Question about Electrolux UltraLux 2000 Bagged Canister Vacuum
Power nozzle not working on my vac but does on another vac
My power nozzle will not work on my vac. It works on another vac. I tried the hose and powervac from the other vac and it will not work on my vac. So, if my hose all the way down to my power nozzle is fine why doesn't it work on my vac? I can use the hose fine for sucking up things on my vac just not able to use the power nozzle. I have Ultralux 2000.
  • 75 Answers
Re: Power nozzle not working on my vac but does on...
If pushing the reset button doesn't help try having your local Aerus dealer check out the 2 prongs in the power head where it all connects. Sometimes they go bad.
Posted on Jan 26, 2008
  • 28 Answers
Is there a reset button somewhere on the power nozzle? Most of these have a breaker to prevent the motor from burning out.
Posted on Sep 06, 2007
0 characters
3 Points
How do I fix the beater bar attachment on my Oreck Canister Vacuum?
Well Anonymous, unless you have a continuity tester I'd say you will most likely need to take your machine to a vac repair shop. You need to determine if there is voltage going to the power nozzle portion through the hose and the wand. This is where the continuity tester comes in. If you have one and know how to use it, check the hose to make sure there's a clear path there for the juice to flow, if so, then check the outlet on the vacuum itself. If all is kosher at these two points then check the power nozzle itself. Somewhere along the line you will find an open circuit, that will be the problem that needs to be repaired or replaced. If you take it to a vac shop for repairs, they will do all this for you and then tell you what needs to be repaired and how much it will cost.
Oct 17, 2015 | Oreck Vacuums
I have a Electrolux Guardian Encore E and the power head quit working. It has suction power head off and all other attachments work.
Try this. Remove the power nozzle from the lower wands. Remove the wands from the hose handle. Snap the power nozzle directly to the hose. Make sure all switches are turned on and try it. If the power nozzle now works, there's an issue with one or both of the wands. If the power head does NOT work, you've secluded the problem to the power head. With that being said and although it could be a power nozzle switch or a wire that disconnected inside, it's most likely the power nozzle Elbow assembly wiring that's worn out. This has been an issue with this model after so many years and you simply need to replace the Elbow assembly.
I hope this helps and let me know if I can be of any more help. Hope this helped. :-)
Apr 02, 2015 | Electrolux Vacuums
Power head does not work canister does . There is voltage at the power head.
Although it could be a multitude of things that keep the power nozzle from operating properly, the most likely is, since it's an Epic series, Is that the power nozzle elbow assembly needs replaced as the fine wires and top of the elbow tend to break/short after 5-10 yrs. of use.
It's also very well possible that the power nozzle reset switch or hose switch at top of handle is defective. Try plugging the power nozzle directly into the hose handle assembly and turn machine on. If the power nozzle still doesn't work, it's definitely a problem directly with the power nozzle.
Hope that helps!
Mar 14, 2015 | Electrolux Epic 6500 Vacuum
Electrolux EL7055 powerhead not working
Have you tried testing the continuity in the hose, wand, and power nozzle? You can also try putting the hose directly in to the power nozzle. If you still need help with you electrolux vacuum try contacting
Nov 17, 2013 | Vacuums
What do I do when there is no suction. My central vac just stopped picking up and though I emptied the machine and replaced the filter there continues to be no suction.
1. If it's an older model, the hose is likely well worn and probably has leaks at each end where it attaches to the handle and connector at the other end. If this is the case, a new hose is needed.
2. A blockage in the hose. To check the hose for blockages, detach both ends and drop a coin down one end. Lift the hose a little at a time so coin drops out the other end. If it doesn't, there's a clog. Please don't try to take it apart to remove the clog. If you can't get it out, take it to a reputable vacuum repair shop and let them.
best way to clear an obstruction is to blow it out by attaching the wall end to the exhaust of a shop vacuum, or using an air compressor.
