Question about Dishwashers
We have a Bosch dishwasher model SHV46C03UC (4-5 years old). has always run well. It now appears to be stuck on last cycle (humms). When I went to unload the dishwasher, water had not drained out of last cycle. I turned it off and on, then ran it again - same thing happened. I checked filter in bottom of dishwasher and it was clean. Any ideas?
  • 641 Answers
SOURCE: Dishwasher LD-14AW2, stopped working mid cycle
Since water doesn't drain out ,it could be a clogged in the drain line. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. You should remove this line and clear it form any debris in the hose or the hose connection. Be sure to reattach the hose before starting the dishwasher again. Good luck!
Posted on Sep 15, 2007
  • 833 Answers
SOURCE: Dishwasher draining - Bosch SGV4313GB/17
This is generally because of a stuck diverter solenoid. The water goes to the pump and then is either sent to the wash arms or the drain. Also, check the drain.
Posted on Feb 11, 2008
  • 105 Answers
SOURCE: bosch classixx dishwasher not draining
try removing pump some models can be serviced fron inside well of machine glass can stop the pump from turning
clean out water and remove filters find a screw in base of well remove and remove pump housing check with torch to see if any obstuctions there if not see if the impellor moves around when turned and make shure that the pump is not worn out
Posted on Feb 24, 2008
  • 2651 Answers
SOURCE: Bosch Dishwasher Not Draining
Im really not all that familiar with the bosch unit, but a few things i would ck. when you cancel a cycle (it should drain the water) is it humming??? does it sound as if it even trickling into the sink discharge?? do you have a disposer under your sink that this unit drains into, if so remove the clamp and look for possible obstructions right there.Honestly passed this ill have to defer to someone else sorry and good luck
Posted on Mar 10, 2008
  • 1462 Answers
SOURCE: Bosch dishwasher is stuck on drain cycle
cause is water in the bottom tray which operates an anti-flood switch and all machine will do is drain.
disconnect from mains
remove bottom panel and mop out water and it will work. if fault re-occurs, then you have a leak which you will have to identify
Posted on Oct 20, 2008
I have Bosch shv46c03uc/21 water is cold and cycle runs long
well check and see if the water supply is hooked up to a hot water supply?
Aug 10, 2015 | Bosch Dishwashers
No indicator lights
A Bosch washing machine can make your life easier. Look in the troubleshooting section of your owner's manual for specific information related to the make and model of your Bosch washing machine.
Find more details on Bosch Home Appliances at Appliances Connection online.
Make sure the washing machine is unplugged or the circuit breaker is turned off before you attempt to replace any parts.
Dec 31, 2013 | Bosch Evolution 800 SHE68M05UC Stainless...
My 5-year old Bosch dishwasher leaves a somewhat fine grit on dishes? especially obvious on the inside of glasses. I use only Cascade detergent, use a rinse aid, don't overfill the machine, and always...
I have the same problem with mine!! It's 6 years old, and I'm running loads of dishes through twice. Even that doesn't help! And I rinse the dishes too, so I have no idea where all these "crumbs" are coming from. Will check back for updates. Hope to get this problem solved!
Oct 01, 2010 | Bosch 24 in. SHU6802UC / SHU6806UC...
My dishwasher is not draining
have you checked your float valve and float relay switch
Oct 09, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Cycle time
yes its dishwashers use very little water and energy but,the cycles need to be longer to get the dishes clean. its perfectly OK.(ps use cascade powder if you can)
Jul 24, 2009 | Bosch 24 in. SHU6802UC / SHU6806UC...
Bosch SHU4312 won't finish cycle, won't drain.
The control board on these units is prone to a cold solder joint cracking. I have read that Bosch recommends replacement and will supply the board, not covering labor. I repaired mine prior and have done one for a friend as well. Has lasted several years and counting
The symptom is constant cycling without ticking down the last few minutes
Jun 04, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher soap dispenser won't open during cycle
both have a wax motor on them that needs to be replaced you just remove the panel and replace the wax motor is what its called
Feb 16, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
52 people viewed this question
Top Dishwashers Experts
