Question about Bburago Citroen C6 Diecast Model
Citreon berlingo 1999 diesel 1.9l need new spark plugs
The van wont start on cold mornings and new spark plugs are needed just neede some advice on changing them myself
    Champion:
  • 250 Answers
Heater plugs are easy, 1 is hard if fitted with a turbo diesel on the bosch pump, 1 behind it.
there easy to change.
Posted on Aug 16, 2009
  • 600 Answers
You will need some decent spanners, the nuts are 8mm on the wiring and some will need a 1/4 drive socket, some a small spanner, get decent glow plugs, maybe citroen ones, there are som unreliable ones out there, even the Bosch ones sold by factors are not as good as factory! the plugs themselves are usually13mm and tight. You may have to take some air filter or emission stuff off but not the fuel injection pipes, leave them alone!
Posted on Aug 13, 2009
  • Chris Edwards
    Chris Edwards Aug 16, 2009
    Firstly buy good heater/ glow plugs from the dealer, the ones from factors, allthough a bit cheaper can be poor performers.You will need decent tools (8mm spanner/ 1/4 drive socket set and 12 or 13 mm 3/8 drive socket set and spanners) you might have to remove some inlet piping but do not take injector pipes off! take the 8mm nuts off the wiring first then unscrew the plugs, dust off the debris with a small paintbrush before sliding the unscrewed plug out.Tighten the new ones tight and put the wire back on (dot forget the power feed on one plug as well as the wire that connects all 4.
  • Chris Edwards
    Chris Edwards Oct 03, 2009
    Are you sure they are faulty? the warning light often goes out before the relay drops out and stops the glow plugs, try on the next cold morning waiting for the count of 20 before cranking and see if that works.they are on the front of the engine, they are fiddly but not too hard to change, the wiring is held on with nuts with 8 mm heads, a 1/4 drive socket set and a spanner is needed. The glow plugs (buy good ones not cheapones) are 13mm and a 3/8 drive socket set and a decent combination spanner are needed. do not remove the injector pipes as one small bit of grit will block an injector.
2 Suggested Answers
citroenchris
  • 600 Answers
SOURCE: Hi,I have a citreon berlingo
Check the fuel filter for water!
Posted on Mar 09, 2011
Citreon Berlingo van. Need to unlock radio but dot have the code,can thius be done.
u can buy an unlock code on ebay from £2.99 you will need to take out the radio from the dash to get the serial number.
Jul 01, 2015 | Cars & Trucks
Engine idle speed on citreon berlingo 1.9
Warm diesels should idle low. Some of them 800-900 revs.
At cold, they should have a fast idle, some 1100 revs.
look if your engine has a cylindrical device, with a bowden cable to the diesel distibutor pump. This will be your coldstart device, responsible for idle revs.
Aug 09, 2014 | 2005 Citroen Berlingo
Berlingo surges and chugs when cold.
if this is a diesel then disconnect the vacumn pipe to the EGR valve and see what it runs like
Feb 14, 2013 | 2009 Citroen Berlingo 1.9d
Ford escort 55 van cold start problem 1.8 diesel 2001
COLD START PROBLEM
Its cold start issues:----
Go through the list of help links mentioned below:----
Click the link :----
Cold start problem and vehicle shudder around 2500 to 3500 rpms
http://repairhelpcenter.blogspot.com/2012/10/cold-start-problem-and-vehicle-shudder.html
Low idle when cold out side?
http://repairhelpcenter.blogspot.com/2011/12/low-idle-when-cold-out-side.html
Ford explorer 4.0 will not idle when cold?
http://technoanswers.blogspot.in/2012/02/ford-explorer-40-will-not-idle-when.html
Automatic transmission shift lever hard to move on cold mornings?
http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
Car won't start when cold?
http://schematicsdiagram.blogspot.com/2011/12/car-wont-start-when-cold.html
These will help.
Thanks.
Nov 28, 2012 | Cars & Trucks
How to set timing on a citroen berlingo 1.9 diesel
How to set timing on a citroen berlingo 1.9 dieselThat's the question....butwhere's the answer? Diesel pump positioning? (Done Cam & Flywheel locked.....)
Aug 26, 2012 | 2006 Citroen Berlingo 1.9d
My 1999 plymouth voyager turns over but wont start
Please post Year, make, model, engine, mileage of your van.
Do you get 'spark' at the plugs?
Check engine control fuse box next to battery.
Timing jump??
Just ideas...
GL
Dec 16, 2011 | 1999 Plymouth Voyager
Diesel engine wont start when cold
check the wireing to the glo-plugs.... sounds like they are'nt getting juice
Jan 26, 2010 | 1983 Jeep CJ7
Bburago Citroen C6 Diecast Model Logo
890 people viewed this question
Top Bburago Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Bburago Toy Expert? Answer questions, earn points and help others