You can try holding the wand end of the hose directly to the CV in port and turning the machine on. This provides essentially the same action as the previous method.
If neither of these work, try a combination of the two. Or using a shop vac, hold the wall end to the exhaust of the vacuum and the wand end to the in port of the shop vac. Turn shop vac on and the obstruction should come out.
Borrow a good strong shop vacuum if you need to.
If these methods fail, take it to an authorized Aerus Electrolux store and have the service tech try to clear it. Care must always be taken when trying to clear an obstuction with a long object, especially if it's pointed. I've seen many hoses that have shorted out and even caught fire due to the wiring accidentally being "nicked
3. Is there suction at the end of the hose, or is it just at the power nozzle there's none. If the hose has good suction, check the power nozzle airway. If it's blocked it can easily be cleared by pushing the clog back toward the brush with the handle of a wooden spoon, or other similar object.
Jan 15, 2011 | Electrolux Pu3650 Central System Vacuum
We have an electrolux central vac. The power head won't turn on. It has a 3 way switch on the handle. When to the left it is just air for the floor. center is off and to the right is the power head. ...
I assume you did press the reset switch on the power nozzle. If so, there are a number of things that could cause this. To rule out the hose and power switch, connect the Sidekick (if you have one) to the handle. Turn vacuum on. If the sidekick runs, the problem will be in the wands or power nozzle. Try connecting the power nozzle directly to the hose. If it runs, the problem is the wiring connections in the wands, or from the lower wand to the power nozzle. Check all connections for discoloring and broken or cracked wand fittings.
The wiring in the elbow of the PN is a fairly common problem, especially with certain models. A piece inside breaks, resulting in the wire connection to not make contact. No contact means the PN motor won't run. And there's always the possibility that the PN motor is bad.
If the Sidekick doesn't run when connected directly to the hose, the switch could be bad, the wiring in the hose could have broken, which is another common problem in older hoses, or the ECV board in the vacuum could be bad.
If the problem hasn't been resolved at this point, it's best to take the entire machine to the Aerus Electrolux store near you for a free diagnosis.
Jan 07, 2011 | Electrolux Central Vacuum
My Ultralux 2000 vacuum power head does not work on my machine but does work on a different machine. What are the possilbe problems? I tried replacing the hose with a new one and that didn't help.
It's probably due to bad wiring connections between the wands, hose and wand, or power nozzle and wand. If it came with the Sidekick, try using it on the end of the hose. If not, simply try using the power nozzle on the end of the hose (no wands). If it works, then the problem is going to be with the cord sections in the wands. Check them good for cracks, breaks, and discoloration at connections. Replace if necessary.
Jan 05, 2011 | Electrolux Eureka Easy Clean 2 in 1 Stick...
Whenever we use our central vac the power cuts in and out often. It happens at all outlets. When I borrowed the neighbour's hose it did the same thing. So I assume I can rule out a short in the hose. Any...
Not necessarily. If the neighbors have the same problem, it could still be the hose. Try your hose at their place.
You can also use their hose AND power nozzle at your place. If their power nozzle works fine, then it's loose or worn wiring in your power nozzle or connection. Also, you can try your power nozzle at their place to double check.
Check your power nozzle connection for discoloring, breaks, cracks, etc. Take to a shop to check internal wiring.
Oct 31, 2010 | Filter Queen Vacuums
Power head hose to fit power nozzle PN-4. Electrolux MDL 1401B
Generic problem for all Vacuums
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
I would advise because this is an older Electrolux Power Nozzle PN-4
Model #1401B that you could buy a replacement hose of which would save you money or you can spend the price for a genuine hose – replacement hoes work just fine and are less money. 1-800-657-1874 -- they can ship one to you UPS….
Don - The Vac Man
Apr 21, 2008 | Vacuums
Electrolux UltraLux 2000 Bagged Canister Vacuum Logo
422 people viewed this question
Top Electrolux Vacuums Experts
Roger Potts
Mike Cairns
Mike Cairns
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
