The carriage is what holds the ink cartridges. If you open that and make sure that there is nothing that is blocking the carriage from moving. If there is remove it. If the machine is powered off you should be able to slide the carriage by hand back and forth along the metal shaft that it rides on. If it feels like it is sticking you can wipe the shaft off with a clean lint free cloth. DO NOT add and oil to the shaft. Power the machine back on and it should work. If it still errors out you will probably have to bring it to a repair place.
Hope this helps
Recently when printing pictures using the document feeder (top tray) and glossy photo paper I have...
(More)
Recently when printing pictures using the document feeder (top tray) and glossy photo paper I have two problems. 1. I get horizontal lines across the picture. 2. The paper feeds mid-picture, so it might print the top 1/3 page of the picture then feed the page and finish the picture at the top of a second sheet of paper.
Hi there! My scanner is only scanning bits and pieces of an 8 1/2 x 11 page or sometimes it scans...
(More)
Hi there! My scanner is only scanning bits and pieces of an 8 1/2 x 11 page or sometimes it scans bits and pieces and the image is just a pile of coloured lines. Is there a setting that has been accidentally changed that I could change back or is my printer on it's last legs? Thanks so much, Andrea
when I press scan to computer it reads downloading application list, then says this can't be done. I...
(More)
when I press scan to computer it reads downloading application list, then says this can't be done. I last used it to scan only a week ago and it just done it without any message????
