Question about Samsung TX-R2035 TV
How to manually adjust the centering of the picture
The old TV's had adjustment features on the back to center the screen image. My new Samsung out of warranty is having a problem with the picture being centered properly. Anyone know anyway I can adjust it by myself?
  • Anonymous Apr 01, 2014
    Screen adjustment
    President:
  • 1,284 Answers
On newer televisions the centering adjustment is only in the service menu. I wouldn't suggest anyone accessing it unless you understand all of the abbriviated alignments.
Posted on Feb 22, 2007
SOURCE:
New purchase. VGA connection. First use, all was fine. Turned off, then back on, and image will not "center." Neither VGA Automatic nor the individual controls will adjust the horizontal enough...
Make sure you have your resolution set to 1680 x 1050 as this is the native supported screen size for this LCD. Also check your graphic card's overscan or manual adjustment settings. They might be manually set to offset the screen picture.
Hope this helps,
Chris
Jun 29, 2011 | Westinghouse 22" Widescreen LCD Flat Panel...
Tv out of foucs
These procedures are from the owners manual, go into menu and then picture quality and then: Convergence The Convergence feature lets you adjust the TV’s three tubes. When the TV tubes’ images are precisely aligned, they create the color images you see on the screen. Over time, the picture can drift out of alignment (this is normal). If your picture seems fuzzy or has a yellow tint, using Convergence could correct this misalignment. Only one convergence is needed for all inputs, regardless of the signal format. Note: Make sure the TV has been on for at least 30 minutes (TV needs to warm up for best results) before starting Auto Converge or Red/Blue Centering. When you select the Convergence feature, a submenu appears with three options: Auto Converge Automatically aligns the projection lenses to self-correct color images. You’ll see flashing squares of color dance across the screen (this is normal). Note: After performing auto convergence, use the Blue Centering and Red Centering menus to fine tune convergence in the center of the screen, if necessary. Blue Centering Aligns the blue and green images to fine-tune the picture. Red Centering Aligns the red and green images to fine-tune the picture. Note: The ability to change channels is disabled when adjusting the convergence options. The TV must be tuned to a usable signal to converge the picture.
Apr 23, 2010 | RCA HD52W58 52" TV
Picture is distorted from center on my 65
You do have a failure in the convergence circuit of your set. If you are good at soldering you can replace the IC's yourself. They are on the large circuit board on the left side of the set looking from the back, and attached to a large aluminum heat sink. If you don't feel comfortable doing that, I reccomend removing the board and sending it to PTS corp in Indiana. They are pretty reasonable repairing boards, and a lot less than buying a new one.
May 31, 2009 | Sony Grand WEGA KDP-65WS550 65" Rear...
Picture is distorted from center on my 65" Sony projection TV.
hi. this will be an easy fix for you if you are a good solder. you will need to replace the convergence chip that is located on the PC board(main). this chip is damaged and it has failed due to this damage that has occurred. click below for your new convergence chip(stk).
CLICK HERE
May 21, 2009 | Sony Grand WEGA KDP-65WS550 65" Rear...
Viewing mode will only go from zoom to wide!!!! please help
Hi!
Found some relevant info on how to adjust your video settings... You might want to give it a try!
Thanks! =)
4.12 PC Input Picture Adjustment
The Picture Adjust menu operates in the same
way for the PC Input as for the DTV / TV input in
section 4.2 for Backlight, Contrast, Brightness and
Color Temperature.
4.12.1 Auto Adjust
When the MENU button is pressed, the On Screen
Display (OSD) appears on the PICTURE ADJUST
page. Press the button to highlight the Auto
Adjust selection.
Press the button for the LCD HDTV to adjust to
the PC signal timing automatically.
4.12.2 H-SIZE
Press the button to highlight the H-Size selection.
Press the button to start adjusting the horizontal size of the picture. Use the or button to adjust
the horizontal size.
4.12.3 Horizontal Shift
Press the button to highlight the Horizontal Shift selection.
Press the button to start adjusting the horizontal position of the picture. Use the or button to
adjust the horizontal position.
4.12.4 Vertical Shift
Press the button to highlight the Vertical Shift selection.
Press the button to start adjusting the vertical position of the picture. Use the or button to adjust
the vertical position.
4.12.5 Fine Tune
Press the button to highlight the Fine Tune selection.
