Question about Canon IMAGERUNNER 6570 Copier
Canon Ir5000 tray one... originally called for "pucking toner on page.. Removed paper feed unit / cleaned up &reinstalled. Now as soon as I hit start 3secs..shows paper jam.. chked all connections, ok.. Possibly put something together wrom, #2 and #4 work fine tray 3 shows u2 I'm a bit frustrated because I'm not trained on canon but needed the cash...HELP PLEASE// WAITING
  • Wayne Dsouza May 11, 2010
    did you try cleaning the sensors for tray 1 feed path?
  • 58 Answers
It sounds like either a clutch or feed roller is not firing. It is not a switch cause that would affect all trays.
Posted on Dec 04, 2008
What does E02 mean
PDF]canon printer error code e31.pdf - WordPress.com
https://maitioprolur.files.wordpress.com/.../canon-printer-error-code-e31....
... on Canon. Printer MP287 : E02 E31 Cause : The printer is not connected to the computer ( the printer is ... Canon Pixma MP287 All in One Printer List of Error Codes There ... Cartridge: Canon E31 Toner CANON Printer + Copier + Scanner -.
Aug 26, 2015 | Canon PIXMA Office Equipment & Supplies
Duplex feed not working
Check the C6200 Device Settings in the properties and make sure that the Duplex Unit is installed.
original?v=mpbl-1&px=-1
Dec 09, 2013 | Brother HL 5250DN Laser Printer
My HP 4ML has been printing fine until recently. Every print job, big or small, the first couple of pages print the pages mostly black, then start to fade the more pages I print in the same print job. ...
You didn't say that you swapped out the toner.
Let's come back to that point later.
Put paper in the manual feed tray.
Print something.
As soon as the paper feeds halfway into the printer, open the top cover.
Pull out the toner, look down at the paper. Is it mostly black?
If the answer is yes....replace the toner.
Vacuum out the inside of the printer and print again.
I think you have a bad toner cartridge
Feb 01, 2011 | HP LaserJet 4ML Printer
Canon Image Class D320 does not copy entire page. New toner has been installed.
Has anyone changed the paper size in the paper tray to another size by accident? Have you tried the manual feed tray? If that copies the whole image then the problem is with the paper size input of the paper tray.
Apr 15, 2009 | Canon imageCLASS D320 Digital Copier
Paper Jams and Black Streaks
I would suggest calling a professional on this one. The jamming problem you are describing is probably the rubber feed tires in each tray that pick the paper up. They need to be replaced. If you could get the parts, you MIGHT be able to do this...however....the other problem is much more involved. It could be that you only need a drum cleaning blade. This is the blade that cleans the unused toner from the drum. But it could also be the drum itself, the developer, or the fuser. And it sounds like it could use a good vacuuming on the inside. Do not clean the drum. If the drum is still in good shape, cleaning could change that. Drums are very prone to scratch. I would call a professional....tell him or her: the model of the copier, and to bring feed tires, a drum cleaning blade, and a vacuum.
Hope some of this helps,
Chad
Oct 11, 2008 | Canon imageRUNNER 2200
Brother HL 2070N red paper light blinks but won't print.
Just fixed my printer issue, had the same problem, Would load 1 sheet, then jam, sometimes it won't pull the paper out of the tray, sometimes it would pull the paper to the toner area, but never into the toner, opening and slamming the paper tray while it attempted to load would usually work, but who wants to slam the tray 50 times? I was using Walgreens generic paper, 20lb, took some higher-quality 24lb HP paper and VOILA! It works every time! EVERYONE WHO IS HAVING THIS PROBLEM, CHECK THAT YOU ARE USING 24LB PAPER!!! Brother says 20-24 is acceptible, but sneaking one sheet of 20lb paper about 15 sheets down in a 20 sheet print job and it will stop at it every time, You can feel the difference, less like toilet paper and more like real paper.
24 LB PAPER! USE IT NOW AND THANK ME LATER!
Jun 27, 2008 | Brother HL-2070N Laser Printer
Paper Jam Problem in Canon LBP 2900
I have a same problem .... somebody help us. :(
May 23, 2008 | Canon LASER SHOT LBP-2900 Printer
Canon iR5000 Tray 3 problem
look behind the tray and see if there is paper stuck behind the tray. Good luck
Dec 18, 2007 | Canon imageRUNNER 5000 Copier
Toner
I had the same problem with this printer. And I think I got the problem solved by removing the all paper from the paper tray, and re-inserting the toner cartridge. I think it is the problem with incorrect error message from Canon's printer. It is problem of paper being fed into the printer mechanism slightly.
Nov 27, 2007 | Canon imageCLASS® MF4150 All-In-One Laser...
103 people viewed this question
old marine
old marine
