Question about Fujitsu Siemens LifeBook S7020 Notebook
The wireless isnt working
Hi
I have noticed in the device manager that the infra red port has a yellow exclamation mark against it
I am not sure if i should just uninstall this and install again - and not sure where from either
as a result the wirelss isnt picking up any signal - i am able to get online via the cable
Connect via wireless router, but when i click on internet explorer it says internet explorer cannot display webpage
this could be a driver problem or it might be firewalled
you will have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled or you could click start control panel administration tools computer management device manager look for network adapters + expand Ethernet driver if you see a yellow question exclamation mark or a red X you will need to update/reinstall the driver for the device if you computer came with a motherboard disk the driver could be on it
also
the drivers might be installed for this device
click start control panel administration tools computer management device manager scroll through all of your devices if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver if you computer came with a motherboard disk the drivers could be on it
hope this helps
Sep 18, 2011 | Computers & Internet
Font panal usb not recognise
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
hope this helps you
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
hope this helps you
Sep 16, 2011 | Mercury KVM266PM-U (KVM266PMUD1600)...
I have the Targus amb04us wireless mouse. The mouse lights up when I turn it on, but my computer isnt showing a connection. Plus, the connector in the USB port isn't lighting up.
make sure the battery is good (has full charge)also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
if you need more help with this post a reply
hope this helps you
Aug 30, 2011 | Computers & Internet
Cant read the drive
hope this helps you
hope this helps you
Aug 28, 2011 | Memorex Mega TravelDrive 4 GB USB Hard...
Problemas con puertos USB no estan instalados
if you are having problems with your usb devices or any other devices
hope this helps
Aug 21, 2011 | Computers & Internet
Usb problems
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question exclamation mark? ! or a red X you will need to update/reinstall drivers
hope this helps
Aug 20, 2011 | EliteGroup P4VMM2 V8.1 Motherboard
Usb ports for 6via5t motherboard not work Grazie comunque!
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question mark?
hope this helps
Jun 14, 2011 | Chaintech 6VIA5T Motherboard
Unrecognize usb port
hope this helps
May 27, 2011 | Computers & Internet
Hi, i am currently am in posession of a hp tx2508ca tablet, and my built-in hp webcam isn't working. I have also noticed that i have an unknown device in my device manager under usb devices that says...
click start control panel view devices and printers you should see your webcam from there
if you are have trouble with your webcam
click start control panel administrive tools ,computer management ,device manager scroll down image devices you could see a yellow question mark?
right click to reinstall drivers or update driver hope this helps
May 25, 2011 | Computers & Internet
Neither the Acer supplied wireless mouse or wireless keyboard work with my new Acer Aspire M3300 PC. I inserted the supplied batteries the correct way round and the blue led come on for a few seconds,...
make sure you have the right keyboard and mouse selected
this will depend on which operating system you have
click start control panel view devices and printers you should see your mouse and keyboard right click on either select properties then hardware make sure you have the correct one selected in W 7
make sure you have the right mouse selected click start control panel mouse hardware you will see which mouse is selected
this will apply to keyboard to in XP
make sure the battery is good ((has full charge))also you might test the usb device for the mouse is inserted correctly into the usb port ((if applicable))
click start control panel administrive tools computer management device manager scroll to mice and other pointing devices you might see a yellow exclamation mark ! or question mark ? or a red x
right click you will need to update the driver
hope this helps you
Aug 30, 2010 | Computers & Internet
Fujitsu Siemens LifeBook S7020 Notebook Logo
283 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Marcin
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
