will be able to also remove the white board, and assess the charging port and replace it with a new one.
After doing this, your phone shoud be in good condittion once again.
Also try out your battery in another phone to ensure the battery is not the problem.
Take care and have a lovely day.
Good luck
Oct 25, 2010 | Nokia 1100
Tip
Why your phone won't charge
<span>Hello,<br /><br />there are three or more reason why your your phone won't charge;<br /><br />1. The charger might be defective.<br />2. The charging port of the phone might be defective.<br />3. The battery cell might be very weak or the battery might be defective.<br /><br />Charger<br /><br />A defective charge can cause a phone not to charge. To actually find out if your charger is defective or not, borrow a charger from a family or friend that has the type of your phone, use the borrowed charger to on your phone. If the the phone charges, then obviously, your charger is defective and need to be replaced. It is also good to test your charger on another phone to confirm the status of the charger.<br /><br />Make sure you run the above test, before buying another charger so that you don't waste your money. Sometimes, charger might be working and phone won't charge due to some other reasons that would be discussed below. So confirm first before buying another charge. Don't buy another charged based on assumptions........<br /><br />Battery<br /><br />A battery that is very flat, I mean a battery that its cell is very weak, won't charge with a phone charger. You might have to leave the battery in the phone with the charge plugged in for some minutes or hours before the battery will begin to charge and other times, it might not charge at all.<br /><br />What make batteries to be in this kind of condition is; <br /><br />1. If you use you phone to the point when it says "low battery" and you still don't charge the battery and the phone turns off by itself. This can run down a battery cell.<br />2. If you leave a battery in the phone idle for a days or months, the battery cell will become weak. Or if you leave a battery used for days or months.<br />3. If you don't use the correct/right charger for your phone, this can drain the battery instead of charging it.<br /><br />Batteries in such condition will have to be fast charged with a desktop charger. The desktop charger will be connected directly to the battery and the battery will definitely pick up within 1 hour. Thereafter, you can continue charging it with your phone charger and it will charge immediately.<br /><br />But if the battery is defective, it won't charge at all. Even if you use a desktop charger. Such batteries needs to be replaced. Also, it is good to test the phone with another battery, and charge it to confirm before buying another battery.<br /><br />Below is a picture of what a desktop charger looks like;<br /><br /><img src="walesarumi_4.jpg" /><img src="walesarumi_3.jpg" /><br /><br />Charging port<br /><br />If non of the above seems to be the reason why your phone won't charger, then it means the charging port is defective. <br /><br />Most times defective charging port confuses people. They think the charger is the reason why their phone won't charge and after using another charger on their phone they still find out that the does still does not charge.<br /><br />Once your phone doesn't charge, the first this you test is the charger and second, the battery. But if the battery and charger seems not to be the cause of the problem, then it is the charging port that is cause the problem.<br /><br />Your charging port might not be defective, maybe it loosed contact with the phone phone or it shifted from it's position. Sometimes, the way we forcefully insert our charger into the phone can make the charging port loose contact.<br /><br />At this point, you will have to disassemble your phone. But if you feel it is a task you cannot perform yourself, then take the phone to a repairman to help you out. But if you feel you can do it yourself (DIY), read further.<br /><br />Turn off the phone. Remove the battery. After that, get a phone screw driver, unscrew all the phone screws, remove the phone cover in order to gain access to the phone panel and get to the charging port. <br /><br />Check if the charging port actually loosed contact. If it didn't loose contact, then you will have to replace the charging port. <br /><br />Note that some charging port are soldered to the phone board and some are not. So if yours is not soldered, simply remove the charging port and make a replacement. But if is soldered, you will be needing a rework station. Rework station is what you will use to remove the charging port.<br /><br />Below is a picture of what the rework station looks like;<br /><br /><img src="walesarumi_5.jpg" /> <img src="walesarumi_6.jpg" /><br /><br />I hope the above makes sense to you.......<br /><br />Good luck.<br /></span>
on Mar 23, 2011 | Cell Phones
My phone wont charge...
Hi
First thing to do is try and find another charger for that phone and see if it solves the problem if it doesnt then you a have something wrong with you battery or soemthing wrong with your charging ports.
You can Clean charging port on the phone with a brush and methilated spirit to remove dirt.
After cleaning it,if still not charging, that means the charging port on the phone is faulty and shoud be replace.
Thanks for contacting FixYa.
Aug 23, 2010 | Samsung Memoir SGH-T929 Cell Phone
Sony ericsson w995 won't charge. On attempting to charge phone says "Battery can not be charged insert a Sony Battery" (the battery is the original battery) once that screen goes it says insert SIM even...
Hello, when a phone does not charge, it means that the phone charger or the port at which the charger is inserted in the phone is faulty.
Might be due to dust or dirt. You can Clean charging port on the phone with a brush and alcohol to remove dirt.
After cleaning it,if still not charging, you can test charger with another phone to be sure if the charger is working. And if charger works with another phone,that means the charging port on the phone is faulty and will need to replaced.
Take care.
Aug 16, 2010 | Sony Ericsson Walkman® W995 Cell Phone
My samsung sgh-e250 has a problem with charging it charges off and on
After cleaning it,if still not charging, you can test charger with another phone to be sure if the charger is working. And ifcharger works with another phone,that means the charging port on the phone is faulty and will need to replaced.
Take care.
Aug 16, 2010 | O2 Samsung SGH-E250 Cellular Phone
My samsung rant wont charge. it charged yesterday but today after plugging it into the charger the Samsung name lights up and then it says "low battery please charge" but it wont charge, i did drop it in...
Phone not charging.
Take care.
Aug 10, 2010 | Cell Phones
I put my charger into the lg cookie charger and it wont charge
hi, try using the charger with another lg phone that it is compactible with to confirm if it will charge..if it worked, it means the charger is fine but if it does not it means the charger is bad...also, it could be that the charging port of the phone is faulty...so if that charger charges another phone, it means you will need to change your charging port.
cheers
Jul 01, 2010 | Lands Phones
Dewalt battery charger won't charge
As you know, solid red on your charger means that the battery is fully charged and the BLINKING red light means the battery is charging. Unless the light is blinking irradically everything is working the way it is supposed to. If the light is blinking irradically, the battery may just be too hot or too cold to charge ( like when you are driving many lags and your battery dies) and in this case simply wait 15 minutes to charge. If you get a fast blinking light still, the problem probably is with the battery.
Oct 07, 2009 | Dewalt DW056 18 Volt Cordless Impact...
Sgh p310 wont charge
Hi!
Please check your charging port if the pins are still OK. Please also try a new charger. Perhaps your charger is already defective.
Have fun!
*Your vote is highly appreciated. Thanks in advance!
Dec 13, 2008 | Samsung SGH-P310 Cellular Phone
Problem charging D 900 and opening sim folder
The charging port on your d900 may be broken.
You have 3 options when the charge port breaks.
2. Get a new one
3.Get an external battery charger and charge battery separate from phone.Another battery and charger will set you back about 10 dollars on ebay2.gif.
Fix for Broken Charge port on Samsung SGH-D900
Jul 14, 2008 | Samsung SGH-D900 Cellular Phone
Samsung SGH-D900 Cellular Phone Logo
94 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
