Question about Toshiba TP55G90 55" Rear Projection Television
Toshiba Projection tp55g90 Dead
Hello all, I have a toshiba tp55g90 TAC 9753. This unit was hit by lightning. After the storm it was totally dead. The main fuse on the power board was blown. I replaced it and it is still dead but dosent reblow fuses. I pulled the power conv board and there is a burn/ smoke mark. The power comes to the board and goes directly to the fuse. The one that was blown. After that there are two rectangular holes mayb 1/16 by 1/4 or so. They are spaced close and are between the ac. This is where the burn is. Looks like the lightning arced across this void. The burn isnt bad, it didnt take out any traces. Just put a jagged edge on them. After that there is diagram # d899. This physically like a disk cap or a varistor. It has a schematic diagram symbol of two arrows pointing at either side of a line. this part isnt burnt physically, but is the next part in parallel with the arc path. What do you guys think? I have basic electronic knowledge, but I generally work on tube circuits. When it gets past 1970 it starts to get a little fuzzy on me. Thanks for reading all this and hopefully with a little luck I can get my tv back! Brennan
  • Brennan Duffy Feb 09, 2007
    UPDATE: I forced the relay closed and the filament and high voltage sections came up ok. I have no picture and no sound. When i unplug the set with the contacts bypassed, I get a flash from the three tubes. At this point I assume everything is ok short the tuner and sound board. Maybe power board no supply power to the tuner? Brennan
  • 1694 Answers
SOURCE: toshiba TP61E80 blows fuse
Blows AC fuse on plug-in is a direct short in power supply...
check components with ohmmeter to find short....Check MOV
across AC line by measuring across AC fuse clip.......T.
Posted on Jan 31, 2008
SOURCE: Toshiba 57H81 Flashing Red Power Light, Blown Fused F850+F852
Solved by resoldering some solder joints!!!!!!!
Toshiba Model 57H81 Rear Projection TV - Purchased 11-09-2001
Problem: Toshiba 57H81 Flashing Red Power Light, No Picture/Sound, Blown Fuses F850 + F852
Symptoms January, 2009:
  • Upon turning on set I got flashing red power light and nothing else.
  • Removing plug for one minute and plugging in results in:
    • Audible click, steady red power light for 2 seconds then slow flashing red light
    • Pushing power button results in steady red for about 2 seconds then slow flashing red light, no other set activity
  • Removing power cord for several hours and plugging back in made no change
    • Audible click, steady red for about 2 seconds then slow flashing red light
  • Possible related note: Over past several months occasionally the entire screen would flicker momentarily and at other times be problem free for weeks.
  • Fuses F850 and F852 found blown
Repairs Made:
  • PD0074 DEF/CON Power Board
    • There are two main power supply capacitors in this set. They are C-809 and C-810. One their negative lead on the printed circuit board re-soldered leads and nearby contacts. I’m told that because the factory left out a printed circuit board eyelet, the connection will come loose over time. When I called Toshiba customer service they said there was a known solder joint problem causing blinking red light.
    • Replaced blown fuses F850 and F852.
      • I actually installed a fuse panel on the inside of the cabinet and routed the fuse connections here instead of ordering the special fuses and replacing them on the circuit board.
      • Had to use a 5 Amp SLO-BLOW for F850. Fast blow does not survive power up. Get the red blinking light.
      • Used a fast blow 2 Amp for F852.
  • PD0073 SIGNAL Board
    • Re-soldered Q751 + Q752 STK392-110 Convergence Amps
    • Re-soldered adjacent pads that looks suspicious
Total Cost to Repair about $10
  • Twelve hours of my time over three days to research issue, disassemble set, make repairs, add fuse panel.
  • Already owned Service Manual and Circuit diagrams from a different 2004 repair.
  • Less than ten dollars at Radio Shack for fuses and fuse panel. Already had wires, etc.
  • Some solder. Already owned de-soldering tools, etc.
  • Visited both local authorized Toshiba factory service repair facilities. One said repair would have to include replacing Q751 + Q752 STK392-110 Convergence Amps with ST392-180, and realigning set for a total of $500+ and it would be more if they had to order a power board. NO THANK YOU! Other shop said $65 for site visit and $30 to make an estimate that could be applied to repair.
Posted on Jan 05, 2009
Shuttle83
  • 1139 Answers
SOURCE: Toshiba 42
This is not a bad tube it is a convergence problem. Your convergence amplifiers are malfunctioning, and need to be replaced. If you have a background in electronics, you can remove the back of the TV locate the Convergence ICs (using the schematic or service manual) and the order the parts you will need which are the two convergence ICs and the biasing resistors (you will see these on the schematic). To remove them unsolder the pins, unscrew the screws holding them on the heat sink and remove them carefully, if they stick use a solvent to break down the adhesion of the heat sink paste. Once loose, take them out and then unsolder the biasing resistors and replace them with the ones you ordered along with the ICs.
To install the new ICs put heat sink paste on the back of the ICs and insert the pins into the proper holes in the circuit board. Screw the screws back in securely, and solder the connections back.
