Can repair tweeter from Nad 8200? If not, where can i buy them?
  • clodo6 Dec 05, 2008
    Thank's!
  • clodo6 Dec 26, 2008
    I was registred at the Nad Website and they never answer me. Is someone in the world have a tweeter for Nad speaker 8200? I can't have any replacement piece...These speakers was designed by IMF..solid sound!
    1 in. dome A140, 8 ohm, 13/78
    Thank's for all!
    clodo6
    Problem Solver:
  • 41 Answers
Have you tired to contact NAD? They have a very informational website. There is a NAD distributor in MA that may be able to get you parts and/or service you need if you want to try to repair. To use some of the features, though, you may have to register on the website.
Posted on Dec 05, 2008
I just bought a pair of Tannoy Mercury V4 with a broken tweeter. Where do I find a new one?
check to see if you can find it on parts-express.com that's where I get all my speaker stuff
May 28, 2013 | Tannoy Audio Players & Recorders
My Creature II speakers still work however the big subwoffer isnt working. I think it is probably just the cord but is there a way I can be sure
Which cord are you thinking of? If you look at the subwoofer there are 4 cords. One to the left tweeter, one to the right tweeter, one to the computer and one to the power.
  1. As both the tweeters are woring then those 2 cords are OK.
  2. As both tweeters are working then the cord to the computer is OK.
  3. As both tweeters are working then the cord to the power is OK.
  4. Therefore it is not 'just the cord.'
What I would suggest is checking that the sub has not been turned down - one of the silver posts on the sub. If that is not the case and you cannot turn the sub volume up then I suggest that you replace the system. They probably cost more to repair than to buy new.
Sep 30, 2011 | JBL CREATURE II Computer Speakers
Hi, I have a 304 NAD amplifier which occasionally distorts on one of the tweeters. I have taken it for repair several times but no one succeeded in fixing it. I have not replaced it because I am so...
Is it on all audio sources or only certain ones? Have you swapped the speakers Left-to-Right to isolate the speaker from the signal chain as a cause?
If it's only an analog source doing it I would suspect a bad audio cable or a switch somewhere in the signal path. Typically, it might be a switch you rarely use, like a Tape Monitor. It's wise to occasionally (with power OFF) operate all manual controls throughput their ranges a number of times to wipe oxides from their contacts.
Feb 04, 2011 | NAD Audio Players & Recorders
My mordaunt-short avant 908i front left speaker aluminum tweeter stopped working... no sound coming out, however two midrange speakers functioning just fine.
I had similar problems my tweeter was blowen and it had to be replaced... I actually blew the speaker many times using a NAD amp as there were spikes coming from the amp. I changed the amp to a Marantz PM7200 and have had no problems since.
May 06, 2009 | Mordaunt Short 908 Main / Stereo Speaker
Eratic volume
Hi....
ONe of the leads on the CD cable has a broken ground (thats why it hums loud)
The speaker that has only the tweeter working: The woofer is blown in the speakers.
Check also for good solid wire connections at both ends of your speaker cables
Mar 29, 2009 | NAD C372 Amplifier
NAD T760 remote control
You could buy a universal remote control and try the following NAD audio remote codes to program it with:
NAD
575 773 975
I read somewhere else that the 'Supplied Code for NAD receivers' was 033, but cannot confirm this. Try the first 3 first.
Universal remotes tend to be pretty cheap, certainly cheaper than buying one from NAD.
Good Luck
Chris (ziraffa)
Dec 20, 2008 | NAD T760
HELP PLEASE. NAD 370 JUST DIED...
This could be as simple as a bad connection at the voltage regulator IC or blown output transistors. If you have a multimeter and some experience with electronics repair, this should be fairly straightforward.
Let me know and I'll try to walk you throught the repair.
Dan
Sep 07, 2008 | NAD C370 2-Channel Amplifier
Focus FK-8200 Keyboard
FK-8200 become so precious now, because you can not buy it any more.
Sorry, I just read your problem, hope it's not too late. There is a very easy way to fix it,
1. remove all screws from the back of you Fk-8200
2. cardfully opne the upper case
3. you will see a "film" type of connector on the upper-right corner of the keyboard -- check it up (move it a bit that usually will fix the problem ( bad connection).
May 02, 2008 | Focus Electronic Focus FK 8200 Keyboard
Tweeters only works when touched!
This is not a solution, but I have the same problem. Obviously, the problem is with the tweeter not the crossover. I can't find a replacement tweeter so i am about to take it to my local stereo repair store and see if they can fix it. If you find a replacement tweeter, let me know.
Oct 13, 2007 | Audio Players & Recorders
Laser unit NAD 5100 Monitor Series
Hey, I think you can bye new laser here http://www.pltv.org.uk/laser.htm I have a nad 5300 monitor series, same laser as 5100, you can buy the hole cd player from http://www.miguelovitch.dk Laser work, but problems with cd transport. When i 'help' the cd transport, cd play as expected. And i agree, it is a nice cd player, also i have heard lot of nad cds on quad 405, sounds realy good. Try to visit my site, i also have a lot of free schematic for nad, denon, quad and mora. Also repair notes for amplifiers, tech videos, diy schematics and more.. Also at this moment i am working on a new 'nad cd service movie) including cleaning, maintenance, repair and more on nad 522, 501, 502 c521 and more see you best regards michael miguelovitch http://www.miguelovitch.dk
Aug 14, 2007 | NAD C521 CD Player
 Grubhead
Grubhead
