Question about JVC AV-27020 TV
JVC TV AV-27020 works well with an indoor antenna GE DTV converter box works well on other TVs in the house The JVC's antenna works well with the GE converter box on other TVs in the house. The JVC displays only a blank blue screen (no sound) when connected to the converter box and antenna. The JVC doesn't like the converter box. Can this be fixed?
  • 4,806 Answers
Yes you just have to chjannel hop until you find the right channel, with Cathode TV's like yours they are usually in the AV channels make sure you have the right codes for the GE coverter box too
kind regards
Posted on Dec 04, 2008
    Genius:
  • 1,550 Answers
Check the connections once again .
Loose connections between Tv and converter box can cause this problem .
If the connection is ok . Then the connector port in tv is damaged .
    Sergeant:
  • 217 Answers
A technician at your place is required to check out the connections.it can be fixed.
  • JVC Master
  • 19,396 Answers
From description it sounds like a cable problem. Try a replacement cable.
  • Ginko
    Ginko Dec 04, 2008
    Try also switching the TV input channels (use the remote) after connecting the converter box this may also be the problem.
    Test a replacement cable, even if the cable works on a different TV.
NO CHANNELS
What specific model of JVC multi-system TV do you have? What is the signal source?
The majority of the JVC multi-system TVs that I've researched only have analog tuners (NTSC, PAL). The AV-29LX is an example of the older JVC TVs. Since most over-the-air signals are digital, you will need a digital-to-analog OTA signal converter to watch any signal from an aerial TV. If you have a cable system that has upgraded to digital cable, you will need a cable box.
Converter boxes are harder to find but there are a few remaining. Here's one for the US: http://www.amazon.com/Magnavox-DTV-Digital-Analog-Converter/dp/B0013ZKZGU .
I wish that I had better news for you.
(A few low-power stations still broadcast in the analog format. However, you have to be really close to the station or have an outdoor antenna to have a chance at receiving the signal.)
Mar 30, 2014 | JVC 29" Flat Screen Multisystem TV
I have a GE remote and an I'Art JVC tv, cannot get remote to work.
Setup codes for JVC with GE remote control are:
0060 0026 0197 0069 0247 0923 0012 0065 0067 0141
Jul 29, 2012 | JVC AV-27020 TV
I have color on all but 1 TV station. That staion has color on other TV's in my house. Any sugestions?
Ur tvs in ur house it is getting a paid tvs incomming broadcasting tv signals like a cables or a satalites dishes companies?Yes,than that incomming broadcasting wire that plug into ur tv Ant. input port hole might have some kind of signals interference at that channel frequencies,call ur cables tvs or satalites tvs companies providers for an answers and get their field Tech. to come out and check it out.If all ur tvs in the house are analoge tvs and u are using a DTV signal through a DTV converter box to getting a Free over the air DTV air to recieving tv broadcasting tv channels stations only than tries it with another antenna signals sources like a better antenna design like a portable digital antena or good roof antenna should solved this problems.
Oct 03, 2011 | Philips Magnavox 20MS3442 20" TV
Is jvc av-32d503 digital ready or do I need to buy a converter box for use with an outside antenna system
Looks like you'll need a converter.
Here's some background info:
Analog TVs were made up until 2007.
Digital tuners for over the air signals are called "ATSC tuners".
To tell if your TV has one:
-If the TV was sold as a "HDTV" or "DTV", it's supposed to have an ATSC tuner built in to it. "HD ready TVs" do not have a digital tuner.
-Check the specs in the owners manual or google the make & model of the TV to see if it has an ATSC tuner.
-If your TV's menu has an option for scaning for digital channels, then it has an ATSC tuner. If it dosen't have a way to scan for digital channels, then it doesn't have a digial tuner.
Most DTVs also have a digital QAM tuner that is used in some (but not all) cable systems.
Jun 11, 2011 | JVC AV-32D503 32" TV
DO I NEED A DIGITAL CONVERTER TO OPERATE A 4 YEAR OLD JVC MODEL AV-32D305 WITH AN ANTENNA?
If you have cable running to your house, cable still uses RF and older TVs work fine. The problem comes when you try to grab stations from the air. The signal is still UHF, but the information riding on that UHF signal is digital, and will need a converter box to turn it back to analog so your older TV will understand it. . Cable: None needed. . Antenna: Need a box.
Nov 25, 2009 | JVC AV-32D305 32" TV
Converter box installation. Not a clue.
rf cables will work fine for older tvs. newer tvs should use the composite (yellow, red and white cable) to produce a digital picture and sound. FYI the indoor antenna works best when positioned in a window. Best thing to do is install an outdoor antenna in the attic near the gable vent or on the exterior of the house.
Jul 04, 2009 | Televison & Video
JVC and the right converter box and antenna
If the tv got audio video inputs put the converter box on it,because any converter box got to work with all tv´s
Jun 30, 2009 | JVC AV-27230 27" TV
Digital Tuner or Analog
I have the JVC AV-27020 and had to download the manual just today. I checked where I got my manual and they did not have anything for an ACV-27020. The link for the TV manual I downloaded is below. Maybe it will help.
http://www.retrevo.com/s/JVC-AV-27020-TVs-review-manual/id/279ag501/t/1-2/
Aug 10, 2008 | JVC AV-27020 TV
Digital TV Signal
Not if you cable TV, DirecTV, Dish network, or FIOS. The converters are not usable with those services.
If you use a regular TV antenna or rabbit ears, then, yes, you will need a DTV converter box. If so, I'd suggest getting one well before next February. Why? 'Cause the pictures are better, and you'll have access to "virtual channels", where broadcasters send more than one program on channels like 4.1, 4.2, etc. Also, if you have poor reception, you may need a better antenna to see the DTV signals. Better to know that before DTV is all that is being broadcast over the airwaves.
Jan 19, 2008 | GE 19GT243 19" TV
DTV Question
Based on the features described by JVC and the technical details listed on Amazon.com the answer is no, no digital ATSC tuner, just NTSC analog.
So yes, she'll need a converter box for the ATSC over the air signals.
Jan 16, 2008 | JVC AV-27D201 27" TV
JVC AV-27020 TV Logo
41 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
