Question about GE Spacemaker JMP28 Electric Kitchen Range
GE oven I have slide in oven. The burners all work, but the oven has every possible feature lit up and will not operate. The clock, delayed time, clean(which we don't have on this range), the Set button and clean door, and the numbers 888 (could be 000 not sure) all displayed. I am unemployed and cannot afford a new stove and service call. Any help is appreciated.
  • Carol Bratcher Feb 11, 2007
    Thank you so much. I will try that and then post a response.
    Problem Solver:
  • 10 Answers
Try turning off the power to your oven and turning it back on. if that doesnt work then you are going to need a new control board.
Posted on Feb 10, 2007
Bake element wont cycle the temperature
PDF]ELECTRONIC OVEN CONTROL Control Pad ... - Frigidaire
manuals.frigidaire.com/prodinfo_pdf/Lassomption/318204143.pdf
Note: The oven function will not work if the time of day clock is not set. ... The ovencan be programmed for any temperature from 170°F to 550°F (77°C to ... Can be used with BAKE TIME to program a delayed bake cycle. Timer Pad- Used to.
[PDF]ELECTRONIC OVEN CONTROL Control Pad ... - Frigidaire
manuals.frigidaire.com/prodinfo_pdf/Lassomption/318204125.pdf
cycle. Bake Time- Use to enter the length of the baking time. Timer ON/. OFF- Use.... It does not disable the clock, Kitchen Timer or the interior oven lights. TIMED. DOOR .... The Preheat feature will bring the oven up to temperature and.
Gas Oven Repair Manual - Chapter 6 ' Gas Ovens Manuals
www.appliancerepair.net/oven-repair-6.html
If it does not ignite, you certainly do not want the gas valve to stay open. ... these sensor bulbs do not cycle the burner on and off to maintain oven temperature.
How To Fix An Oven Door That Won't Open After A Self ...
Jan 28, 2016 | Frigidaire Kitchen Ranges
GE JS900 electric range stovetop works fine but no lights or clock on control panel so the oven cannot be turned on.
You will probably have to replace the main control board- the cooktop operates independently of the ovens, so your symptom is not uncommon... GE Range Stove Oven Oven Control Board WB27T10416
Jan 09, 2016 | GE Kitchen Ranges
My stove is a GE and everything works but the burners and oven.
check your breakers everything you said means not enough voltage
Apr 05, 2014 | GE Stove/Oven/RanSurface Burner Knob -...
GE Spacesave microwave won't work. Display says REM. What does that mean?
"REM" is "reminder". That's covered in your owner's manual.
Here's a sample:
"The Reminder feature can
be used like an alarm clock
and can be used at any
time, even when the oven
is operating. The
Reminder time can be set
up to 24 hours later.
1 Press REMINDER.
2 Enter the time you want
the oven to remind you.
(Be sure the microwave
clock shows the correct
time of day.)
3 Select AM or PM.
4 Press REMINDER. When
Reminder signal occurs,
press REMINDER to turn
it off. The Reminder
time may be displayed by
pressing REMINDER.
NOTE: The REM indicator
will remain lit to show that
the Reminder is set. To
clear the Reminder before
it occurs, press
REMINDER, then 0. The
REM indicator will no
longer be lit."
Jan 27, 2011 | GE Microwave Ovens
Microwave won't heat
you will need the magnetron replaced $150-$180 price range part and labor
Feb 04, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile gas range - Model Number removed by previous owners. Black slide in range with warming drawer - 5-10 years old. Digital oven controls on left side Broil and Bake functions are reversed. When...
Unplug the range.
I would open the control console and locate the BAKE/BROIL terminals on the Oven control. I would reverse the wires,plug the range in and try again.
Sounds to me like someone has changed out a part and wired it wrong.
Jan 03, 2010 | GE Kitchen Ranges
Hi, I cannot get the oven element or the back left burner to heat up.I found a blown 15 amp fuse blown in the oven and replaced it but still no power to the two elements. I took out the oven element to...
I take it when you mention burners you are refering to electrical hot plates?
If you have tested with 110V --even nthough it should be 240V then I can assume that the hob is working.
Possible cause is the regulator.
Regards
Aardvark Repairs
Nov 16, 2009 | GE Ovens
Delay in oven burner to light after pilot is lit.
Usually delayed lighting on a standing pilot system is caused by a gas pathway that is dirty from spilled food or grease. If you can remove the burner assembly and clean it that will correct the problem. If there is a removable plate above it then you can remove that and get access instead of removing it. Pilot ignitions work by creating a column of gas between the pilot and the burner that is established when the burner is turned on kind of like a fuse. A small tube my be used to establish the column of gas between burner and pilot and it may get blocked with food that overflows. Sometimes the pilot is just located right next to the burner and may get partially blocked or the orifice in the burner next to the pilot may be blocked. Cleaning all this helps. Be very careful with gas. Work in a well ventilated area. Turn on gas very briefly to run an ignition test. Turn off the gas and vent it off if it fails to light in about 5 seconds. Unburned propane drops to the floor and collects. Natural gas rises. Be aware of this when you ventilate.
Dec 23, 2008 | Magic Chef Ovens
Top burners often wont light if oven is already lit
I have fix that problem before, the oven heat is soficating the top burners, you will have to adjust top burners with the oven on, so that they will light by them selfs.Or put a shield under the cook top section on the back, so that the heat will not come to the burners where they get the oxigen.
Dec 07, 2008 | GE JGBP28 Gas Kitchen Range
GE Spacemaker JMP28 Electric Kitchen Range Logo
249 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Steve Allison
Steve Allison
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
