Question about Fisher CD-RW1000 2-Disc CD Recorder
Fisher cd-rw1000 Im trying to record from an analog device (4-track recorder) I used to do this all the time and its been a while since i used the cd-rw 1000 and i forgot how to do it . I nolonger have the owner manual . When i hit record im getting a da:d2 . how do i record from analog and where can i get a new owner manual? thank you, Am
  • djdave420 Jul 01, 2008
    Just got a Fisher CD-RW1000 2-Disc CD Recorder, need a manual. Any suggestions? Am  a pro-DJ and wish to make my demo direct to cd.
    DJ Dave
Hey boss...turn on the rcorder...put a cd digital audio cd,I use Memorex CD-R B....put the cd in right side disc try...press to close....reading will show Blank....press input button to analog...all this will appear in the window.....press dubbig button to 60....press rec level far right digital level buttons to 6db...now you are ready......press record button the window will show ready after the busy signal...now turn on your analog then press enter you will see the time is counting.....if you want to track at the end of song press pause then ready will come on..move fast..keep the analog going..press enter it will show the next track...you will bet the hang of it like a pro...when you finish press the stop button under the right shelf pma write will show,when it clears press finalize then hit enter when it finished it will show complete your done. see ya david.....bye bye
Posted on Jan 11, 2008
Ah..yes..mi friend, i was in that spot one time. one suggestion i have is-make sure the blank cd you are trying to record on is a "compact disc DIGITAL audio"...or try hitting the "input select" button.
Posted on Aug 08, 2007
Tray wont open - Fisher CD-RW1000 2-Disc CD Recorder
With a bit of luck it's just a belt that has broken or fell off, which can easily be replaced.
You just need to look inside.
Sep 08, 2018 | Fisher Audio Players & Recorders
My Fisher CD Player heats up right after plugged in. Unplug, cools off, same problem when replugged. Why?
check the voltage of the new charger
If it heats so quickly the I suspect that the adapter is not correct voltage for the player.
May 20, 2015 | Fisher CD-RW1000 2-Disc CD Recorder
On some blank cd's I get a DA:D2 can't record
I'm told this is the manual...
http://support.radioshack.com/support_audio/doc71/71337.pdf
Page 28
The quick answer is that you're trying to use a blank Data CD on a consumer AUDIO recorder. No can do.
This is true for ALL consumer audio CD recorders. Buy blank media that has Audio or Music printed right on it.
Feb 20, 2011 | Fisher CD-RW1000 2-Disc CD Recorder
I have a Phillips CDR 775 2 -disc cd recorder and my track time is automatically set to 20 seconds. How do I increase this time per track? Also, I cannot seem to get the auto track to work when...
It's all in the manual...
20 seconds is the amount of digital 'silence' the machine will let pass during recording before it marks a new track. t will Pause and wait one minute for a digital signal to resume. (Page 21)
On digital copying it will automatically increment track numbers as the source advances.
For analog sources you should switch Auto Track to OFF and manually press Track as applicable. (Page 28)
Jan 21, 2011 | Philips CDR775 2-Disc CD Recorder
Im trying to records mix cd but isnt changing
• To switch off the Auto Track function you have to enter
Menu mode.
If you wish to increase track numbers manually, press
TRACK INCR(ement) on the remote control. For further
instructions see Menu mode.
ON (AUTO): The track increments are automatically taken over
from the digital source material or after 2.7
seconds silence during analog recording.
OFF (MANUAL): While recording track numbers can be
incremented manually by pressing TRACK
(Minimum track length is 4 sec.) (This can
also be done in Auto track ON mode.)
May 01, 2009 | Philips CDR770 CD Recorder
Fisher CD-RW1000 2-Disc CD-dvd stuck in player
hmmmm.... try to take off the cover of your dvd player and observe it.(if you try my advice, try it in your own risk and with caution) then check the tray maybe there is something got stuck in there and also check the gears, if nothing, a belt just came off. check the motor too, I guess It has 2 switches too. clean them up. and then try to power up.
note:
(keep you fingers away at the power supply section)
Jan 29, 2008 | Fisher CD-RW1000 2-Disc CD Recorder
Need owners manual
This Unit is the same as a Radio Shack RCA branded model minor differences. 42-7011 Same type of issues that the RadioShack unit had. Hope this helps.
http://support.radioshack.com/productinfo/DocumentResults.asp?sku_id=42-7011&Name=CD%20Players&Reuse=N
Aug 26, 2007 | Fisher CD-RW1000 2-Disc CD Recorder
Fisher CD-RW1000 2-Disc CD Recorder Logo
618 people viewed this question
Top Fisher Audio Players & Recorders Experts
oldhess
Are you a Fisher Audio Player and Recorder Expert? Answer questions, earn points and help others
