Question about Astar LTV-2701 27 in. HD-Ready LCD Television
I needed to know some codes of capacitor.
HI FRIEND! I was findout almost capacitors of 27,but I still can"t known the codes of 5 capacitors.ITwas covered by the black polyvinyl and have a small stamp with lethering said: (DQG-B6-0974A) for1ca,(DQG-B6-1042A)for 1ca,(DQG-B6-1043A)for 3ca.Therefore I"m very difficult when I find them in electrinic store.SO you can sent me some iformations about,maybe I needed you order list when you bought them...I"m very thankful.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 18 Answers
Apex gt2715 vertical sweep capacitors
Check the filter capacitor to the power supply to vertical output section. Normally, this supply will be provided by LOT. Check the rectifier diode and smoothing capacitor. Replace all the electrolytic capacitors [5 or 6 of them] in the vertical output section. It will be the best remedy. Never forget to replace the supply smoothing capacitor described above.
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1250 posts to different brand TVs now. Pull up older posts there.
Nov 21, 2012 | Apex Digital AT2708S 27" TV
I am trying to find a 270k capacitor for this tv where do i get one
Hello Neonblackfyr, Hi, There are no 270K capacitors, Its most likely a resistor, can you give a snap shot of the part. 270 is the value and K is for kilo OHMs in resistors, if you are sure its a capacitor, 270 means 27 x 10 raised to the 0 power is equal to 27 x 1 which is 27, K is +/- 10 percent, no such capacitor exist, the closest is 27uF but not 270K. here is a link to clear thing up: http://en.wikipedia.org/wiki/Ceramic_capacitor for capacitors and for resistors: http://www.kpsec.freeuk.com/components/resist.htm. Enjoy.
Jan 29, 2011 | Mitsubishi WS-65869 65" Rear Projection...
Can i get a copy of the power supply diagram for samsung 204B syncmaster ,i replaced the capacitors that were inflated in the power supply and in the inverter but the backlight not turn on. i want to know...
jose54tony, Schematics would only be available from Samsung. Rarely do they let them out of there tight grip!! You may need to look at the smps board and inverter board to find bad transistors that may have also died (muerto) when the electrolytic filter capacitors failed. 12fixlouie
May 20, 2010 | Samsung SyncMaster 204B 20.1" LCD Monitor
Pic gets small
hi,few yrs old tv? do you know few basic tip's check the power main board,look for leaky capacitors ,or dry solder's -re solder .and changed the 85'degree capacitors to 105' with the same volts.remember dis-conated from AC main before you do this job.good luck.
Feb 04, 2010 | Panasonic CT-27SL14 27" TV
Need to know the kind of capacitor it uses
Exact number is: 295-60 by CITIZEN,otherwise known worldwide as:MT 621. You can find it on eBay by following this link: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=140099531503#ht_843wt_939 You do not need to buy exactly Citizen made capacitor - any other well known manufacturer is good as well.
Rate me, plz.
Jan 24, 2010 | Watches
Schematic missing - need to know which cond unit
Black wire goes to contactor. On your capacitor the brown wire goes on one side the blue and the other wire from your contactor goes on the other sideof the capacitor. Russ
Aug 07, 2009 | Heating & Cooling
Hi Tim
I got the capacitors from Honson (College Home Hardware) 306 College St. W., Toronto, ON, CANADA, honson12@hotmail.com.. They cost between $1 and $5 ea and there were 26 of them to replace.. As I remember, the bill for the capacitors was about $80. If you don't live in Toronto, you might want to Google yourself another source, but he lets you pick them out of his parts bins and you can get them immediately. His prices were also better than anybody around here. You will also need a roll of 2mm copper desoldering wicking tape ($3), a 150 watt soldering gun, a 40 watt soldering iron and a roll of rosin core solder.
Repairing the board is as easy as 123, 26 times :(
1) Make a list of all of the electrolytics on the board. To order them you will need to supply 3 values for each: The voltage (ie 35V), the capacitance (ie: 220uf) and the temperature rating (ie: 105C).
You should be able to read these values off the ones on the board. There is quite a bit of duplication, so even if the existing one is too fried to read, you may be able to match it to another one the same size color and shape.
2) Put a black mark on the top of each capacitor in the board with a black permanent marker so that you will be able to identify which ones are left to replace.
3) Replace the capacitors one at a time by placing the copper desoldering tape abon the connection you wish to desolder and heating it with the soldering gun until the solder on the board is wicked away into the tape. Remove the capacitor noting the - connection and insert the replacement with the - lead in the same hole as the - lead of the other capacitor went into. Solder in the new capacitor with the soldering iron.
4) Repeat step 3 twenty-six times, check your work often and you're done with the board.
5) Now, cut, drill or punch some extra holes in the metal coffin that the power board sits in so that you wont bake it again, install the power board and fire up the TV.
It worked for me first time, just be real careful that you install the capacitors with the correct polarity and that the new solder joints are shiny and dont bridge to other connections.
Good luck and let me know how you make out.
Jim
Nov 08, 2008 | Astar LTV-2701 27 in. HD-Ready LCD...
Power supply
I have the complete kit of capacitors to repair the LTV-2701 power supply. These power supplies need 20 capacitors for the secondary side of the power supply and 7 for the primary side. I can put together the kit with the 27 capacitors as well.
Let me know if you need further assistance.
Nov 06, 2008 | Astar LTV-2701 27 in. HD-Ready LCD...
RCA tru flat 27 tv problem
the capacitor of vertical section is problem of your tv,so replace the capacitor value 100/50volts in or else all capacitors in vertical section.
Oct 14, 2008 | RCA TruFlat 27F520T 27" TV
Darn blue loading light won't stop
The problem with these units is the filter capacitors in the power supply. They should be removed and replaced with 25 v.dc capacitors...total cost for the capacitors £5. If you don't fancy doing the repair your self, perhaps you know of a good friend who can use a soldering iron!
The capacitors are 2200 micro farads radial mounting, 680 and 1200, all should be at least 25v dc working for a reliable recorder. The existing ones are prone to "leaking" and should never have been used...shame on you JVC!
Regards,
John Saunders
Mar 11, 2008 | JVC DRM10 DVD Recorder
Astar LTV-2701 27 in. HD-Ready LCD Television Logo
97 people viewed this question
Top Astar Televison & Video Experts
Jaime Hernandez
ted dux
Are you an Astar Televison and Video Expert? Answer questions, earn points and help others
