Question about Mpio FL400 MP3 Player
Hi, i dont have the disc that comes wuth tho mpio. how can i delete files that i recorded on it?
    Genius:
  • 1,061 Answers
MPIO Utility can be used with MPIO player that supports USB Mass Storage.
With this, you can..
- Format and Recover MPIO player
- Upgrade firmware of MPIO flash-type player
- Building playlist of MPIO hdd-type player
* Supported OS : Windows 98 SE, ME, 2000, and XP
* MPIO Utility doesn't work with FL200 and FY300.
* If you are using the latest firmware, be sure to use the latest version of MPIO Utility.
* Please uninstall the old version of MPIO Utility before installation.
[Download] REDOWNLOAD NEW DRIVERS AFTER UNINSTALLING OLD ONE'S RICHARDM69
Posted on Dec 04, 2008
I recently purchased the Toshiba DR570KU DVD recorder. I live and purchased this machine on a small Caribbean Island,and with respect to local people they have no technical knowledge of what they are...
Hi -
I'll try to explain without confusing you any further, but if anything doesn't make sense, please let me know. The instructions on page 79 are contradictory, which doesn't help very much. The upper part of the page suggests you can create extra space on a DVD+RW disc by deleting titles, while the lower part, in the grey box, states you cannot. The bottom part is actually correct.
I'll split this into two sections - blank/unused and used discs then explore a few scenarios.
Blank/unused discs
A DVD+RW is typically 4.7GB and will record approx. 2 hours of video in SP mode or 4 hours inLP mode. If you record more than one programme, they will appear consecutively in the disc editing menu, and shown as numbered blocks in the Title List. The last block shown will always be 'EMPTY', but the actual size of this block can be all or none of the total capacity of the disc.
If you insert a blank DVD+RW disc into the machine and view the title list, you will see this:
Although you can't 'record' to a block labelled EMPTY, this doesn't mean you cannot record to this disc. The blank space on the disc precedes the block labelled as 'EMPTY'.
If you then record one programme of 1 hour duration in SP mode. the title list will look like this:
Once again, although you can't 'record' to the block labelled EMPTY, this doesn't mean this disc is full or that you cannot record anything else on it. The next programme recorder will appear between title 1 and the 'empty' block - as long as there is sufficient space on the disc remaining to record the programme.
If you then record a second programme of 1 hour duration in SP mode. the title list will look like this:
This disc is now full as 2 hours of video has been recorded in SP mode. However, if you'd only recorded 1 hour in total for these 2 programmes, you would still be able to record another hour of video in SP to this disc. The additional programmes would appear between the last numbered title and the 'empty' block - until the disc is full.
The empty block is always present and you cannot 'get rid of it', but it doesn't mean the disc is full or cannot be recorded on.
Hopefully, this goes some way to explaining it, but I still need need to explain what happens with used / full discs when you want to delete programmes and re-record.
There is a maximum length for messages posted on FixYa and I may be getting close to this, so rather than break off in mid-flow, I will continue the explanation for used discs in another message below this one. I will do this right now, but it will probably take me 20 minutes or so to write part 2, so keep checking back. It will be less confusing if you hold any questions until I've written part 2, but I will be happy to answer any after that.
Regards,
BElectric
May 02, 2011 | Toshiba DR570 DVD Recorder
Hi, I can no longer browse through the files of my MPIO MG 100.
ok what charge setting is it on? if its on the MTP setting hold the "MENU" down until a message apears that says "reconnect the mg100 to change the mode" then it should work. if not then i guess i wasnt verry helpful and im sorry
Jun 05, 2009 | Mpio Audio Players & Recorders
How can i delete files wuthout the software?
[Download]DOWNLOAD NEW DRIVERS AFTER UNINSTALLING OLD ONE'S RICHARDM69
Dec 04, 2008 | Mpio FL400 MP3 Player
I need help deleting recorded files or songs from Samsung YP-T10
plug your Yp-t10 with the usb, and then go to the samsung media programme
and from there push the ETC next to the other icons on portable part , and list of files comes up. then press recorded files, press the file u want to delete and that's it
hope this helped
Aug 23, 2008 | Samsung YP-T10 Digital Media Player
Deleting all recordings and some songs
first you go to songs and then go down to recordings, when selecting it you can delete them. also to delete some songs you should hook it up 2 da computer and take it out the music folder.
Jan 28, 2008 | Audio Players & Recorders
Mp3 player repair
Hi
It's called the FPC cable, you can try to connect Mpio America
rma@mpioamerica.com
Sep 24, 2007 | Mpio HD-300 MP3 Player
Mpio fg200
Turn off the unit and connect it to the computer.
The computer should recognize the player.
Run a program called Mpio Utility (Can be found on the CD or Mpio.com)
Select format & Config
That should do the trick.
Or go to www.mympio.com
Feb 01, 2007 | Mpio FG200 MP3 Player
Unable to format
Try this http://www.mympio.com/index.php?topic=15.0
Jan 22, 2007 | Mpio FY500 MP3 Player
Deep trouble with the memory..
ok you have to format by itself. reset the fl400 by the pinhole then when its off press play and menu at the same time for 10 seconds then press and hold the rec or rew button. after the format, run mpio utility press on setup & conf now you havet it like new
Jan 18, 2007 | Mpio FL400 MP3 Player
Mpio FL400 MP3 Player Logo
272 people viewed this question
Top Mpio Audio Players & Recorders Experts
Computer Repairing
Computer Repairing
David Roberts
Level 1 Expert
JonSnell Electronic
JonSnell Electronic
Are you a Mpio Audio Player and Recorder Expert? Answer questions, earn points and help others
