Question about Kenmore Elite 45986 Front Load Washer
Washing machine moviment
Front end loader washing machine moves about on highspeed spin possible solution to this problem
Did not stop the vibriation but movment stoped by installing three quarter in plywood under it glued ply wood to exsisting floor and screwed it down then put fences wood around legs works so far anyway
Posted on Dec 05, 2008
Electrolux EWF1083 Front Loader washing machine.
Your right not draining-see your other post-cheers Denny
Oct 24, 2013 | Washing Machines
My ge front end loader washer won`t spin water or pump water out
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jan 29, 2011 | GE WSXH208A Front Load Washer
I replaced the base assembly and completely level the machine and it still is unbalanced at the 11 mi. mark.
Is your washer a front loader because if it is then one possible solution is by putting less close. I have a front loader and when I put 8 blue jeans along with some other close. The spin cycle is violent and by removing 4 jeans, the cycle spins better and it end up balancing its self. Usually jeans soak up a lot of water, so try to put in lee close and less heavy close.
If this does not help then you might have a problem with the damper shocks (leaking) or springs (broken) if it a front loader washer.
Jan 11, 2011 | Washing Machines
Leaking water in washing machine
Front loader or Top Loader? If front loader you probably put to much in and at spin cycle the tub hit the hose to the pump and possibly got knocked off?
Oct 16, 2009 | Washing Machines
My washing machine spins violently and the ground
Possibly you still have the transport screws in. this causes havoc when load is in. or very unballanced load or possibly spring come loose . assuming you have a front loader. Definately one of those.
Sep 15, 2009 | Frigidaire ATF6000ES Front Load Washer
During spin cycle washer spins fine but toward the end of the cycle it spins out of control like it is out of balance? Any help is greatly welcomed.
Some front loaders have a super high speed at the end of the spin. Front loaders don't like small loads, the laundry does not spread out evenly enough for a balanced spin.
May 08, 2009 | Frigidaire ATF6000ES Front Load Washer
Kenmore Front loader washer doesn't spin clothes as dry as before
The out-put pump is possible clogged up and not moving the water efficiently, also check the pully belt is tight
Dec 14, 2008 | Kenmore Elite 45986 Front Load Washer
Front loader washing machine
Plug off the wall; open up behind. Possible some spring hs come off or a shock absorber is faulty. Can be easily fixed by you. You might have to take the top off.
Jan 07, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
63 people viewed this question
Richard Roth
Richard Roth
Archaeology
Archaeology
Fordexpert
