Question about Lands Phones
The Phone when it dials out when the other party picks the line goes dead
    Problem Solver:
  • 16 Answers
This is a typical service provider problem. The fact that the phone is able to establish contact to bts implies that the phone is ok.
Contact your service provider it could be a call setup glitch which will be corrected on your service provider switch.
Posted on Dec 04, 2008
Remove dead co line
disconnect the line in system programming.
program*#1234, then 400 sp-phone , enter co line no.
then select disconnect and store.
Oct 29, 2013 | Panasonic KX-T7453 Corded Phone
I have the panasonic handset phone. I have three lines. When I pick up the phone it goes automatically to line 3. If I have a call holding on line 1 from the desk phone how do I get to line 1 on the...
A lot depends on what sytsem the 7896 is plugged into. If it happens to be a TA series, you'll go into station programming mode (menu 99) and dial 11. The change this makes is that you will have to dial "9" to get an outside line, or 53x to pick up lines 1,2,3 etc. To get back to idle line preference, dial 12, but a cordless phone should never be set to ILP because you can't call internally or page.
Carl
Sep 21, 2010 | Panasonic KX-TD7896 Cordless Phone
Panasonic KK-T7633 When I pick up the phone to dial out I have to manually select a line to dial out on because the phone automatically selects the intercom button on the front of the phone. How do I fix...
I have the same problem. It happened because I put a speed dial number on the first line. Even after deleting it, it still goes to the intercom and the first line is never the same since.
Jan 28, 2010 | Panasonic KX-T7633 Corded Phone
Panasonic KX-T7633
You're in luck. Without picking up the handset, press PROGRAM the line 1 button, and dial 0 001 (or 01) and STORE. Press PROGRAM to exit.
If I "guessed" right, on your TDA system, you have line 1 back.
Carl
Sep 17, 2009 | Panasonic KX-T7633 Corded Phone
CANNOT RECEIVE FAXES ALL OF A SUDDEN
Check the phone line with a basic old phone plug it into the fax line do you get a good dial tone, and no noise on line. Also check the phone line call ATT and have them check the number move the fax machine to different plug. power off the wait tens second power on. check the phone line connector.
Mar 31, 2009 | Minolta Office Equipment & Supplies
No dial tone
Sounds like the phone line may be dead, try to put another phone on that line and make sure the phone line is active.
Hope that helps...
Lbcoaster
Aug 05, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Fax machine wont send or reiceve
Check to see if you have a dial tone. If not, plug a regular home phone into the jack in the wall and see if you can call it or dial out. You might have a dead phone line.
Apr 22, 2008 | Office Equipment & Supplies
Storing Speed Dial Phone Nmbers
Emergency/quick dial numbers: Pick up handset, push store, enter the phone number (it will not call the number), push store again, Push A,B or C. hand up handset. Frequently called numbers, pick up the handset, push store, enter the phone number, push store again, push key pad 1, or 2, etc. for memory location. Hang up handset. How to change a stored number. just repeat the sequence. How to clear a stored number, repeat the storage skip step 3 (do not enter the phone number). How to correct an error while storing, just hang up and repeat.
Feb 26, 2007 | GE Telephone pr521w
Lands Phones Logo
56 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
