Question about Kenmore 30169 Electric Single Oven
Oven will not come on, no power, when it does work it will make a bleeping sound and blink F7
The oven I have isn't working. It doesn't come on. This is the first time this has ever happened. I've at this residence for 6 years. The only problems we would have is it would make a beeping sound and blink F7. We don't know what F7 means. How we would get to stop is by cutting the power, that means would go to the circuit breaker and cut the power off to the oven. I would like to know why it is working anymore and what do I need to do to get to work.
  • 87 Answers
Check the power to the oven, maybe a bad breaker.
Posted on Jun 10, 2007
Kenmore wall oven digital screen is blinking F7? it has a digital button screen. i can clear it but it comes on again a minute later. no other buttons work?
Here is the list of f7 codes for this oven and what they mean and what needs to be checked and fixed
F7 Function key shorted Replace touch pad
F7 Function key shorted; too hot at the clock assembly (also called the ERC) or shorted touch pad or clock assembly (also called the ERC) Replace touchpad or ERC
F7 Lock motor relay watchdog circuit is active when it should be off Microprocessor checking the operation of the EDC lock, relay failed. Replace EDC.
Oct 19, 2010 | Kenmore Ovens
Oven keeps blinking F7 AND WILL NOT WORK
Hi
Thanks for using FixYa. Error F7 on your Kenmore means that the keypad is shorted or stuck and to resolve this issue you’ll have to replace the electronic range control (ERC). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 15, 2010 | Kenmore 42161 / 42169 Electric Single Oven
I am getting an F7 error message more and more frequently. When the F7 message is on the display, my kepad does not work and I get an annoying beep. When I press "Clear" the F7 and beep will stop until the...
Hi
You don't say what type of GE oven this is so I will advise the following;
On a GE range oven F7 indicates either a function pad button is stuck or the clock on the oven is malfunctioning
On the 99 Range oven F7 indicates a shorted Clear/Off Key due to membrane switch or a shorted control or connector
On the GE XL44 Self Clean Oven F7 is Stuck keypad or control relay malfunction
Hope this helps. Please remember to rate my answer. Thank you.
Jul 07, 2009 | GE Ovens
Oven emitted black smoke and F7 beeping on display
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Mar 30, 2009 | GE Profile JK915 Electric Single Oven
DCS wall oven F7 ERROR
I TRIED SOLUTION FROM SYMAR DATED MAR 14, 08 IT WORKED FOR NOW. I HOPE IT WILL CONTINUE WORK UNTIL SERVICING...COME MORNING.
Feb 09, 2008 | DCS WO-130 Stainless Steel Electric Single...
Power surge, and pad won't work
This may be related to the F7 problem. I have a post on this site.
Go to the following link:
http://www.fixya.com/howto/h155060-dreaded_f7_error
I have shared this fix with over 1400 folks and most report success. I hope that it works for you too.
Nov 20, 2007 | GE Profile JKP56 Electric Double Oven
Ge wall oven display says F7
Your problem is most likely caused by a short between sections of the ribbon cable between the touchpanel and the electronic control. The solution is to insert a slip of paper between the sections where it exits the touch panel. See the attached photo. If you have a metal touchpanel, insert slips of paper on either side of the ribbon cable as well. CAUTION: Be certain to turn off the power to the oven before you poke your fingers in and around the touchpanel. My solution has worked for hundreds of folks. Don't worry about the paper burning. If you have questions, contact me at hutchipop@yahoo.com.
May 29, 2007 | GE JKP30WMWW 27" Built-in Single Electric...
Kenmore 30169 Electric Single Oven Logo
133 people viewed this question
Top Kenmore Ovens Experts
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