Press the button to start tuning the to the PC signal. Use the or button to adjust the tuning
4.14.1 Understanding Viewing Features
Your LCD HDTV features four viewing modes and Picture-In-Picture (PIP)/Picture-by-Picture (POP) mode.
You can switch viewing modes using the remote control.
4.14.2 Viewing Modes
Normal Mode
The original 4:3 aspect ratio (1.33:1 source) is preserved, so black bars are
added to the left and right of the display image. Standard TV broadcasts are
displayed with a 4:3 Aspect Ratio. Movies in 4:3 Aspect Ratio may be referred
to as pan-and-scan or full frame. These movies were originally filmed in 16:9
(widescreen), and then modified to fit a traditional TV screen (4:3).
Wide Mode
When watching a standard broadcast or full-frame movie in this mode,
the display image is stretched proportionately to fill the TV screen.
When watching a widescreen (1.78:1 source) program or movie, the
display image fills the TV screen. If you are watching a widescreen
(1.85:1 or 2.35:1 source) program or movie, there will still be black
bars at the top and bottom.
Zoom Mode
When watching a widescreen (1.78:1, 1.85:1, or 2.35:1 source)
program or movie, the display image is zoomed proportionally to fill the
width of the screen. The top and bottom are cut off to remove most of
the source material’s black bars. This mode is good for programs or
movies with sub-titles.
Panoramic Mode
When watching a standard broadcast or full frame movie in this mode,
the 4:3 Aspect Ratio (1.33:1 source) display image is stretched
horizontally on the left and right sides to fill the TV screen. The center
of the image is not stretched.
Note: Viewing modes are saved based on input. For example, you lasted watched a DVD in widescreen
mode and then watched TV in standard mode. When you switch back to DVD input, the viewing mode
will return to widescreen.
Jan 04, 2009 | Televison & Video
Tv repair
what's that model number?
May 20, 2008 | Televison & Video
52 in rca projection 2006 cutting of the top of heads of people
There are manual settings on most projection tv's to adjust the size and to bring the picture down so it is centered on the screen better. Try adjusting the three colors mentioned below first. All projection tv's are pretty similar. If you need to adjust the picture manually, which you should not have to, there are manual knobs behind the front of the tv or at the rear. They should be marked for thier function.
Here is how to adjust the convergence one color at a time.You should be able to get to the convergence screen with your remote. You need to go into the setup screen and read what is on the menu there. It should say how to adjust when you get there.
Convergence- The Auto convergence feature automatically adjusts the TV’s tubes
(this may take several minutes, after which you can make fine adjustments to the
convergence settings); Red convergence displays the Red convergence screen,
allowing you to use the arrow buttons to align the red and green images; Blue
convergence displays the Blue convergence screen, allowing you to use the arrow
buttons to align the blue and green images.
Also this is in the manual for a generic projection tv.
Call 1-877-RCA-HDTV and have your unit’s date of purchase and model/serial number ready.
• A representative will troubleshoot your problem over the phone.
• If the representative determines that you should receive service, they will provide you with the name(s) of the
Authorized Service Center in your area.
• Contact the Service Center and arrange for home or pick up, repair, and return service, provided that your unit is
located within the geographic territory covered by an Authorized Service Center. If not, you must take your unit to the
Service Center location at your own expense, or pay for the cost the Service Center may charge to transport your unit to
and from your home.
• Proof of purchase in the form of a bill of sale or receipted invoice which is evidence that the product is within the
warranty period must be presented to obtain warranty service. For rental fi rms, proof of fi rst rental is also required
Here is a link to rca tv manuals if you don't have one.
You can download them in pdf.
If this is not a help, please give the specific model number.
Apr 21, 2008 | Televison & Video
Image cut off of Samsung LCD TV picture
if you have a time warner remote press the # to zoom
cox has another button . don't know it. ask them.
Mar 08, 2008 | Samsung LN-T4671F 46 in. LCD Television
Lines, colors, delayed images
Had the same problems.  This was after the a power outage.  Had green vertical and horizontal lines, like a checkered shirt.  But I searched online and found the simplest solution.  Just unplug the power.  And it worked.
Jan 02, 2008 | Samsung DLP HL-P5663W 56" TV
Image on my Apex TV/DVD combo is too large for the screen
deer joe you need da service manual,becouse your tv is altereyted the memori,you moust going the center service for definetival reset
Jun 02, 2007 | Apex Digital GT2715DV 27 in. TV/DVD Combo
Samsung TX-R2035 TV Logo
213 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
