Question about APC (BH500NET) UPS System
Common Failure mode of APC 500 UPS
We use MANY APC 500 UPS's (Each PC) approxiamately 150 at work has one.
We do generator checks once per week and the UPS's help keep PC's up as electrical load switches from electric company load to generator power and then back after 15 mins.
We have constant UPS failures. Many can be corrected by replacing the batteries.
I have noticed most of the time when the replacement battery doesn't fix it, the followign observation:
I place a small home 3 prong electrical outlet tester in the Battery backed up outlet and with the UPS ON and plugged in the tester reads FINE (two orange lights on and red light is off).
On bad units when electrical source is killed, the tester has one orange light go out or dim indicating (according to tester) that the Ground is open.
Any idea what is typical failure or failed item inside I could replace?
I plan to take one and TEAR it apart down to the component level looking for bad failed components to try to repair others vs. throwing them away.
We will not trade them in on new units.
I would recommend replacing APC UPSs with ONEAC ONEPlus Power Conditioned UPSs, which have a perfect ground reference, longer lasting and more reliable batteries, and a 5 Year Warranty (2 Yrs on Batteries).
www.gryphon-inc.com
1-800-POWER-OK
Posted on Jan 30, 2009
APC Smart VT 30KVA UPS cannot sustain power after power failure
ups units run a computer directly from mains power and from a battery when mains power is cut.
some run the computer through the battery at all times and so use the battery as a surge protection
points to check on your unit
is the by pass system being damaged in the surge protection section
is this requiring the batteries to provide power but not being charged at the same time
Is the power consumption exceeding the battery rating ( pc, printer, monitor , modem etc exceeding the out put of the ups
Apr 27, 2015 | American Power Conversion Corp...
Low voltage output 170 volts
Check your voltage meter, so it measures correctly, probably generate your UPS is not pure sine wave, but a modified sine, then the simple measuring devices to display the wrong value.
Jun 20, 2014 | APC BE500R Back-UPS ES 500 (BPAPWBE500R)...
APC BACK-UPS ES 500VA fails to provide back up during power failure
Get APC Powerchute Personal Edition for free and run it. If it says your battery isnt charged, check its voltage disconnected. Charge it with a car battery charger and see if its still a good battery. If not , replace it. If the battery is good, then check the charging voltage. Should be about 14 volts. if not, check the small transformer on the main board. Should be 120 in and 17 to 18 out. 4 diodes in a bridge for charge. The input to the transf has small fuse into it alone.
Jan 04, 2013 | APC BE500U ES 500 USB BACK-UPS 500VA/300W...
APC 1100CI-IN UPS NOT EORING ON GENERETOR WHAT I DO? PLZ SEND SULATION E-MAIL singhpintu987@gmail.com
Hello Sing,
There is a possibility that your UPS doesn't like the voltage or frequency that the generator is feeding it. As per an APC knowledgebase article, the size of a generator should be 3 to 5 times higher that the total Watt/VA load that it would be supporting.
There are also instances wherein the sensitivity threshold of an APC BackUPS is set too high that a slight change in voltage/sensitivity would cause the unit to switch from online to on battery too frequently. This can be addressed by lowering the sensitivity either by their APC PowerChute Personal Edition Software or via the front panel switch.
If you are going to do it via the software, it needs to be installed on your computer. Prior to downloading it, make sure that your operating system is compatible with it. Suppose that your operating system is compatible, once the program is installed you will need to open it up and look for the Sensitivity option and from there you could select Low, Medium or High.
If you are going to do it via the front panel switch/button the UPS should then be turned off but plugged in to an input source. Press and hold the On button until you see that the LEDs are flashing. Once the LED is flashing, press the button again to set the desired sensitivity. Low sensitivity would show the On Battery LED flashing. Medium is On Battery and Overload LED while High is On Battery, Overload and Replace Battery LED flashing. If you'll see a flashing Online LED it means that you are cancelling or exiting the program mode of the UPS.
Below are some helpful links from APC
*** You will need to login in APC before you can download the software. Choose the correct PowerChute Personal Edition Compatible with your OS and create an account online.
Jul 22, 2011 | APC Back-UPS CS 500VA UPS System
My inverter (500 va) (battery based electric generator for power backup) keeps on charging batteries even when the charging light goes off making the inverter, wires and battery very hot.
This a possible failure of the voltage detection circuit in the inverter main board and requires the fault be identified by checking the voltage/current feed/limiter to the battery.
Once when the battery voltage has reached the threshold set up the charging should stop and then the circuit will analyse the voltage on the board to trigger the charging to be put ON.
This can be a failure of the detection circuit and if not checked can damage the battery.
Jun 20, 2011 | APC American Power Conversion Back Ups Es...
My Apc Back UPS Es 500 did not charge and then there is power when I turn on the switch. How could I repair this problem?
Good Day! Try changing the battery. please visit apc's service center for battery replacement. it will only take 3-5 working days. once done, your ups will be as good as new.
Nov 09, 2010 | APC BE500U ES 500 USB BACK-UPS 500VA/300W...
Ups not working on generator power
you will try to change the fuse in ups
Aug 24, 2009 | APC Back-UPS CS 500VA UPS System
Charging apc 800va through home generators
The reason of this is the UPS cannot adopt on the frequency that is being generated by your home generator. you should use APC smart ups series coz smart-up series can work on a wider input frequency range.
Jul 27, 2009 | APC Smart-UPS RT 8000VA (0731304239635)...
APC (BH500NET) UPS System Logo
503 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
