Question about Fisher and Paykel AeroTech Double OD302 Electric Oven
Oven wont work after cleaning
We cleaned our oven for the first time today; its about 4 or 5 months old... (in our new kitchen that is) and now it wont work at all. the lights light up but the oven wont go on.. nor will the one on the bottom which I did NOT clean. Any suggestions?
  • 5 more comments
  • Karen Stevenson Feb 09, 2007
    Thanks. We have spent about 4 hours on the phone yesterday trying to find someone who WILL fix it. Nobody seems to, and if they do, its not for two weeks. I bought a gourmet oven cause I USE it every day. I dont think they give a hoot.
  • Karen Stevenson Feb 13, 2007
    Thanks. But we tried that too. Someone finally came out and told us we burned the heating element; that it happens alot... even to him twice on his own oven. he ordered a part, with a new fan that runs while the oven is cleaning..or something like that. And all WILL be well... but Im still without a stinkin oven now..... VERY frustrating.
  • jenniferab Nov 12, 2007
    Yep, just self-cleaned my top oven and it's not working. This is the second oven failure I've had since I bought the appliance. I had a "high altitude" thermostat added to my control panel, but that doesn't seem to have helped. I will follow up after the repair service comes. I'm going to try turning off power at the breaker switch and see if it helps, but I'm not optimistic.
  • wholefoodmom Nov 16, 2007
    Same exact deal with me. Did any of you turn off and on the switch at the circuit breaker? Did it work? Someone is coming out tomorrow to look at it and he said it is probably the board. Has anyone had a solution to the problem? Please let me know ASAP. How am I going to cook Thanksgiving on the BBQ pit?
  • Aerovexed Jan 10, 2008
    Exact same problem, double oven, 4 months old, after first self cleaning cycle of top oven, both ovens will not heat. All lights and fans work, resetting breaker and resetting clock changes nothing. Service person didn't even know how to open the top to see the schematic. Suspect the "thermal cut outs or thermal limiters are tripping. Apparently,
    this is not uncommon and they may have devised a new limiter kit. This is according to an article I found on F&P Aerotech ovens archived on Sept. 6, 2007, link:http://www.servicetechhelp.com/index.php...
    Here is another similar story:
    http://www99.epinions.com/content_170960...
    Seems like a trend, what to do? Not impressed with their "service network," one of the three numbers they gave me had stopped doing warranty service for F & P for several years. Waiting to hear from service company about which parts have been ordered, they say 5 business days is average. Again, my oven seemed to be the first F & P that the service person had ever encountered, not a good sign.
  • aimegloff Nov 17, 2008
    My oven temperature is no longer calibrated and I cannot find anything in the installation or user manuals. Neither can my repair guy. How do you recalibrate it?
  • annsera Dec 28, 2008
    I bought one the F&P double oven in March 2005 and it's been broken twice a year ever since. I cook quite a bit, and this is a serious problem for me.
    The first service person who came, under warrantee, decided that the heating element was burned. He couldn't remove the heating element from the oven and thought you needed to pull the entire oven out of the wall in order to just replace the heating element. In doing so, he spit the custom cabinets apart.
    I complained to F&P who never responded. We also never got any responses to further warrantee calls. We've had to fix the oven on our own ever since (but actually, we do a better job!).
    I have found the following problems so far:
    1) heating element no longer working.
    2) screws at side of oven work loose and fall out (no one in australia ever heard of lok-tight?). When this happens, the sensor which detects that the oven door is closed no longer works, and the whole oven fails because it thinks that the oven is open all the time (and it's best to take out the light bulbs else you risk that they'll be on all the time).
    3) F&P designed the control board with absolutely no circuit protection. If you replace a light bulb with the oven receiving power, you risk burning up the circuit board! And yes, that's exactly what happened -- really costly.
    4) microprocessor shot after cleaning
    5) screws that hold handle in place very loose, handle wiggling
    6) fancy finish flaking off under handles and starting to flake off elsewhere
    7) about one week after I got the product, it was obvious that the inner window of the oven was not well sealed because a casserole dripped between the inner and outer windows (lovely). This problem progressed until both inner windows rattled, requiring repair. Actually, I have to repair this now, too -- the problem continues.
    8) multiple lights burn out. There don't seem to be USA replacements and the F&P replacements cost 30$ each...excellent.
    So, there you have it -- reasons to never buy this oven. If it worked and was durable, maybe it would be nice.
    Right now, I'm trying to determine whether the behavior of my non-working lower oven is a burned out heating element or a dead microprocessor. I have a working fan and light in that oven which would lead me to think that it was the element, but people here say that since this was after a clean, it's likely to be the microprocessor. Does anyone know what to do to distinguish?
I have a single wall oven by fisher paykel I have had the same problem with it not working after the last self cleaning mode.
no fault codes show and the fan and light comes on and blows out cold air. I have reset the power and still it wont heat. broiler is out too. I called the store where purchased and was told they will order a part and come out. This must be an ongoing problem as they did not need to come out and trouble shoot .
I will have to barbeque for a while !
Posted on Oct 19, 2007
    New Friend:
We have had the same problem and the repairman said they are not meant to work at high altitudes. I am now trying to find a product for cleaning it without using the self-cleaning feature. Any suggestions? I called F-P and they did not call me back when they said they would.
Posted on Feb 03, 2013
I regret buying the flash Titan oven, I have had one replacement and almost all parts have been replaced in that one as well. It is getting to the stage where I am scared to clean it! But I did yesterday and I was a nervous wreck when F7 came on (and the dreaded Beep Beep) I managed to reset this, but I know I will have problems in the future.
