Question about Frigidaire Dishwashers
The door to my dishwasher will not close tightly.
I have checked the load, the basket placements, and the latch and handle. I have tried to close the door multiple times, but it just won't snap shut, and thus, I cannot use the unit.
I will not need your service. Please remove me from your con list.
Posted on Dec 12, 2008
Latch is not tight when closed
Something must be blocking the door from fully engaging. Pull the loading racks out and put them back after checking they are on track and roll freely. Good luck.
Mar 06, 2014 | Frigidaire Dishwashers
PDW8100 Dishwasher went through cycle several times, but I am unable to open the door. Is there a way to get it open? Thanks, Barbara
When your dishwasher door has a problem, check these:
Latch
Springs
Hinges
Door seal
Latch The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem.
If the latch has worn out in a way that makes it impossible for you to close the door properly, you probably need to replace the latch.
Springs Your dishwasher has two springs that counterbalance the weight of the door. If either or both of these are broken, the door feels quite heavy and you need to replace both springs.
Hinges The hinges are important to the door closing properly. If they're bent or deformed, you probably need to replace them. Once bent, only rarely can they be straightened well enough.
Door seal If your dishwasher is new--or if you have just replaced a door seal--the door may be difficult to latch for a week or two. If the tightness persists, though, try adjusting the latch, if it's adjustable. If it's not adjustable, there's probably nothing you can do immediately. But try running the dishwasher on the highest heat cycle to help the seal conform to the door. Otherwise, the seal should compress over time.
Goodluck..
Jun 07, 2008 | GE Dishwashers
The door wont shut properly
see this causes and use the common sense.God bless you
When your dishwasher door has a problem, check these: Latch Springs Hinges Door seal Latch The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem. If the latch has worn out in a way that makes it impossible for you to close the door properly, you probably need to replace the latch. Springs Your dishwasher has two springs that counterbalance the weight of the door. If either or both of these are broken, the door feels quite heavy and you need to replace both springs. Hinges The hinges are important to the door closing properly. If they're bent or deformed, you probably need to replace them. Once bent, only rarely can they be straightened well enough. Door seal If your dishwasher is new--or if you have just replaced a door seal--the door may be difficult to latch for a week or two. If the tightness persists, though, try adjusting the latch, if it's adjustable. If it's not adjustable, there's probably nothing you can do immediately. But try running the dishwasher on the highest heat cycle to help the seal conform to the door. Otherwise, the seal should compress over time.
Sep 19, 2012 | Hotpoint 24 in. FDW60 Free-standing...
E1 ERROR
sound s like you have a bad door latch very easy fix and cheep , if you give me all the info on this unit will locate te door latch and tell you .
Dec 16, 2011 | LG LDF6810ST Stainless Steel Built-in...
The dishwasher door will not latch
When did this start happening,was it all of a sudden.what have you done differently..check that one of the baskets isnt stopping the door from closing all the way..or the door latch may just be broken..or somebody has sat on the door while open & its bent.
May 05, 2010 | Asko 24 in. D3530FI Built-in Dishwasher
The door won't close completely
Hi, Check for the following whenever you have problems in door
Latch: The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem. If the latch has worn out in a way that makes it impossible for you to close the door properly, you probably need to replace the latch.
Apr 12, 2010 | Frigidaire Professional Series 24 in....
The door on the dishwasher squeaks terribly. How can this be corrected?
If your dishwasher door squeaks you have to check the following:
Latch
Springs
Hinges
Door seal
If your dishwasher is new or if you have just replaced a door seal the door may be difficult to latch for a week or two. If the tightness persists, though, try adjusting the latch, if it's adjustable. If it's not adjustable, there's probably nothing you can do immediately. But try running the dishwasher on the highest heat cycle to help the seal conform to the door. Otherwise, the seal should compress over time.
Sep 10, 2009 | KitchenAid Dishwashers
Door won't close wont lock closed
Check the following if you have problem with your doors:
1)The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem.
2)Your dishwasher has two springs that counterbalance the weight of the door. If either or both of these are broken, the door feels quite heavy and you need to replace both springs.
3)The hinges are important to the door closing properly. If they're bent or deformed, you probably need to replace them. Once bent, only rarely can they be straightened well enough.
4)If your dishwasher is new or if you have just replaced a door seal the door may be difficult to latch for a week or two. If the tightness persists, though, try adjusting the latch, if it's adjustable. If it's not adjustable, there's probably nothing you can do immediately. But try running the dishwasher on the highest heat cycle to help the seal conform to the door. Otherwise, the seal should compress over time.
Sep 03, 2009 | Westinghouse Dishwashers
Dishwasher has power but will not start when start button is pushed
hi there,
if your dishwasher is recieving power and the circuit is controled by a switch,the swtich is faulty,check the swtich by multi tester if switch is defective replace the switch with new one.
check also the door if is tightly closed and latched.The diswasher will not operate until the latcht is prop[erly engagaed.to check this close and latch,closed and latch the door,holding the latch tightly inb place,then still pressing the latch closed, turn the control knob to the ON position.check if the dishwasher work,the latch is faulty and should be cleaned and tightened or replaced.best regard
Aug 09, 2009 | Dishwashers
Wil not fill with water
  • Check that the water supply is turned on. The valve may be located under the sink.
  • Check the door latch
  • Test the door switch
  • Inspect the float assembly
  • Inspect the fill tube for kinks
  • Test the float switch
  • Check the inlet valve filter screens
  • Test the water inlet valve
  • Test the drain valve lever arm
  • Check the drain valve
  • The door latch pulls the door tightly closed to prevent water leakage around the door. It is also designed to prevent operation while the door is open. The door latch works in concert with the door switch to ensure that the door is tightly closed and latched. The door switch is a separate part from the door latch and is found inside the cabinet. The switch is off when the door is open. Depressing the switch closes the circuit and enables dishwasher operation. Closing the door does not depress the switch all the way. Only when the door is closed and latched, does the door fully depress the switch.
    If the door latch is not properly aligned it may not pull the door tightly closed and the door switch will not be fully depressed. Unless the switch is fully depressed the dishwasher will not operate.
    It is a simple matter to determine whether the door latch is the problem. Simply open the door, close the latch and select a cycle and depress the switch. Note that if the test is successful, with the door open, the dishwasher will operate and water may spray out. Make sure to first remove all tools from inside the dishwasher. Do not reach inside the dishwasher during the test. Now, inspect the cabinet where the door makes contact with it and locate the door switch. It may have a protruding button or spike or more likely it is a hole with a piece of metal or plastic inside it. You must fully depress that switch. If the switch is recessed, then use a non-conductive object, such as a wooden pencil, to depress the switch
    Sep 21, 2008 | Dishwashers
    Dishwashers Logo
    83 people viewed this question
    Top Frigidaire Dishwashers Experts
    Mike
    Charles T Nevin
    Charles T Nevin
    Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
