I chand the two cartridges test page came out with color and black tried to print a page and it only printed in black
  • 148 Answers
You have to make a lot of Cleans in the Color printer head....
enter in the driver proprieties of your printer and make a good clean on the color cartridges!
Posted on Dec 04, 2008
My HP C4780 PRINTER WILL PRINT A TEST PAGE BUT NOTHING ELSE. How do I get it to print?
Check the settings in Windows Print Manager.
Make sure that the paper quality matches what is in the printer. If set to glossy, minimal ink is deposited on the page. Also, check the print quality - draft quality provides a minimal amount of ink as well.
Jan 17, 2015 | HP PS C4780 All in One InkJet Printer
SLOW PRINTER
You have a cartridge problem.
This condition is typically caused by one of the cartridges failing. Try removing the black cartridge and printing (not copying) a test page. If this prints at near normal speed the black cartridge is at fault and should be replaced. If the printer still prints slowly then put the black cartridge back in and remove the color cartridge, then print a page. Replacing the cartridge that causes the slow printing with a fresh cartridge will resolve the issue.
May 03, 2012 | HP Office Equipment & Supplies
HP Office jet printer slow
I think it's that black cartridge!
The problem you've described is typically caused by one of the cartridges failing. Try removing the black cartridge and printing (not copying) a test page. If this prints at near normal speed the black cartridge is at fault and should be replaced. If the printer still prints slowly then put the black cartridge back in and remove the color cartridge, then print a page. Replacing the cartridge that causes the slow printing with a fresh cartridge will resolve the issue.
Assuming the cartridges are original HP (not re-manufactured or refilled) you can check the warranty status by CLICKING HERE
Let me know how you make out.
Ben
May 03, 2012 | HP OfficeJet 7410 All-In-One InkJet...
Lexmark x1270 wont print color even though the cartridge is full.
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.
2. Select "Clean and Fix Horizontal streaks." Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
Next, try this printer self-test by following the steps given below:
1. Power the printer off.
2. Press and hold the "Paper Feed" button.
3. While still holding the "Paper Feed" button, press and release the "Power" button. Continue holding the "Paper Feed" button.
4. When the printer starts pulling paper, release the "Paper Feed" button. It should print a test page at this point.
5. Power the printer off, as this test is continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, please try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only a color cartridge installed (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed). If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know.
Oct 19, 2009 | Lexmark X1270 All-In-One InkJet Printer
I put in new color and black cartridges a couple of days ago and was able to print okay. Now I keep getting ''Remove and Check Black Cartridge'' prompt. I've taken out Black Cartridge, turned off printer,...
hope you put back both cartridges before trying again..try wiping the tip of the black cartridge before replacing it..then activate the head cleaning process..
Oct 03, 2017 | HP G85xi All-Color InkJet Printer
Print cartridge missing
Please remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Please snap the cartridges back into the cartridge carrier.
1. Please turn OFF the printer.
2. Press and hold the "Color copy" button.
3. Now, turn ON the printer.
4. Once you see "0" on the display, release the "Color copy" button.
5. Press the Up arrow button until "2"appears on the display.
6. Press the "Black copy" button to start the self test. Once the page has printed, the printer will stop printing.
The self-test should at least print out a set of either black or color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with the color cartridge installed by itself. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let me know.
If the self-test prints, but has lines or smudges or other print quality issues, let us know. This includes any print quality issues, we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
Apr 13, 2009 | Lexmark X2650 All-In-One InkJet Printer
Color ink want print after installing new cartridge
have you installed the cartridge correctly??? make sure you did
try to print a few pages, to get the ink going.
try test pages, try the aligning procedures as well.
Mar 26, 2009 | Lexmark Z515M InkJet Printer
HP Photosmart C 4200 printer will not print in black. Will print all other colors
Try to  print a test page first. To print a test page press and hold the bottons power and cancel together. The test page will show you the amount of ink left in the cartridges.  If the black ink color bar is not visible in  the, than it will mean that the ink is low or depleted. Try a new genuine HP ink cartridge. It should help you.
Jan 26, 2009 | Office Equipment & Supplies
HP Photosmart C3100 series
I just got off the HP help line.  After changing my black ink cartridge a test page was printing each time I turned the machine on.  This is very costly, in both time and ink as the cartridges themselves for this machine hold very little ink.  I tried to learn from HP tech how to turn off the test-print while keeping my color cartridge empty.  It turns out that you cant do it.  HP requires you to keep buying and using cartridges whether you need them or not.If you buy the color ink it will use it up in its testings.  And if you dont buy the color cartridge it will use up your black ink by printing the test each time you turn on the printer.  The printer was inexpensive sure, but I'm paying for it in wasted ink.
Dec 26, 2007 | HP Photosmart C3180 All-In-One InkJet...
Dell Photo All in One Printer 964
Try printing a windows test page from the driver software, START-SETTINGS_PRINTERS-DELL964- properties,,etc. If the test page prints with color then I believe that your driver is set to print in greyscale. If you can't find that option in the driver you might try to re-install the driver from your original cd.
Aug 28, 2007 | Dell Photo 964 All-In-One InkJet Printer
53 people viewed this question
jasbo
jasbo
