Question about Gateway FPD2275W LCD Monitor
Monitor screen ia blank
I have a gateway fpd2275w 22" flat screen that went blank,in the right light i can see the screen is there but its so dark it just looks blank.
can you help?
I just had the same problem, I hit th F8 key at start up & rebooted from the last time my computer worked without any problems,,,& it worked.
Posted on Dec 18, 2008
  • 148 Answers
Open it and see if you can find a blow capacitor on the logical lcd board...it´s very common to happen in this kind of model...
Good Luck!
Posted on Dec 04, 2008
My monitor does not turn on and the power button light keeps blinking ... <my Gateway monitor light blinks blue slowly but the screen is blank
This is usually a sign that there is no signal going to your monitor, check all your cables and then reboot.
Jun 28, 2010 | Gateway FPD2275W LCD Monitor
GATEWAY FPD2275W 22" will show everything when unhooked from pc then reconnected but within seconds goes to a black screen. I have 2 and the other one works fine so it is definitely the monitor giving the...
Chances are that some capacitors in the power supply have failed. some monitors are known for this. The parts are readily available, but they do solder in.
Nov 13, 2009 | Gateway FPD2275W LCD Monitor
My Gateway FPD2275W LCD monitor has just failed.
Trying to find replacement parts for your model could be a task. LCDs are so inexpensive these days it would be cheaper to just replace it. Not sure if you have a Frys computer store nearby but I saw a 22" LCD for 129.00. Check your local electronics stores also. If you did find the part for your Gateway consider the cost and installation fees.
Eric
Oct 23, 2009 | Gateway FPD2275W LCD Monitor
22 inch monitor won't power up, went blank after two years. Power button does not even light up.
It seems to be a HW issue Staright away>
connect it with a diff power cable> see if the same happens > if it does> then the monitor has gone bad
Oct 08, 2009 | Gateway FPD2275W LCD Monitor
Monitor goes blank after it comes on for two seconds
bad capacitors on the power board internal to the monitor they need to be replaced, let me know what you would like to do
Mar 22, 2009 | Gateway FPD2275W LCD Monitor
Gateway 22" flatscreen monitor won't display after startup
Monitor has blown capacitors internally on the power board I can fix these let me know what you would like to do.
Mar 04, 2009 | Gateway FPD2275W LCD Monitor
LCD monitor goes blank
It appears that the display resolution set in your display properties is out of the range that the LCD can display.
Try this.
Boot to the ENABLE VGA MODE by pressing F8 to get the Windows Boot Menu. If you can get to the desktop, then go to display properties, and see if you can change the resolution to higher settings and maintain video. (If the video blanks out, then it should revert to the previous setting in 15 seconds)
Aug 03, 2008 | Gateway FPD2275W LCD Monitor
Syncmaster Screen went blank on my Dad
check and see if there is any buttons on the side of the monitor or in the front area. also, check wiring plug connections.
Jun 21, 2008 | Gateway FPD2275W LCD Monitor
Dell 1503FF flat panel monitor is blank
If you power switch does not light up. It possible that the Horizontal Output Transistor (HOT) is shorted.
Mar 31, 2008 | Gateway FPD2275W LCD Monitor
22-inch Wide screen X2Gen LCD Monitor
Monitor Help CH000241, No display on the monitor. CH000242, Distorted or skewed image on monitor. CH000243, Monitor has a tint of one color.
Good Luck, Please dont for get to Vote/Thank You.
Dec 19, 2007 | Gateway FPD2275W LCD Monitor
Gateway FPD2275W LCD Monitor Logo
195 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
