Question about Adobe Computers & Internet
How do you skew an object on illustrator?
I converted a text into outlines and wanted to skew it but can't seem to find out how to do it? I hope you can help me on this.
    Problem Solver:
  • 9 Answers
Ahh!! good one. You can use the free transform tool. I'll provide a link that should prove to be very helpful for you.
http://www.khulsey.com/adobe_illustrator_free_transform.html
Enjoy!!
Posted on Dec 07, 2008
How to repair illustrator file?
And also u can use the same program Illustrator Repair Toolbox
But with working link below:)
http://www.illustrator.repairtoolbox.com/
Dec 15, 2014 | Adobe Illustrator CS3 - Windows for PC...
I need to curb the text kind of like word art in corel x4 can you help me to do it or how to do it
To create curved text you need to use the text tool and fit to path. When you create a shape, line or curve and then select the text tool you can make the text take the same path as the object you created by just hovering it over the objects outline, you should see the courser change.
1- Draw the a curve
2- Select the text tool and hover it over the curve that you created and then when the course changes click on the line activating the text tool
3- Type the text
4- Select the curve and change the outlone color to transparent
Jun 10, 2009 | CorelDRAW Graphics Suite X4 for PC...
Program for calculator using vc++
hi, here the code...
class is used for items(item.h) . In this class are stored the two number into property and the result:
property double nr1;
property double nr2;
The operations like :asin,cos,power,pi,plu,divide,sqrt etc. are edited into inherited class from items:
#pragma once
#include "Items.h"
using namespace System;
public ref class asinus : public Items
public:
asinus(void)
double^ asin(double a)
return Math::Asin(a);
In the base class 6 boolean variable is used for the precedent operation:
bool plus;
bool minus;
bool produs;
bool divide;
bool sin;
bool prec;
For button equal:
private: System::Void btnegal_Click(System::Object^ sender, System::EventArgs^ e)
prec = false;
if(plus == true)
this->txtRes->Text = Convert::ToString(p.aduna(i.nr1,i.nr2));
else if(minus == true)
this->txtRes->Text = Convert::ToString(m.scadere(i.nr1,i.nr2));
else if(produs == true)
this->txtRes->Text = Convert::ToString(pr.inmultire(i.nr1,i.nr2));
else if(divide == true)
this->txtRes->Text = Convert::ToString(d.impartire(i.nr1,i.nr2));
there is a function for operaton click:
private: System::Void Operation_Click(System::Object^ sender, System::EventArgs^ e) { if(prec == false) { i.nr1 = Convert::ToDouble(this->txtRes->Text); } if(prec == true) { i.nr2 = Convert::ToDouble(this->txtRes->Text); } }
Apr 10, 2009 | Microsoft Computers & Internet
Converting word formatted data in CStriing to MS publisher
Why not use Word Automation? You instantiate an object with a reference to Application.Word, load your document, then use the built in functions to extract the text from the document and paste it into the MSP document.
Jun 30, 2008 | Microsoft Computers & Internet
Illustrator to photoshop
Here is everything you will need. I hope you will find this worthy of a FixYa rating.
Import Illustrator CS2-CS3 artwork into Photoshop CS2-CS3
What's covered In Adobe Photoshop, you can import Adobe Illustrator artwork in several different ways, each of which offers a different level of control. When you open or place AI, EPS, or PDF files created by Illustrator, Photoshop rasterizes vector artwork and removes the ability to edit transparency, fonts, layers, and paths. To retain more control over imported Illustrator artwork, Adobe recommends that you drag or paste it into a Photoshop image or export it in Photoshop format.
Drag Illustrator artwork into Photoshop Dragging Illustrator artwork is the quickest way to import it into Photoshop. By default, Photoshop creates a new layer for the dragged artwork and imports the artwork as a Vector Smart Object. (For more information, see "Smart Objects" in the Photoshop Help.) You can import dragged vector artwork as a work path, however, by holding down Control (Windows) or Command (Mac OS) while dragging. To center imported artwork in the Photoshop image, hold down Shift while dragging.
Note: To import dragged type as a work path, you must first convert it to outlines in Illustrator. For more information, see "Modifying letterforms as graphic objects" in Illustrator Help.