My warrenty for this one runs out this month, I dread to think of how much this will cost me in the future.
I would never buy F&P again (that is my solution to the problem)
Posted on May 24, 2008
Don't buy Fisher & Paykel Ovens
Posted on Jan 22, 2008
I have this exact oven and it is less than a year old. We have had six repairs, two of which on a new replacement oven F&P assured us would fix the problem--IT HASN'T! I live at high altitude (about 5000ft) and I've had all the fixes F&P can think of, namely replacing the thermostat kit for high altitude. I don't have any faith that they can fix the problem. The only thing I can suggest is keep breaking (cleaning it) it often so that F&P has to keep on the problem or give you a refund; this is what I'm doing. Gendos' suggestion is great and may work on some ovens; but F&P oven owners know from experience, once it's cleaned, only a service call can make it work again. Good luck and please keep us all posted on your developments.
Posted on Feb 25, 2007
    Scholar:
  • 76 Answers
Kcupcake If your oven is just 4 or 5 months old, the only thing I could suggest is to call a manufacturer authorized service. Your oven is under warranty. Because it's under warranty, any attempt to repair will void it. Gendos...post back
Posted on Feb 09, 2007
  • Gennadiy Kagan Feb 13, 2007
    kcupcake
    did you try to reset the power? If not, locate the oven circuit breaker and turn it off. Wait couple minutes and turn it back on. It works the same way as you reboot your PC when it's got stocked.
    Gendos
Oven enamel
your wiring is switched up. its a 220v check wiring diagram on the oven. make sure the neutral isn't switched around
May 28, 2017 | Ovens
Nardi oven F86
I have a Nardi f86 but I Don't know how can I used the Bud ( knob ) of the furnace, please can you help me, thanks verf much, greetings of ANNE
Jun 03, 2013 | Ovens
Has anyone had a problem with the inner glass on the Lamona oven door exploding. Mine just has! It's only 18 months old and hardly used. I wonder if it's the difference in temperature betweeen the hot oven...
We bought our kitchen from Howden's as well about 15 months ago. They installed a Lamona double oven and hob. Last night when opening the door to the bottom oven our glass on the inner door exploded as well. Maybe there was a batch of defective ovens as ours sounds as though they mat have been bought/manufactured at the same time.
Mar 07, 2011 | Ovens
How do I clean my Electrolux Icon Oven?
Which Electrolux Icon Oven do you have?
For most ovens, with a use a cloth and hot soapy water (do not use an abrasive cleanser or an oven cleaner), clean the door and the frame of the oven outside of the gasket. Similarly, remove the heavy amounts of spilled food (get rid of sugary or highly acidic food spills particularly) in the oven. Take the oven racks and oven rack support, broiler pan and insert, utensils and any foil out of the oven. Then close the door. If you have a single oven, press Clean. If you have a double oven, select the oven to clean and then press Clean. Select the duration of the cleaning cycle (either by hours (2,3, or 4) or cleaning level (Lite, Medium or Heavy)). Some Electrolux ovens have buttons for the cleaning level otherwise use the up/down arrows. Then press Start. The door will lock and remain locked until the oven cools after the cleaning process. For a delayed cleaning cycle, make sure the time is correct on the clock and press End Time and enter the time you want the cycle to end and then Start.
Make sure the kitchen is well ventilated.
The manuals are available for most from the Electrolux site. Start at http://www.electroluxicon.com/ and search for your model. (Either search on the model at the top right or under Kitchen Appliances) If you find a page for that model, it will have a Specifications and Guides tab. The manual is in that tab as a pdf.
I hope this helps.
Feb 06, 2011 | Electrolux Ovens
When cleaning my oven, the whole house fills with smoke.
sell cleaning on ovens just causes problems like this, it is normal. it cleans by burning everything inside at high temp. i always recommend cleaning the old fashioned way, once a year , with oven cleaner, or as req. roasting an oven itself to clean it is insane i think
Jul 23, 2009 | Ovens
I am in the process of cleaning my Whirlpool self cleaning oven and it seems like there should be about 2 hours left on the timer and when I came out to the kitchen the timer was off and the door is still...
most likely the safety latch got stuck from the super heat of the oven while cleaning. try tapping the latch with a screwdriver and hammer, spray a bit of wd-40 on it wont hurt. i believe the self cleaning on ovens is crazy, as the heat damages things, including the finish of the unit.
Jun 22, 2009 | Whirlpool RBS275PD Electric Single Oven
Self cleaning oven won't start self clean mode
NO IN ORDER TO ENGAGE IN SELF CLEANING THE LOCK MUST FIRST ENGAGE. DOOR LOCK ASSEMBLY FAILURE
Apr 27, 2009 | Whirlpool RBD305PD Electric Double Oven
F8 / Convection portion of top oven doesn't work
F8 Oven door lock failure Check lock relay and door switches.
Apr 02, 2009 | Frigidaire 27 in. Electric Gallery Pro...
Self cleaning
Sometimes, according to what I've seen.  My theory is that the elements are probably covered in grime and this causes the damage.  As far as the control...I don't think that makes sense.
Never use cleaner on the elements..also causes damage.
A typical duty cycle for cleaning is 2- 2.5 hours.  Longer and you could burn them up, too.
Nov 28, 2008 | KitchenAid KEBC101 Electric Single Oven
Fisher and Paykel AeroTech Double OD302 Electric Oven Logo
1,700 people viewed this question
Top Fisher and Paykel Ovens Experts
Joseph Hoffmann
ray gallant
Ap12
Ap12
Are you a Fisher and Paykel Oven Expert? Answer questions, earn points and help others
