I want to set up my fax on my printer to fax in and out
  • Betty Wood
    Betty Wood May 11, 2010
    Do you have the drivers for your fax? Is it already hooked up to the computer and just not working? Need more info
  • 60 Answers
Hi does your printer have an phone sockket on it cable need, fax software and installation -setup fax
most printer will need seting up on pc you can fax from pc with a rj11 on it
Posted on Dec 05, 2008
Send & reseive fax
Set Fax system and adjust your Fax address .
Set Local fax code with fax number.
Apr 27, 2016 | Canon imageCLASS MF216n Black-and-White...
How do I access system settings to change the baud rate and turn off ECM.Thanks in advance.
Fax settings for VoIP ' How to lower the Baud Rate ' Faxing ...
www.voipmechanic.com/voip-fax-settings-9600-baud.htm
How to Lower the BAUD rate to 9600 on fax machines for better VoIP faxing success.
Faxing over VoIP, the correct configuration settings that you ...
www.voipmechanic.com/faxingissuesandotherdevices.htm
How to fax over VoIP and the settings and configurations, like BAUD rate that you need to set.
Dell VoIP Fax Settings, how to lower the BAUD rate and ...
www.voipmechanic.com/voip-fax-settings-dell.htm
VoIP Fax settings for Dell printer/fax machines/multi-purpose machines.Missing: kyocera
Faxing over VoIP - Sfax
Dec 15, 2015 | Kyocera FS-1128MFP FS-1128MFP...
Dell V715w wont receive faxes
To receive a fax automatically:
  1. On the printer control panel, press the Setup setup_icon%281%29.jpg button, then use the menu to select Fax Setup, Ringing and Answering, and then Auto Answer.
  2. Select On and then press OK to save the settings.
  3. Select Pick Up On and set the number of rings, then press OK to save the settings.
To receive a fax manually:
  2. Select Off and then press OK to save the settings.
  3. When the telephone rings and you hear fax tones when you pick up the handset, press the Start button on the printer or *9* on the telephone attached to the printer.
Oct 25, 2011 | Dell All-in-One Multifunctional (v715w)...
How can I cancel incoming fax on lexmar x646e
If the printer is connected to a network, get the IP address of the printer and access printers web interface. You may print a network settings page to get the IP address of your printer. Open a web browser and type the IP address on the address bar.
On the left side, click on the configuration menu and click on fax settings and select fax setup. Under fax receive settings, please uncheck enable fax receive.
You may also do this using the printer's operator panel. Just press on Menu button and select settings. Select fax settings and analog fax set up. Select fax receive settings and turn off enable fax receive then press submit.
Jun 20, 2011 | Lexmark X646e All-In-One Laser Printer
What setting to receive fax
You don't have to manually set the printer to receive faxes. Your printer will automatically receive a fax when it recognizes a fax tone/signal/transmission. Just as long as the fax settings are correctly configured and the printer is connected to a working phone/fax line.
Apr 12, 2011 | Lexmark X6575 All-In-One InkJet Printer
Which port to use for fax???? sonyajohnsonrn@yahoo.com
Followup the steps to setup the printer to send/receive fax.
Connect the phone line ( wire ) to Line 1 Ext at the back of printer port.
The connection is from the Phone socket to printer.
Press the Auto-Answer button on the front panel of the printer to enable automatic fax receiving.
If your no. of rings on voice mail or Answering machine is 4, you need to set 6 Rings to Answer on printer to receive the fax or else the printer will start accepting all the voice mail calls.
Press the Setup button on printer front panel
Scroll till you find Basic Fax settings Or Advanced Fax settings - Press OK
Choose the option Rings to Answer - Press OK
Set the No. of rings. - Press OK
Your printer is ready to send/receive Fax.
* Please rate this solution with Thumbs up and comment to help us improve providing support
Dec 02, 2010 | HP Photosmart C7280 Laser Printer
HOW DO I GET MY FAXES OUT OF THE MEMORY?
Receiving a fax
Receiving a fax automatically
1 Make sure the printer is on and is connected to a working phone line.
2 Make sure that Auto Answer is on.
To check if Auto Answer is on:
a From the printer control panel, press (tool icon).
b Press the arrow buttons until Fax Setup appears, and then press ok.
c Press the arrow buttons until Ringing and Answering appears, and then press ok.
d Press again.
Check to see if Auto Answer is set to On.
e If Auto Answer is not set to on, press the arrow buttons until On appears, and then press to save the setting.
3 Set the number of times the telephone rings before the printer automatically receives faxes:
a Press the arrow buttons until Pick-up On appears, and then press ok.
b Press the arrow buttons until the setting that you want appears, and then press to save the setting.
When the number of rings you set is detected, the printer automatically receives the incoming fax.
Receiving a fax manually
1 Make sure the printer is on and is connected to a working telephone line.
2 Make sure that Auto Answer is off.
3 To receive the fax, press (green botton) or press * 9 * on the telephone after you answer it and hear fax tones.
4 Hang up the telephone.
The printer receives the fax.
Receiving a fax with an answering machine
1 Make sure that Auto Answer is on.
2 Make sure you have set the number of times the telephone rings before receiving a fax automatically.
When a telephone ring is detected, the answering machine picks up the call.
• If the printer detects a fax, it receives the fax and disconnects the answering machine.
• If the printer does not detect a fax, the answering machine receives the call.
3 Set the answering machine to answer incoming calls before the printer does.
For example, if you set the answering machine to answer calls after three rings, set the printer to answer calls
after five rings.
Forwarding faxes
Use the fax-forwarding feature if you are going to be away, but still want to receive your faxes. There are three
fax-forwarding values or settings:
• Off—(Default)
• Forward—The printer sends the fax to the designated fax number.
• Print & Forward—The printer prints the fax and then sends it to the designated fax number.
2 Press the arrow buttons until Fax Setup appears, and then press ok.
3 Press the arrow buttons until Ringing and Answering appears, and then press ok.
4 Press the arrow buttons until Fax Forward appears, and then press ok.
5 Press the arrow buttons until Forward or Print & Forward appears, and then press ok.
6 Enter the number to which you want to forward the fax, and then press ok.
Aug 12, 2010 | Lexmark X5650 ALL-IN-ONE PRINTER
How can we use the printer while the fax is on? how to set up fax while printer is being used?
What do you mean, "... while the Fax is on."? You can set the fax so it will automatically receive a fax, but while a fax is being processed (send or receive) you will not be able to use the printer for anything else. You can set up lots of things about the fax, but if you are printing the printer is pretty well busy doing that.
Nov 12, 2009 | HP OfficeJet 4255 All-In-One InkJet...
Fax procedure in laserjet 3050 model
Press the Menu button and there is option to set-up select that option and there is another option call fax set-up there will be three option.
Fax recieve set-up , Fax send set-up and all faxes set-up from these three options you can set-up fax on your printer.
Thanks and Regards
Nov 26, 2008 | HP LaserJet 3050 All-In-One Printer
Not receiving any faxes but sending
Note: check your equipment for:
Fax machine must be connected to an answer machine
Receiving a fax automatically:
1 Make sure the Fax Auto Answer light is on.
2 To set the number of telephone rings before the printer automatically receives faxes,
2 Set the answering machine to answer incoming calls before the printer does.
after five rings.
3 To set the number of telephone rings before the printer automatically receives faxes.
Oct 31, 2008 | Lexmark X5470 All-In-One InkJet Printer
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
