Question about Husqvarna Chain Saw 20" Bar
Huskvarna model 141le wants to run full throtle all time
Carb has been rebuilt and problem is the same. starts good and will idle until you give it the gas a couple of times then full throtle problem begins again
  • 211 Answers
Hi
Adjust H,L and T from the carb.When the engine is warm check the spark from the sparkplug:It has to be a strong violet spark(not flame).Disassembly the carb and carefully clean it.Check the fuel pump(it should be tighten not bended),Check the fuel filter and air filter.;the gas tank ventil and the fuel hose.
regards savumihai71
Posted on Dec 05, 2008
Won't idle will run wide open if choked must hold hand on back of carb to start it
Theres a blocked orifice in the carb- Cleaned or not. Check by running thin wire or fish line thru all orifices
Oct 04, 2015 | Motorcycles
Just rebuilt carburetor for kawasaki 300 prarie and when i start it the throtle is very high, how do i adjust it
There should be a cable that runs under the carb on the left hand side of the quad,that has a black knob on it.If that has no effect,then its a possibility that your cable is too tight,needs lubing,OR you could have a vacuum leak somewhere.
Good Luck!
Sep 28, 2012 | 2002 kawasaki KLX 300 R
Runs at full throtle and then stops
sounds like you have a crank seal out of it, you ncan try to clean carb and check fuel lines etc, but usually when they rev high with out giving throttle means there is an air leak Good Luck 2StrokeJim
Nov 19, 2011 | Poulan 25CC Gas BlowerVac
I have a yamaha 40etlg outboard that will run good at full throtle, but when I go back to slow speed, almost idle, it stalls, and is very hard to start. I can get it started and it will run wide open, but...
stalling at idle indicates a blockage in the idle circuits of the carby
fuel breaks down all of the rubber components ( hoses pumps etc( and e-mix fuels are worse) so it indicates that a blockage is in the small drilling or jets for the idle
take it in for a professional overhaul and adjustment
Aug 10, 2017 | Computers & Internet
2004 150 runs good but won't idle and idle screw does'nt seem to make a differance
well if it didnt run good i would say carburator needs cleaned or rebuilt.if bike performs fine you can adjust the idle at the hand throtle on handle bar ,just loosen the nut and unscrew a little at a time untill desired idle is acheved and then tighten screw back down.
May 21, 2010 | 2005 Honda CRF 150 F
Starts and idles will not run above idle unless choked. Have cleaned carb multiple times new fuel filter new air cleaner and cleaned exhaust screen new plug. Maybe a collapsing fuel line?
Have you tried adjusting the carb? There should be two screws on the carb (hi & Low) turn the hi screw completely until it stops and then start the unit. Let it warm up and then begin to back the screw out until it starts to run smoothly but strong. Once you have it running then put it in full run position (choke) and you should be good.
Feb 19, 2010 | Echo Inc. 44 CC, Carb Certified Backpack...
Chain saw will idle, but not run at full throtle
First, check the air filter and clean it well. Then make sure the spark plug is clean and gapped properly.
Then prime, start it up, and allow it to idle, even using the trigger to make it fast idle if you can. Using a small thin screwdiver, turn the high speed idle screw on the carb in small increments to the right, kepping the speed up on the trhrottle.
The idea is to screw it out until it sputters, then screw it a half turn back in. If it doesn't smooth out when turning it to the right, try going to the left.
Afterwards you may find it doesn't run at low throttle well. If not, try the same thing starting to turn left until it smooths out. If it doesn't, screw to the right. Again, the idea is to go until it sounds rough, then back off a half turn.
You should be able to adjust it to the point where you can open the throttle all the way with smooth sure throttle increase.
Nov 05, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Stihl line trimmer FS46 Runs good at full throtle
the smallest piece of trash will cause you the biggest problems. try blowing the carb out . i think it has a pre set idle on it.
Sep 18, 2009 | Garden
Husqvarna Chain Saw 20" Bar Logo
150 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
