I have just bought a DVD Video Player No DVP3120 from Tesco it only had the power lead attached,should there have been a scart lead included. Hope you can help. Thankyou. B. F.Oxley
Problem sorted found out they do not include scart leads,which i think a bit bizzare had i bought it for a xmas present it would not hve worked !
Posted on Dec 07, 2008
I bought a freeview box, My tv has only one scart socket. how do i connect my dvd player to combine with this?
You need a video switch box, that has two video and audio inputs and a video and audio output that connects to the video and audio connections on the scart cable.
Then you can switch between the DVD player or the freeview box.
These devices are available on the Internet, use Google to search for these devices.
Dec 17, 2011 | Televison & Video
Video mode
Hi
Does your tv have 21pin scart connector on the back if it does connect with 21pin scart lead to scart connector on dvd player.When play is selected on dvd player tv should swich via pin8 to a/v mode hope this helps
Mar 09, 2010 | Sylvania 6427TE 27" TV
Ineed to know how to interconnect our tv, vcr, dvd and top set box, Can you help? Philips DVP3120/05, Philips VR720 Philips 282 tv with built in dvd and Bush free view top box.
Problem solved : incorrect connection of scat leads Solved by roof top digal aerial Digi top box and on to VCR. and then on to TV.
Scart from VCR to TV
Scart from VCR to DVD
Scart from Digi Top Box to TV.
Everything now functions correctly
Equipment connected:
Philips VCR: 720/07
Philips TV : 28PW6515/05
Philips DVD: DVP3120
Bush top box
Nov 20, 2009 | Philips Televison & Video
I just bought a second hand sumsung tv with a vrc attached. it has A/V connections but for some reason i cant hook it up to my dvd player...not sure WHY!?
connect up your scart lead, from the scart socket on dvd player to the scart socket on tvyer. There are usually to sockets to connect to on the tv, it will be AV1 or AV2. To view dvd, press source button on tv remote to select AV channel you have connected the dvd played to.
Aug 15, 2009 | Samsung Televison & Video
I recently purchased a DVP3980, could you please advise me where to get the appropriate Scart Lead and Cable and Adapter from.
Scart leads are available just about anywhere try your local Tesco or Asda but dont by the very cheap ones as this will degrade your picture.
SUPER8
Nov 26, 2008 | Televison & Video
Accessories
Depends on the /xx at the end of the model # - if it is an 07, 17, or 37, it was designed for US, and will not have these - go to www.philips.com/support for the manual for this product to see correct hook-up options
Aug 09, 2008 | Philips DVP5140 DVD Player
Dvd video player model no DVP3120 unable to get player to play on tv setting AV1 at all but on tv setting AV2 player plays dvd`s but picture only no sound. it is connected using a Scart lead.
through a process of elimimation I identified the problem as a faulty scart lead
replaced lead and all was okey dokey
thanks for advice posted
colin the cat
Jan 22, 2008 | Televison & Video
NEW DVD PLAYER, PHILLIPS DVP3120 PICTURE SCROLLING RIGHT TO LEFT
have you tried the scarts they are fully inseted to dvd and also the tv , some times the cables become loose this can cuase this to happen .
riz.
Nov 20, 2007 | Televison & Video
Tuning a samsung tv to a phillips dvd, a goodmans video and an akura freeview box
It sounds like you are trying to tune in the dvd and video to a free channel on your tv, I would suggest using the scart connection if your tv has one. Scart leads only fit in the one way so you cant go wrong. Scart leads are available everywhere including tesco.
Once the scart leadt isconnection between the dvd and the tv then use the AV1 button on your remote controll and you will get sound and picture in better quality than manual tuning.
Oct 28, 2007 | Philips 32PT6441/37 32" TV
Wharfedale DVDRHD400 Set up Issue
Hi I had the same problem. The answer is to use a scart lead on the freeview box and connect it to the input/output scart on the DVD. Then connect a scart lead from the TV out on the DVD to the TV. You then press Video source on the DVD remote until 'scart' is displayed to pick the freeview channels. Hope that helps
Jun 25, 2007 | Wharfedale DVD-M3 DVD Player
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