Paste Illustrator artwork into Photoshop When you copy Illustrator artwork, you can paste it into Photoshop and retain many Illustrator features. To do so, however, you must properly configure Clipboard preferences in Illustrator.
The Illustrator Clipboard supports a variety of formats including: PICT, PDF, and AICB. Though Illustrator always copies PICT data to the clipboard, you can configure Illustrator so that it also copies PDF or AICB format. These two formats allow you to retain Illustrator features in artwork pasted in Photoshop. PDF retains Illustrator transparency, while AICB format retains Illustrator paths.
You should only select the AICB format by itself if you are going to be pasting paths in to Photoshop. In all other cases, select the PDF format or the PDF format in conjunction with AICB. The PDF format retains transparency and other features in Illustrator such as extended support for spot colors.
To configure Clipboard preferences in Illustrator:
  1. Choose Edit > Preferences > Files & Clipboard (Windows) or Illustrator > Preferences > Files & Clipboard (Mac OS X).
  2. In the Clipboard section, select the desired format.
  3. If you selected AICB, select either Preserve Paths or Preserve Appearance.
  4. Click OK.
Paste options in Photoshop
When you use the Paste command to import copied Illustrator artwork, Photoshop provides the following options in the Paste dialog box:
  • Paste as Smart Object: Pastes the art as a Vector Smart Object that can be scaled, transformed, or moved without degrading the image before it's placed into the Photoshop document. As the art is placed, its file data is embedded in the Photoshop document and the art is rasterized on a separate layer.
  • Paste as Pixels: Pastes the copied artwork in a new layer and rasterizes it at the resolution of the Photoshop image. Use this option when pasting raster objects.
    Note: When you use this option, clipping masks for raster images are not retained as paths. These masks still clip images, however.
  • Paste as Path: Pastes the copied artwork as a work path.
  • Paste as Shape Layer: Pastes the copied artwork in a new vector shape layer. Compound Illustrator shapes retain their attributes and remain editable. Multiple copied paths and clipping masks are pasted as multiple paths that use the unite attribute .
    Note: When you use this option, pasted objects use the foreground color in Photoshop, not the fill color they use in Illustrator. Likewise, transparent objects become opaque.
Export Illustrator files in Photoshop format Exporting Illustrator documents files in Photoshop format gives you the most control over Illustrator artwork in Photoshop. With this method, you can specify resolution and enable anti-aliasing for rasterized artwork. You can also retain the following Illustrator features:
  • Editable text
  • ICC profiles
  • Layers, including nested and hidden layers
  • Masks
  • Transparency
  • Compound shapes
  • Slices and image maps
Note: A compound shape must have either no stroke or a stroke with a round join that uses whole integers for the stroke weight. However, the compound shape can reside on a layer with other objects. In that situation, Photoshop places the other objects on a separate layer in the same layer set.
For more information about exporting Illustrator files in Photoshop format, see "Photoshop export options" in Illustrator Help.
Open Illustrator (AI) files in Photoshop You can open AI files in Photoshop if you save them using the Create PDF Compatible File option.
To save an AI file using the Create PDF Compatible File option:
  1. Choose File > Save As.
  2. Choose Illustrator (*.AI) as the file format, and click Save.
  3. Click Create PDF Compatible File in the Illustrator Options dialog box, and click OK.
Thanks,
Lee
Jun 18, 2008 | Adobe Photoshop 7.0 for PC
Converting text to an object
Select the type object (the Select tool must be used, not the type tool); then from the menu, choose: "Type," then, "Create Outlines." The text will become an object, with multiple lines and curves, fully editable, by each point or line.
May 09, 2008 | Adobe Illustrator CS V11.0 for PC
Ocr
Use any OCR software and it will take care of converting the scanned image into .DOC file or .PDF file. Some OCR softwares require a minimum dpi output, standard being 300 dpi. Ensure that the image is clean and 'straight', deskew if skewed.
Feb 19, 2008 | Canon CanoScan N650U Flatbed Scanner
Computers & Internet Logo
2,351 people viewed this question
Top Adobe Computers & Internet Experts
lemesee
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
