Question about Epson Stylus 1400 InkJet Photo Printer
Red cast on all prints
I have an epson 1400 (bulk feed) every time i print a picture it has a red cast?i lowered the amount of magenta to 0% & it was the same, i also checked icm & put this to no coulour adjustment & thats no better then i did a nozzle check & all colours are fine but when i do a print head alignment these are all red & the picture is again still red
plaese help!
bea
  • Anonymous Apr 27, 2009
    I have that same problem. Czerwona - a raczej magenta smuży po kartce przy druku np. niebieskiego, zielonego, zoltego, najmniej smuży przy drukowaniu czerwonym i wlasnie magentą???
    Ma ktos rozwiazanie ????
  • 26 Answers
Sounds crazy, but have you got the LM (light magenta) and M (magenta) tanks or inks mixed up?
Also - check the profiles, if you've got a colour profile set up, you may have applied it twice, which would make a magenta cast...
Posted on May 15, 2009
Epson Stylus SX445W printing pictures with a red tint
Dear Kate,
please run the Epson maintenance software and check your printer cartridge.
i think printer head cleaning is the solution.
please run 1 or 2 cleaning cycles and give a try again.
if problem still there its time to go to technician.
regards,
nuwan.
Jan 10, 2014 | Epson Stylus Sx445w Inkjet Print Scan 5760...
Need to print banner type pictures
No, it is tells you it can print to 19", that is all it will do. I suspect buffering the image and feeding it to the print head is the problem. Make 3 x 16" and join them.
In the old days we used a dot matrix printer and continuous stationery, listing paper.
Jul 19, 2017 | Epson Stylus Photo 1400 Printer
Epson c88 how print in magenta
Do you mean "how do I print text in Magenta instead of black". Well, you change the colour of the text from black to magenta. For example in Word, you would select (highlight) all the text, click on Format, then Font. Then click on the down arrow at the side of the Font Color box, then click on Magenta. To check you have the right colour, click again on the down arrow at the side of the Font Color box, and select More Colors. Then click on Custom. Magenta has a Red-Green-Blue value of 255-0-255. Now print the document and it will come out with magenta text.
If this is not what you want, please come back with a new comment explaining further.
If this advice has been helpful, please rate it.
Jan 30, 2009 | Epson Stylus C88 InkJet Photo Printer
Epson 7800 is printing a magenta cast
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and when the software install asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 09, 2009 | Epson Stylus Pro 7800 InkJet Printer
Epson 1400 simply pulls blank paper through when I try to print
I've had the same problem. Drives ya nuts. Found that error said dvd/vcr release something or other on the epson print monitor. In any case, I found that if the front door isn't securely closed. (the front door you open to insert the dvd thingie, the paper will just feed or not feed at all. Once the door is closed on the front, the feed works fine again.
Smles,
Writenright@aol.com
Dec 14, 2008 | Epson Stylus 1400 InkJet Photo Printer
I have an Epson R220. when I print from iPhoto the image has a magenta cast. I've tried turning off Color management. Any ideas?
Check printing preferences, print the picture as an image. Have you tryed update Acrobat reader?
Nov 05, 2008 | Office Equipment & Supplies
Printing Yellow instead of Red
The colours in the 3 colour cartridges are cyan, magenta and yellow. If you want to print "red", this requires a mixture of magenta and yellow. Thus if only yellow is printed when you should be printing red, it means the magenta is not printing i.e. faulty/empty magenta cartridge or faulty/blocked magenta nozzles.
Please post a new comment if you wish for further help with this problem.
Jul 17, 2008 | Epson Stylus C86 InkJet Printer
Printing
hello,
probably the printer takes his own color-profiles installed by epson.
Click on propriaties of the printer and create your own color-profile for diferent sizes.
you can take the color-profile from a smaler size and save it choosing an other size.
So You also can improove your pictures by changing the color-profile after your needs...
but then you should use the same paper , because different papers give different colors.
you can also improove the colors by choosing-on the profile-another type of paper.
i hope i could help
Oct 16, 2007 | Epson Stylus 1400 InkJet Photo Printer
Magenta cast on prints
probably u need to exchange the cartridge, normally the ones that came with the printer aren´t full, they are just for few prints.
Jan 22, 2007 | Epson Stylus Pro 7800 InkJet Printer
Epson Stylus  1400 InkJet Photo Printer Logo
494 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
