Question about Kenmore 71832 Top Freezer Refrigerator
Freezer on top - Bongo noise after closing doors
After opening and closing the doors, either one, it sounds like bongo's front under the refrigerator
  • 770 Answers
SOURCE: Kenmore cold spot refrigerator freezer
wow you have power to the unit what about the temp control ? is it turned up?? if so is it closed(calling for cooling?) that is the place to start you can jumper it after yo unplug it to see if you dont have a meter
Posted on Jan 24, 2008
  • 1122 Answers
SOURCE: Kenmore elite refrigerator door leak
your drain in the bottom of freezer is clogged or frozen,use a hanger or if it is frozen use a hair dryer,thanks-mike
Posted on May 31, 2008
  • 19396 Answers
SOURCE: Refrigerator does not cool
If the refrigerator cooling is poor, it may be a problem with the thermostat, the compressor, or the evaporator fan. If ice is accumulating at the back of the fridge, that can also be a reason for poor cooling.
See aso the links below for a more detailed explanation:
It's not cool
Cooling is poor
Posted on Oct 04, 2008
  • 531 Answers
SOURCE: side by side leaks out front door on freezer side
you may have defrost problem
Posted on Apr 07, 2009
  • 4 Answers
try checking the tube that water drains out , it could be plugged with crumbs or old partials of food and causing the problem, This has happened with my fridge at one time , affecting the defrost cycle of the freezer and dripping water out of the door, The tube was located under the crisper in the back of the inside of my fridge, Hope this solves your problem
Posted on Apr 19, 2009
Small truck mazda bongo years 1997
You might try ebay. That said, here are some links to investigate:
Genuine Mazda Parts Shop by Mazda Model
Here are links which include Bongo clubs. You can figure one of them would know where parts are.
Aug 24, 2017 | Mazda Cars & Trucks
I want top to enjin mazda van E1400,but i dont now how to set timing chain mazda bongo E1400 van.single up crank .
great question
an earlier 1400 cc engine with timing chain
1979–1980 1415 cc UC, 70 PS (52 kW)
fitted to some
Second generation bongo Vans (1977–1983)
in the absence of you not making marks or observations
best guess is crank mark is a straight line to top cam mark
other wise old school way
both number one valves closed
number one piston at top compression point
lower harmonic balancer at TDC timing mark
distributor rotor at number one plug lead pick up
top cam should be at its correct timing mark
internet search hopeless today
all i can find online is timing belts for later models
Mar 04, 2017 | Mazda Cars & Trucks
I have a Servis fridge freezer and it's making a clicking noise at the front at the top. Fridge and freezer working but noise annoying . Stops when u open the door. What is causing this.
Does it have a fan? If so fan may activate when the door switch closes. Open the door and hold switch then and check for noise.
Jan 20, 2016 | Refrigerators
Bongo diagnostic
same as any other , very little when putting foot down
Jul 06, 2014 | 1996 Mazda MPV
There are not many auto repair techs that I know of that deal with Bongo watches. I believe you will get better results if you were to post your question under the correct category.
May 02, 2012 | Cars & Trucks
I shut my refrigerator doors and a noise is made in the top back happens...I open the doors and the sound disappears. What should I do
Try to set the level of the fridge. Using a bubble level on top, adjust the front feet up/down to level it. When the doors open, weight is to the front and may help with an internal fan blade position.
Nov 20, 2010 | Samsung RF265AA Bottom Freezer French Door...
Mazda bongo manual
there is a bongo owners site, try them
Feb 07, 2010 | 1994 Mazda MPV
It is making a buzzing noise on freezer side that stops when u open the door but starts again when u close it
On some models of refrigerators, the evaporator fan (behind an access panel at the top of the freezer) shuts off when the door is opened. This fan may be making the buzzing sound.
You should be able to check by pushing in the door switch while holding the door open. The fan should come on; and, if the buzzing resumes, you know what is making the noise. The fan may be developing a problem. If it stops running, the cold air will not be distributed properly between the freezer and refrigerator.
Oct 19, 2009 | Samsung RS2630SH Side by Side Refrigerator
Kenmore - over under
Adjust the feet to raise the front of the frige, which should be higher than the back. Therefore the weight of the door will keep it shut or at least cause it to shut itself if it pops open.
Jul 08, 2008 | Kenmore 62832 / 62834 / 62839 Bottom...
Mazda bongo 2.5 turbo diesel 1996. over heating
no im a mechanic it sounds like that you have an air lock in the cooling system .i am familiar with ford freda and bongo and the design where the engine is is a bit far from the radiator ,so the problem with air locks magnifies.really the solution is just drain the water and refill it slowly while you are pressing and releasing,just repeat the action on the top radiator hose to get rid of any air trapping within the system,it's as simple as that want it to have just water and no air as this will cause a blockage.
Jun 28, 2008 | 1996 Mazda MPV
Kenmore 71832 Top Freezer Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
