Question about Motorola Talkabout T5720 (7 Channels) 2-Way Radio
Staying keyed up after button release
The unit seems to stay keyed up after pushing the button and then releasing. When powered up, the unit will receive normally, but once it is keyed up and then released, it continues to transmit, but no more voice audio can be heard and the unit is unable to receive until power cycled. The light also stays on after the button is released and the other radio still hears the slight static associated with the faulty radio transmitting but voice can no longer be transmitted after release.
  • 123 Answers
I have never seen this problem before, check if the VOX is activated, this could cause to transmit the radio, but the voice must be transmited. check if the Accesory connector is not dirty, clogged or damaged
Posted on Feb 08, 2007
SOURCE:
Starter staying engaged and running with key off
This is usually due to one of two things:
  1. The solenoid spring in the starter is broken, not retracting the starter gear when the key is released.
  2. The starter gear is binding in the flywheel (flex plate) and not releasing after releasing the key.
Jul 23, 2015 | Cars & Trucks
My msntv2 won't power up. A green screen comes up and says refer to error code #131.
I got the same problem a few days ago error#131 on my msntv2 unit. Tech support at msn said to start with the power on ---then push and hold (alt) and push power and release both at the same time and the power should shut off.--- Then push and release Power and Immediately push and hold down (alt.)---Then a Orange light should come on---Then release the (alt) key--- then enter 5532 5532. If that does'nt work then try starting with the power off---Then push the OK button 3 times then push 5532 5532. Mine didnt work so I dont know what happens after that. Good luck
Apr 30, 2012 | RCA MSN TV 2 Digital Media Streamer...
Oxc18a001
1. Get the unit into the ?Support Menu? by following the steps below. A. - Press and hold the ?*? key. B. - Press the ?#? key and release both keys. Display should say ?Enter Special Key Combo? C. - Press and release in sequence the ?1?, ?2? and ?3? buttons. 1. Press and release the right arrow button until the display says ?System Configuration Menu?. (on C8100 use Touch Screen) 2. Press and release the ?OK? button. 3. Display should say ?Hardware failure status?. If not there already, Arrow Key over to ?Hardware failure status?, 4. Press and release the ?OK? button. 5. Display should say ?Hardware failure status: Clear. Press OK to clear?. 6. Press and release the ?OK? Button. Message changes to ?Hardware failure status Cleared. Press Cancel to continue?. 7. Press and release the ?CANCEL? button as many times as necessary, so that, either the ?Welcome to Photosmart Express? screen appears, or, the ?Ink System Failure? screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE. 8. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet. 9. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer 10. Turn the unit on. The printer may display message ?USE POWER BUTTON TO SHUTDOWN THE PRINTER? followed by ?PRESS OK TO CONTINUE?. Press OK.
May 27, 2010 | HP Photosmart C6180 All-In-One InkJet...
The door latch button doesn't release the latch to open the door. It just goes all the way back when you push it, as if the mechanism is broken.
hi, if the door release latch is eaven from both sides and it is pivoting in and out with out staying in, i would suspect of the interlock switch assembly(this goes to a mmc5000 m.w. oven).00078674.jpg
but if it's not eaven or staying in then door latch or door actuator are suspect.00291855.jpg 00018565.jpg all these parts go to a mmc5000 but i am using it as examples, if you have the model number for yours try repairclinic.com and you can get prices for what ever you are going to need for the repair.
Jan 18, 2010 | Maytag MMC5000 Microwave Oven
URC-22B doesn't work with my BEKO tv.
Check with this method. Manually turn on your tv.
Then push and hold the code saerch button until the light stays lighted release the button.
Push and release the device button you want to set TV.
Now you got to push and release the ON/OFF button until your device turn off when your device turn off stop and push and release the enter button for storage the code.
Warning: You may push and release the ON/ OFF button for almost 200 times.
Good luck.
Jun 12, 2009 | Televison & Video
My car will start but the gear wont come out of park
Sounds like a bad brake switch. It has a shift interlock system that requires power from the brake switch to move the shifter.
Mar 02, 2009 | 1998 Ford Escort
Moving maxi cosi to another car
I assume that you mean the Maxi Cosi Priorifix?
At the top of the leg (that extends to the floor of your car) there is a button (which, if connected to the Isofix points will be red) push this button in as far as it will go and the seat will release from the Isofix points.
I hope this helps.
Jan 25, 2009 | Maxi-Cosi Priori
MagicSing EG-18000 TV picture
i believed the problem is the TV mode. (NTSC or PAL mode)
try this
turn mic OFF
press and hold 8 then press power buton (PAL to NTSC)
or
turn mic OFF
press ang hold 9 then press power button (PAL to NTSC)
customerservice@magicmic.com
Sep 05, 2008 | Magic Sing Along Consumer Microphone
Lost codes
Try this turn on your tv manually,Then on the control remote push and hold the code search button until the indicator light stays lit,release the code search button now push and release the device button TV and next you gotta push and release the power button until the TV turns off ( you might do this per about 150 times be patience) when the tv turns off you push and release the Enter button and the code be saved.
Good luck.
May 10, 2008 | RCA Universal Remote Control
Motorola Talkabout T5720 (7 Channels) 2-Way Radio Logo
330 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Damen Wong
Damen Wong
Gene Pitts
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
