Question about SanDisk Sansa m240 MP3 Player
When I turn on my Sansa 240m it will only load to the point where it says the products name, model, and size. I can use it at all and I can't get it to connect to the computer
  • gg_hellokitt May 06, 2009
    mine just wont startup all the way til you see the brand name and thats all it stays stuck in that position..=/
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out:
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Dec 10, 2008
My name is raza. i have west point washing machine model no 1225tl , Fix error LE is coming. please tell me about this urgent.
An LE error code on the washer's display indicates that the motor is locked, possibly due to a heavy wash load.
Large and heavy sized loads will put a strain on the motor, causing the LE code to occur. Performing a reset on the washer will normally resolve this error.
To reset the washing machine:
  1. Press POWER to turn the washer off
  2. Unplug the washer from the power outlet. If the outlet cannot be reached, turn the circuit breaker to the unit off.
  3. With the power disabled to the washer, press and hold the START/PAUSE button for 5 seconds.
  4. Plug the washer back in, or turn the circuit breaker back on.
The washer should now be reset and the LE code cleared. If washing a heavy or large load, reduce the load size and attempt to restart the cycle.
Note: For your safety and to preserve your warranty, if the issue persists, LG recommends that all repairs are performed by an Authorized Service Center.
Jan 06, 2017 | Washing Machines
The MSM 422 Access Point is not booting up, just restarting all the time. This is the error message: CPU: Motorola PowerPC 8241/8245 Version: 5.4 BSP version: 1.3 Bootcode version: 3.0.6 Creation...
I think you need to get the latest firmware and load it. You should be able to stop the bootup as soon as you power it on.
HP Support can be reached at 1-866-my-procurve. Their support group should be able to help out.
Sep 28, 2010 | HP ProCurve MSM422 WW (J9359A) Pre-802.11n...
How do i reset my sansa e270
Press and hold the "Power/Menu" button for 15 seconds to reset it back to its original factory default settings.
Sep 24, 2009 | SanDisk Sansa e270 MP3 Player
I have sansa sandisk e 260. last time, after charging it in my computer, i plug it out without having safety mode in the computer. After then i can not open my disk. when i try to turn on pressing on Menu...
1. Download the Sansa firmware.
2. Turn the player off.
3. On the top of the player is a Hold switch located.
Move it to the right so you see "Orange".
4. On the left hand side of the player is a Record button.
Press and hold the record button while connecting the player to the computer.
Continue holding the Record button until you see a new icon under "My Computer": named "16MB FORMAT".
Once you see that icon release the Record button.
5. Drag and drop the download firmware files to your player (16MB FORMAT).
6. Disconnect the player from USB cable.
Several things will be displayed.
When you see Key Lock, System Shutdown, move the Hold switch on the top back to the left.
Otherwise download the Sansa Updater and start follow the points 2-4 and start the Sansa Updater.
After updating the firmware follow point 6.
Jun 08, 2009 | SanDisk Sansa e260 MP3 Player
Sandisk 240m mp3 not playing
the radio and mp3 uses one audio amplifier, check if you have loaded your music with mp3 songs, if not load with mp3 songs. if songs used to play and just stopped playing, then follow these steps,
i does your display show song playing, if it does then your set is fault, and if it doent and display unsuppoted, load with mp3 songs.
ii if it was playing and just stopped, than take it to a tech, who can open it and check the change-over switch, or selector of that set.
iii the problem is to very big.
Mar 30, 2009 | SanDisk Sansa m240 MP3 Player
Sansa e200 load main image failed
i'm thinking that it has too much info on it, so it ets stuck when you turn it on.
Jul 31, 2008 | SanDisk Sansa e260 MP3 Player
Sansa sandisk
Feb 21, 2008 | SanDisk Sansa e250 MP3 Player
Won't turn on all the way or connect with computer
this is so ridicious i have the same exact problem i really want my mp3 player back!!!!!!!!!!
Feb 03, 2008 | SanDisk Sansa m240 MP3 Player
Its not plug and playing Sandisk 240m 1g
Hi blackmajik, I just got a Sandisk m250. Windows wouldn't recognize it either until I updated my Windows Media Player to version 11. Now XP sees it just fine and the MP3 player syncs with WMP and accepts and plays music!
Jun 07, 2007 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa m240 MP3 Player Logo
135 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
