Question about Sharp AL-1641CS Laser Digital Copier
Double left line down the side of paper
On every copy we make we either get a very clear double black line down the left side of the paper
  • 1 more comment
  • jdistel Dec 04, 2008
    yes i am sure it is clean - they are 2 very distinct lines
  • jdistel Dec 08, 2008
    Thank you SO much!! I removed the drum and sure enough there was a defect where the lines were - so we ordered a new drum and hopefully that will solve the problem! Thank you again!
  • Scott Yeoman May 11, 2010
    Are you sure the ccd is clean?
  • 56 Answers
Sounds like the drum surface has been damaged by some foreign object.
Typically when you get imaging errors such as lines from top to bottom of a page there is a permanent scratch on the drum surface. Pull the drum unit out of the printer/copier and carefully examine the drum surface, you most likely will see the damage quite easily. The only repair is to replace the drum unit with a new one. HOWEVER... be sure to clean the inside of the machine with a toner vacuum to remove any dirt, debris or paperclips, staples, etc that might have accidentally been introduced into the unit.
Hope this helps you out.
Posted on Dec 07, 2008
  • Keith Deininger
    Keith Deininger Dec 08, 2008
    Glad to know that I was able to solve your copier problem.
    I was Systems and Design Engineer for Kyocera-Mita America for nearly 6 years and a Field Engineer for a consulting firm in Georgia for more than 5 years and have seen this problem all too many times.
    Best of luck, and have a great holiday season!
My panasonic kv-s2026c has a black line running down the left side when I scan my documents. I have cleaned the rollers, used air canister to see if anything is stuck in there. That didn't help
On the CD that came with the scanner is a directory called "Shading Utility". Copy this folder to your PC. Put a blank piece of copy paper into your scanner. Open up the Shading Utility folder and then double-click on the shadingutility.exe. The password is "GOSHADING" without the quotes. This process will take a few minutes but it will re-align the lens in the scanner which has gotten out of alignment through vibration. This is what is causing the vertical black line on the left side of the page.
Jan 13, 2011 | Panasonic KV S2026C Path-Through Scanner
When faxing a paper and the recipient receives the fax, their copy has a wide black lines down the side....if we make a copy, it has wide black lines down the side....we have replaced the drummer we've...
FIRST I would check the scanner glass again you can test it by asking for a report to be tx REPORT.. if this dowsnt have a line on it the problem is either the scanner glass or at worst the scanner unit it self.. I would double check the glass.. get a soft cloth and some glass cleaner on it and give the glass a good rub over. do you have the lines on incoming faxes .. if not the glass or scanner unit is the def area to be looking at, Luck A
Aug 27, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
Marks down left side of copy
There are several things that could be causing this I will TRY to address or suggest on all of them.
1.) If only appears when copying, double check the glass and make sure those areas are cleaned.
2.) If happens at all times, it could be the toner cartridge in the unit (especially if started when just changed). I would try another cartridge (later if you can stand the copies w/ the lines or if you have a spare).
3.) I have seen a lot of these machines do this putting vertical lines down the side of the paper because the fuser assembly has worn out and needs replaced.
I have seen #3 occur sometimes when paper gets jammed in a machine and someone pulls it out too rough, this can cause the slick cover over the fuser to crack, break, or bunch up, needing replaced.
Hope this helps you.
Apr 28, 2010 | HP LaserJet 3330 All-In-One Printer
A Solid black line down the left side of the page
It could be 2 things...
1. Your scanner glass is the doc feeder and clean the glass. probably Wite-Out.
2. A segment of your scanner assembly lamp is burned out. Not good, uneconomical to repair.
Jan 21, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
Black line is present when copying document; not
This sounds as if you have some ink/contamination on the small scaning glass that sits to either the left or right of the main glass on the copier.(Depending on the model/make)As your original is scanned over this thin piece of glass the scanning device will see any spots and this will result in a black line down the page.Please clean the glass with a soft rag.
Oct 12, 2009 | Office Equipment & Supplies
How to photocopy double sided A4 sheets?
you copy first side normaly. then on left side open bypass deck.Put the paper, so that the side on wich you want to print is down. Automatically when you put paper in bypass, the machine ask you wich format is it ( eg. A4 ), confirm with OK, then you need to tell machine wich type of paper ( eg. plain paper ) and OK. then green copy key.
May 02, 2009 | Canon iR 1600 Laser Photo Printer
Canon PC860 - Paper Jam resulted in black horizontal lines in subseq.copies
If the blank ink still cames in the printer means that their still ink inside the cartridge, kindly check if there are papers left inside the printer when it was removed if there is you have to take it off.
Turn off the printer, delete the remaining files that is to printed on the printer dialog box by just double clicking the icon found at the bottom of the task bar.
Turn on the power of the printer, have a printer test to test if the pritned copy is good. Clean the head, or the nozzle of the printer at the maintenance tab.
If the problem still arises means the head align was damage or mess align that happend when the paper was remove forcely.
That's all
Thank you.
Nov 10, 2008 | Canon PC-860 Black and White Copier
Sharp AL-1641CS Laser Digital Copier Logo
107 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
