Question about Kenmore Elite 45986 Front Load Washer
Washing machine won't fill with water
My one year old Kenmore front loading washer won't fill with water. All the hoses are attached and in working order (the water for both hoses is turned on). I also checked the washer connections and the screens on the washer connections where a little dirty, but I cleaned them. The machine "acts" like its ready to wash but when I push "Start" it locks the door and just sits there for a couple of minutes. Then, all the control panel lights turn off and it beeps an error code 1 (1 beep) regularly for about 5 minutes. I haven't seen any problems like this one on the message boards so any help you could give would be greatly appreciated.
  • 247 Answers
Two possibilities here. The cheap, easy, and probably most likely one is a fault with the fill valve. The alternative is something scary with the controls. On the inside of the machine, you will find that the water connection screens you mentioned in your post above are actually the inlet ports to solenoid operated valves. First of all, inspect all the wires that lead to the solenoids on these valves. Unlikely to be the problem, but costs nothing to look. Then, taking each valve in turn: With the power off, connect either a multimeter set to measure AC mains voltage, or a suitable test lamp, across the connections to the solenoid. Turn the power on and set the washer to a part of the cycle where you'd expect the drum to fill. If you see voltage across the solenoid terminals but don't get any water flow, then you need to replace the valve. Do this for each of the valves in turn, turning the power off each time before you disturb your meter/lamp connections. Replacement valves are pretty inexpensive and easy to get hold of. If, at the end of this, you haven't seen volts on any of the valve solenoids, then you're probably into a control problem and you'll need help from someone who knows that particular model of washer better than I do. A.
Posted on Feb 08, 2007
My Kenmore HE2 front load washer when I go to start a load of clothes it's making a humming sound and not filling up with water?
Either one of your water valves isn't working properly, or the lines have sediment restricting the volume of water . What I would do is turn the water to the machine off and remove the water lines and make sure they aren't filled will calcium, etc. and look in the water valves where the hoses connect because that are, which has a screen, may be full of nastiness. If both those are good then the water valve solenoid(s) are stuck and won't open. The humming sound you hear lets you know the rest of the machine is working because the sound is generated by power being applied to the valve by the control.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 21, 2012 | Kenmore 43142 Front Load Washer
Won't fill up with water
If you take the hoses lose from the back the sceens are in the inlet valve body you should see them with the hose off.
Dec 29, 2011 | Kenmore 3.5 cu. ft. Front Load Electric...
Won't fill, no cycling noises
Hello, try to see if there's a good water volume coming through the hoses attached to the washing machine.If there is, check to see if the screens inside the water-inlet valve are clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to). If they're clean, you probably have a defective water-inlet valve. If so, you should completely replace the valve.
Thanks
Jun 04, 2010 | Kenmore 24642 Top Load Washer
What is usually wrong when water will not fill in a new Kenmore elite 800 washer? The spin cycle works but will not fill with water. Washer is only 3 months old.
There's no water at all If there's no water at all, make these checks: Is there water getting to the machine? Is the water-volume selector switch set properly and are the control panel buttons pressed in all the way? If you have a Maytag® washer, is the fuse (if there is one) in the control panel at the lid-switch bracket blown? Is there a faint buzzing or humming noise coming from the water-inlet valve? (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If you can't hear anything, the water-inlet valve may not be getting any power. If you can hear some noise and there's water present, you may need to completely replace the water-inlet valve.
Feb 01, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Error Code: F-20
ck fill hoses be sure they are full on ..ck inlet screens both hoses for trash..both hoses must be attached and on f20 indicates a water fill issue also be sure drain hose is at least 30-36 inches from floor and drain hose fits loosely in standpipe
Oct 24, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Kenmore washer fill problem
make sure you have it on the right settings, or inspect fill hoses cold for clogg
Apr 17, 2008 | Kenmore 44042 Front Load Washer
Washing machine
check pressure switch hose
Jan 02, 2008 | KitchenAid KAWS850L Top Load Washer
Washing machine
it has a little semi clear or black 1/4 of inch, long hose behind the control panel , who its attached one side to the level pressure switch and the other side to the tub. culd be only this three options clogged ,bented or unnatached this hose to one of the sides tub or switch easy fix
Jun 10, 2007 | Kenmore 20172 Top Load Washer
Kenmore Elite 45986 Front Load Washer Logo
93 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