After doing this you will need to perform a convergence adjustment, using the cross hair adjustment screen (access this from your TV menu). and the you will need to do an advance adjustment using the crosshatch pattern (also accessed from your TV menu).
Once these are done use you service manual to follow the procedures on locking the adjustments into the TVs memory.
I hope this helps,
Thank you,
Shuttle83,
http://www.electron-age-technologies-llc.com
Posted on Mar 23, 2009
  • 126 Answers
SOURCE: Toshiba TP48C90 Convergence (replaced ICs, worked for 2 days)
Well, my thought is that there are a ton of knock off generic convergence IC's out there that usually hold up as long as yours did. Professionals like me will only use Sanyo original STK's. The counterfeit STK's out there are everywhere. Do some research on the web to locate Sanyo originals, they are out there.
Posted on Jun 11, 2009
Slinteriors
  • 8617 Answers
SOURCE: I have a toshiba tz50v51 projection tv. the red power light is on
It could either be due to the convergence Circuits ( If the Power Indicator Blinks) or the power deflection board if it doesnt blink. I have a source for parts if you would like the link.
Posted on Jun 20, 2009
Toshiba 32c100u dead; power supply board replaced but still nothing
Have you checked whether mains power reaches the power board? Check it first. If yes, the power board you purchased newly should be checked.
Jan 09, 2014 | Toshiba 32C100U 32 in. TV
Completely dead laptop.
sometimes you just need to remove the battery then power-up the unit using its charger.
Jul 05, 2013 | Toshiba satellite c660
Toshiba 57h84 wont stay on
CRT type from the model number
When goes off what do you have: power light on or off?
If it stays on a short time what does the picture look like?
There is a difference between total dead and shuts off after ?
Mar 27, 2012 | Toshiba 57H83 57" Rear Projection HDTV
Totally dead cause hit by a thunder lightning
I would check and ensure the outlet is properly working if it is and the cord is for sure working then the motor that runs the projector got shorted and will need to be replaced.
Dec 01, 2010 | Hitachi 57F500 57" Rear Projection...
My toshiba 42h83 tv is dead. It won't turn on. I
hello if you've never looked inside a tv before then you'll be wasting your time with out the right equipment it will be hard. get quote from an engineer good luck
regards
shaun
Jul 31, 2010 | Toshiba 42H83 42" Rear Projection...
Toshiba 32A33 television screen is part green.
It sounds like it has magnitized sometimes you can unplug it and it will demagnatize when you turn it back on, otherwise you need a demagnitizing coil .
Aug 11, 2009 | Toshiba 32A33 32" TV
Car starts then cuts out immediately
unless the car was grounded lightning should not of hurt it. when you turn the ignition on can you hear the fuel pump?
Jun 22, 2009 | 2000 Volkswagen Beetle
Screen removal
1) Remove lower,front speaker grill
2) Remove screws along bottom edge of screen frame
3) Lift screen assembly off cabinet
4) Lay assembly face down
5) Remove just enough frame screws to get back in position--
    Don't force it----
6) Reassemble.........T.
Oct 28, 2007 | Toshiba TP55G90 55" Rear Projection...
Power light is blinking TV does not turn on
Mosy likly the regulator Ic in the main power supply . Not a consumer replaceable item because of xray and safty issues Call in a shop to assit you in this matter. Good luck
Jun 14, 2006 | Toshiba TP55G90 55" Rear Projection...
Open Questions:
I was given a 2007 Toshiba Regza LED television ( I believe it to be LED just because of the Year 2007.) I have the television plugged into the wall standing alone with nothing connected to it no wires no cable boxes nothing. When I push the power button on the side it goes on because the green light is on the bottom it's not flashing but it is on okay. Now what's happening is I'm not getting any picture and I went on to shop Jimmy's and they recommended that I contact you. The back lights are on as I can see through the slots on the back of the television that there is light coming from there. The thing I'm trying to find out if I did the flashlight cuz I couldn't see any picture whatsoever and I don't know I turn the volume up as much as I possibly could through the side and also with the remote. I change the batteries in the remote of course to see make sure that they were working and I shine a flashlight on the screen I could see no picture whatsoever no menu picture no nothing and no sound. So my question is to you, after following shop Jimmy's recommendations it said that if you have your back lights working but you still have no sound or picture then you would need to replace one of two parts or both. I'm not sure what those parts are called I forget but my main question is how much is it to even get those parts and can I still get them. Like is it really worth doing that or should I just go and buy another television. Mind you to see me was given to me at no cost so that is basically the question would it be worth buying those two parts that they recommended and putting them in one at a time or should I just go get a whole new television remember I'm not which call Rich either so... If you could contact me with an answer that would be great please be specific as I am not what you call text Abby okay? I thank you in advance for your time patience and cooperation and helping me to answer this questions. I look forward to hearing from you! Respectfully, Stephanie Whitman PS can this television only be controlled by the remote. There are buttons on the side but to truly get the best quality of the television I would need to use the remote correct?
Jun 14, 2018 | Toshiba Televison & Video
Televison & Video Logo
62 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
