Question about Kitchen Ranges
Amana Electric range ART6510 had teh bottom heating coil go out. coil actually burned out and broke. WE replaced coil but now the electric display is not lighting up. Stove top sill work however?
  • 334 Answers
You most likely pulled a wire loose when you were working on it.
Unplug the unit
Take the panel off and look for loose connections
Posted on Dec 04, 2008
Electric range not heating
You should check your Hi Limit thermal switch part#74008715 you will have to remove the oven from the wall to access this part.
http://www.on-timeappliance.com/ovenrepair.html
Mar 24, 2012 | Amana Kitchen Ranges
Element burned out on the bottom of the oven. replaced the element, now I get no heat on either element. It just clicks twice and stays at 100degrees on the display.
IF ELEMENT BLEW OUT WHEN IT WENT BAD MAY HAVE KNOCKED OUT THE RELAY ON CONTROL BOARD HAVE TO REPLACE BOARD IF THAT IS WHAT HAPPENED
Jul 21, 2011 | Amana AER5515QA Electric Kitchen Range
Heat element burnt out replaced with new, still will not heat
one of heating element burns out how can i replace it? amana brands cooking range
Apr 03, 2011 | Amana AER5515QA Electric Kitchen Range
Oven will not heat up... the bottom coil is cold. What can be wrong, how do replace coil?
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Nov 22, 2010 | General Electric JBP22B Range
NO HEAT, RUNS LOAD, SMEELS LIKE SOMETHING IS BURNING
The thermostat could be fried. As in really fried.
Jan 16, 2009 | Amana NDE2330AY Electric Dryer
Bottom element on range doesn't work although its been replaced
You have to replace the clock. That will definately fix your problem.
Nov 17, 2008 | Amana AER5515QA Electric Kitchen Range
BOTTOM COIL DOES NOT HEAT UP
my bottom element in my Whirpool range needs to be replaced. It is hidden. How do you replace it?
Jul 20, 2008 | Whirlpool RF364 Electric Kitchen Range
Bottom element burned out, replaced with a new one
there does appear to be a high limit thermostat located on back wall, diagram not really clear where but would be wired inline with the bake element . if thats blown there would ne no bake/ probably no broil either
Mar 06, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Oven will not heat past 220 degrees
Check your bake element, I had the exact same problem and found the bake element had burned in half. The broil element comes on during preheat and kicks off at around 220 degrees.
May 06, 2007 | Amana AER5515QA Electric Kitchen Range
Kitchen Ranges Logo
139 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
