Question about Canon P23-DH Calculator
Canon p23-hd v
We calculation but not right amount print on paper diff.sign.come reset,change button cell but not work proper printing
thanks
kelly
  • Anonymous Mar 13, 2014
    Canon MP31DH - recently for the first time in the 3 years I've been here my calculator is printing numbers off to the left of my check amounts on my receipt and they don't make any sense what they mean. I am familiar with the counter and I want that but I hate these other numbers!
    Problem Solver:
  • 5 Answers
Download the user manual (P23-DH III) from here:
http://rapidshare.com/files/181603396/P23DHIII.PDF.html
Posted on Jan 10, 2009
Cleaning my calculator print head
try using clear alcohol and a small toothbrush or crc contact cleaner
Jul 12, 2016 | Canon P23-DHIII Calculator
Order tape for printing
Lorena, Staples will have it in stock, Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Amazon com Calculator Plain Paper 2 25 150 Pack of 3 Calculator And Cash...
Canon 1904B001AA P23 DH Printing Calculator Staples
How to Load Paper Into Canon P23 DH eHow
Mar 05, 2016 | Canon P23-DHV Calculator
Need to know how to insert printing tape into Canon P23-DH color printing calculator?
Install paper roll with end coming up from rear. Insert end of paper into slot at back of calculator until it stops. Then press feed button until paper advance thru slop at top.
Jul 17, 2010 | Canon P23-DH Calculator
I need the instructions for a canon P23-DH V calculator
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=346&modelid=15431
Apr 16, 2010 | Canon P23-DH Calculator
How to reset the clock?
Push the button with the clock and calendar, this is directly over the 'cost' button, to display the date or time. Then use the 'Time set' button (this is the one for Memory - Plus - Equal). Hold the 'Time set' button down until the first figure blinks then release it. Use the number buttons to change the setting. When you have gotten the correct date or time entered oress the 'Time Set' button again.
Although it is only printed with 'Time Set' the button works for the date just as well.
Mar 30, 2010 | Canon P23-DH Calculator
Forgot how to load paper
Hello.
From FixYa Support:
While looking at the front of the P23-DH printing calculator. Fold down the paper holder and turn the calculator back around to face you. Then, cut the paper on the roll straight across. Then, feed the paper into the slot in the back of the calculator. Turn the calculator on to the print mode. Then hit the "feed" button. The paper will feed through and you are ready to go.
Hopes this helps.
Mar 14, 2010 | Canon P23-DH Calculator
How do I load paper in my canon p23 dh v printing calculater
Put paper roll on paper arm with the end of the paper coming down from behind. Cut paper on a diagonal. Insert the paper into the **** at the back of the calculator. You need to really look to see it. Use the feed button to feed the paper through..
Nov 06, 2009 | Canon P23-DHV Calculator
How do I feed the paper through to start printing
Put paper on paper arm with end of paper hanging down from the back. Cut the end of the paper at a diagonal. Insert paper into **** on back of calculator. Use feed button to feed the paper into the calculator.
Hope this helps.
Oct 28, 2009 | Canon P23-DHV Calculator
How do you load paper into the printing calculator?
Cut paper at a 45 degree angle and load into back slot with angle (apex) of paper to the right of machine when facing it. Be sure to push it thru when loading. You should see tip next to calculator number wheel. Hit the additon sign several times to advance. You may need tweezers to pull paper thru if it doesn't advance by itself.
Oct 10, 2008 | Canon P23-DHV Calculator
Loading paper
Cut paper at an angle and insert and push into back slot with tip of angle (apex) to the right of machine when facing it. It should engage number wheel when you hit addition sign, You may need tweezers to pull it thru if it doesn't advance.
Jun 20, 2008 | Canon P23-DHV Calculator
Canon P23-DH Calculator Logo
505 people viewed this question
old marine
old marine
